Replacing a bushing
Tim Gosling02/09/2021 12:04:41
4 forum posts
Hi all,
I'm trying to fix my trusty 10 year old cross trainer. There are some bearings that are quite worn which I think are called bushings. They push fit into a steel tube and a steel shaft runs through them. Because they are so worn on the inside I have measured the shaft diameter instead to get an inside diameter for them. The measurements I've taken are:
Internal diameter (diameter of the shaft) 15.4mm
Outside diameter 24mm
Length 17mm
There's also a flange on one end and a notch cut into the side.
I've googled bushings and found a few websites like BearingShopUK, SimplyBearings, BearingBoys etc. but none of the bushings they sell quite match what I need.
So my questions are, is this a non-standard size or possibly an imperial size or perhaps this isn't called a bushing and I'm googling the wrong thing?
Paul Kemp02/09/2021 23:17:58
689 forum posts
18 photos
Tim,
How accurately did you measure the shaft and bushes? None of those sizes (as you state) seem to correlate with standard flanged oilite bushes. So two possibilities, one is your measurements are off or two the manufacturer of the trainer used odd size bushings. The latter makes little sense in terms of cost - making their own bushes to odd sizes adds cost and complexity to their product, however they may have altered the length and OD of a standard product to suit the other materials they were using (although 15.4mm bore makes little sense either) so maybe it was the former! If so the lack of suitable off the shelf replacements protects their product in some ways by ensuring if you want parts you can only source them from them, or it guarantees obselesence and forces you to buy a new trainer? Probably the only way to match those sizes if your measurement is accurate is to make your own!
Paul.
noel shelley03/09/2021 00:11:13
759 forum posts
19 photos
Are the bushes steel, the picture seems to show rust on the bore ? Noel
Pete Rimmer03/09/2021 06:51:05
1072 forum posts
69 photos
Looks like a 5/8" x 15/16" x 11/16" long bushing to me.
Edit: Looks like you have taken the flange OD as your OD size. If so, it should be OD of the bush itself.
It looks like the part number is made up from the relevant sizes in sixteenths of an inch.
Edited By Pete Rimmer on 03/09/2021 07:11:55
Redsetter03/09/2021 07:02:30
191 forum posts
Quite possibly an Imperial size, as posted above. There is still a lot of Imperial stuff in use, even in new machinery. I would suggest going to a bearing factor with a trade counter, who can measure it properly and will know the market, rather than trying to do it on line.
Tim Gosling03/09/2021 10:21:41
4 forum posts
All measurements were made with a digital caliper. It's an inexpensive one but I think it's accurate. The OD measurement is the bush not the flange, the flange OD is 28mm.
Not sure what they're made of, I agree that does look like rust.
5/8" x 15/16" sounds close enough to me. It's a cross trainer not a nuclear reactor so I can live with a bit of play. Worst case scenario is I fall off it.
Googling 5/8" x 15/16" Bushing comes back with quite a few suppliers, mostly in the US. I'll email some of the UK suppliers first but if I have no luck I'll buy from abroad.
Paul I like the way your mind works, suppliers balancing cost of production Vs being the only source of spares Vs deliberately making their old products unrepairable. It has a ring of truth. Or maybe spending time reading internet forums has made me a conspiracy theorist
pgk pgk03/09/2021 10:58:43
2317 forum posts
293 photos
Have you tried looking for a manual/parts diagram on the web? Some of these gym machines may be rebadged US designs and perhaps a clue if nuts and bolts are non-metric.
pgk
Pete Rimmer03/09/2021 11:45:06
1072 forum posts
69 photos
I would be very tempted to knock up a couple of bushings from Delrin or PTFE.
bernard towers04/09/2021 19:14:08
293 forum posts
84 photos
I would hardly think a cross trainer would have missed imperial fixings by about 30 years.
Tim Gosling05/09/2021 11:40:55
4 forum posts
I don't think it's a very well known brand. It's called a Sprint Elite XZ1 and when I google that all I get is someone in Dundee selling one for £50 back in 2014
Edited By Tim Gosling on 05/09/2021 11:41:13
pgk pgk05/09/2021 12:52:25
2317 forum posts
293 photos
XZ1 cross trainer finds Hammer https://www.hammer-fitness.co.uk/ and a few hits to hammer xz1 cross trainers in Germany. It may well be the original source of yours - rebadged or renamed. Perhaps a word with the company above to see if they recognise it and have access to manuals or spares?
pgk
Tim Gosling06/09/2021 12:04:31
4 forum posts
Thanks pgk, I completely missed that when I searched before. I'll contact them.
walker midge
BOLDON
rapid Direct
JD Metals
