Myford cross-slide
Slipping marker ring
Michael Brett 130/08/2021 20:42:29
23 forum posts
Hi al
I have a Myford super 7 lathe ,imperial version. On the top slide the marking ring turns with the hand wheel as it should . But on the cross-slide the marking ring almost spins freely, which means I cannot use it for measuring how much I am turning off. Is there some sort of clutch mechanism , if so how can I tighten it up.
Or does something need replacing. Thanks in advance for any help.
speelwerk30/08/2021 20:48:28
418 forum posts
Probably the diaphragm washer is missing. **LINK** Niko.
ega30/08/2021 22:25:04
2255 forum posts
186 photos
A further tip: if the diaphragm washer does not apply enough friction to the dial you can hold it on edge and tap with a soft hammer to put a bit more set into it.
Steviegtr30/08/2021 22:26:45
2243 forum posts
311 photos
As above. Yes it sounds like the spring washer is missing or broken. Remove the slotted screw in the centre of the handwheel & it will come off.
Steve.
Michael Brett 131/08/2021 09:40:42
23 forum posts
I took the handle of and the spring was in place and seemed in good condition. It was all very dirty though with lots of swarf mainly brass. I gave it all a good clean and now it is working fine. Must of been all the muck stopping it getting enough grip. If I have any more trouble I will order another spring. Thanks for all your advice.
Cheers Mike
walker midge
BOLDON
rapid Direct
JD Metals
