5/8" BSP compression nut
Bill Phinn17/09/2021 14:21:50
572 forum posts
86 photos
An old but well made brass bib tap of mine recently started to weep at the water inlet compression joint. Dismantling it revealed that it consists of what appears to be a 5/8" BSP compression nut with an integral olive. The bore accepts 1/2"/15mm pipe.
I've replaced the tap with a ubiquitous 1/2" bib tap for the moment but I might like to reuse the old tap at some point.
Does anyone know where I can get 5/8" BSP compression nuts either with an integral 1/2" olive as originally or that accepts a loose 1/2" olive?
Thanks.
DC31k17/09/2021 15:18:49
571 forum posts
1 photos
JTM Plumbing
TB72 3458 5/8" BSP F to 3/4" BSP M bush
DZR02 1534 3/4" BSP F to 15mm compression
Bill Phinn17/09/2021 16:34:30
572 forum posts
86 photos
Posted by DC31k on 17/09/2021 15:18:49:
JTM Plumbing
There wouldn't be enough room laterally to fit those in, unfortunately.
Bill Phinn17/09/2021 18:38:46
572 forum posts
86 photos
This is the nut in question, btw. It looks like it did consist of two parts, but in my case the olive has effectively welded itself to the inside of the nut:
Edited By Bill Phinn on 17/09/2021 18:39:01
JD Metals
walker midge
BOLDON
rapid Direct
