Soft floor and lathe...
Ebenezer Good22/09/2021 18:53:55
17 forum posts
2 photos
6" is much better! I had visions of you and your lathe disappearing down a hole!wink
Enjoy the lathe, I have the Smart & Brown version.
Tonny Andre22/09/2021 23:27:15
12 forum posts
3 photos
Hehehehehehe. I have taken it all apart and repainted and cleaned it. A bit worn, but it works very well. Soon getting it together again and wonder how it will run.
Howard Lewis24/09/2021 08:11:28
5298 forum posts
13 photos
To spread the load, you could always make a frame out of angle iron, say 60 x 60 x 6 and put the lathe stand on that.
The floor will be less likely to compress into holes, locally, since the load is spread, the pressure is considerably less, and the frame will add rigidity.
Then you will have place from which you can start to "level" the lathe. In this context, for most of us, "level" will mean adjusting the feet of the lathe (Not the stand ) to take twist out of the bed, so that it cuts as near to parallel as we can get.
The level from Headstock to Tailstock will matter when flood coolant is used, since the coolant needs to be directed to the drain back to tank.
Otherwise, for dry cutting, a slight deviation from absolutely level will matter very little.
JD Metals
walker midge
BOLDON
rapid Direct
