Making radiator caps
martyn nutland | 28/08/2021 09:29:29 |
133 forum posts 7 photos | Hello Everyone I wonder if I might pose a couple of questions and try out an idea on the experts? I want to make a bronze vintage radiator cap (I do know I could buy one but they seem disproportionately expensive and I like to make things!) I thought... if I bought a nut of the same thread as that on the neck of the header tank, I could turn off the hex on the lathe, mill a bronze replica of the original cap and solder or braze it to the nut. Simples! Job done. However, I can't for the life of me, and after consulting every table I can find, determine what the male thread is. The major diameter is 37mm 16 TPI. Any ideas? Now I acknowledge the proper way to do this job is start with raw bronze and cut the female thread on the lathe, but I don't feel I have the competence or confidence to do this, not least because there are a few fundamentals I'm unsure of. I use a Chester Super B lathe configured for metric. Assuming I know the lead screw pitch, can I gear a metric lathe to cut imperial threads, as would be required (I guess) for the radiator cap. And if I can, and someone knows the thread I'm talking about, what change wheels might I be looking at. Hope all this is not too bizarre. Best, as always, from la belle France. Martyn
martyn nutland | 28/08/2021 09:46:03 |
133 forum posts 7 photos | Addendum! As regards the thread - I've seen the major diameter expressed as 1.475 inches, which is about 37.4mm isn't it? Martyn |
Michael Gilligan | 28/08/2021 09:53:40 |
![]() 20081 forum posts 1041 photos | My trusty ‘Fractions Calculator’ gets 37 and 93/200 mm [37.465] … but, whichever way you express it, I don’t recognise that as a thread size for which you could expect to buy a standard nut.
MichaelG. |
noel shelley | 28/08/2021 10:03:27 |
1282 forum posts 21 photos | A 1" brass commpression fitting might be worth a try - the nut ! Or the brass fittings used on plastc pipe may be big enough. I will see if I have one and can measure the thread ! Some had fine threads others much coarser. Talk to a plumber, or look in his scrap box. Good luck Noel |
john halfpenny | 28/08/2021 10:05:05 |
232 forum posts 24 photos | Vintage radiator threads are, in my experience, all over the place, but a Model A Ford is about 16tpi ( much larger od though). This Ford thread would certainly be 60 degree form. Vintage Vauxhall is much coarser at 8tpi. |
Clive Foster | 28/08/2021 10:09:10 |
3104 forum posts 107 photos | Martyn According to Andy Pugh if its 37 mm diameter its a PG29 conduit thread to DIN 40430. Andys list gives :- Designation Pg29 Seems awfully shallow for a radiator cap thread but the numbers fit. That said 16 TPI is a permitted constant pitch thread under the Whitworth system but you'd expect the diameter to be 1.5 inch if it were Whitworth. Constant pitch size nuts in Whitworth don't exist. Specials only. Clive PS Rattus Crappitus. Spent ages sorting that into a nice list with extra spaces and the stupid forum software just stripped them out. Edited By Clive Foster on 28/08/2021 10:11:16 |
JasonB | 28/08/2021 10:09:45 |
![]() Moderator 22579 forum posts 2637 photos 1 articles | It's quite possible it is 1.5" nominal with worn or over rounded crests and could be 55 or 60deg Though the originally quoted 37mm x 16 would make it a PG conduit thread but usually only thin pressed steel nuts available for that Beaten by clive, just Edited By JasonB on 28/08/2021 10:10:20 |
ega | 28/08/2021 10:13:04 |
2498 forum posts 200 photos | I have a couple of larger radiator caps (c49mm OD) both with 16 TPI threads and deduce that this may have been the standard for this kind of thing. I assume that your smaller cap is for an Austin Seven. My own 1931 machine came with a presumably non-standard one with built-in temperature gauge; after this was stolen I replaced it with one that resembled one of the couple: Not an answer to your question I'm afraid but I thought this might be of some interest. In your position I would regard the machining of the body with its pleasing form to be the difficult bit; the screwcutting looks straightforward. |
Speedy Builder5 | 28/08/2021 10:22:31 |
2592 forum posts 207 photos | What vehicle radiator ?? British / American will use TPI and most others will be some form of metric generally. 37mm is about Austin 7 size. which I believe is 1 1/2" and the thread would be Whitworth form and any TPI the maker chose. Bob (1932 Austin 7) |
roy entwistle | 28/08/2021 10:52:52 |
1504 forum posts | What make of vehicle is it ? |
bernard towers | 28/08/2021 11:05:06 |
573 forum posts 109 photos | I’m with Jason it’s a worn 1 1/2” x 16, I have done one in the past. |
Clive Foster | 28/08/2021 11:10:43 |
3104 forum posts 107 photos | Probably made undersize rather than worn. Radiator cap threads are usually made fairy slack to help dissipate pressure during unscrewing if the cooling system is still hot rather than blasting it off as it come to the end of the last thread. The extra 25 thou clearance by making the majot diameter 1.475 inches rather than the "proper" 1.5 inches for a constant pitch Whitworth thread is entirely reasonable. Clive |
Watford | 28/08/2021 12:25:05 |
![]() 141 forum posts 11 photos | Posted by Speedy Builder5 on 28/08/2021 10:22:31:
What vehicle radiator ?? British / American will use TPI and most others will be some form of metric generally. 37mm is about Austin 7 size. which I believe is 1 1/2" and the thread would be Whitworth form and any TPI the maker chose. Bob (1932 Austin 7) and 1929 Chummy at 1 1/4" by 13tpi Mike |
Martyn Nutland 1 | 28/08/2021 13:06:13 |
20 forum posts | Many, many thanks everyone. An education in itself! I'll pursue PG29; maybe ask our plumber, who, resident on the Somme, may not often deal with Austin Seven radiator caps, Thanks again Martyn |
JasonB | 28/08/2021 13:48:08 |
![]() Moderator 22579 forum posts 2637 photos 1 articles | You would do better asking an electrician than a plumber as it's a conduit thread. But as others have said 1.5" x 16 most likely on an A7 |
HOWARDT | 28/08/2021 14:00:58 |
900 forum posts 39 photos | Why not try ringing a radiator refurbished/maker, I have one near to me and there was one recently on a car rebuild program recently. |
Paul Lousick | 28/08/2021 14:07:25 |
2013 forum posts 711 photos | Martyn, You have said that " if I bought a nut of the same thread as that on the neck of the header tank, I could turn off the hex on the lathe, mill a bronze replica of the original cap and solder or braze it to the nut" Therefore you must have access to a lathe and mill so why not make a cap yourself. Not too difficult and will be a good learning curve for some new skills. Try plastic or aluminium for a trial first, then make one out of brass or bronze, A good feeling after you have mastered it. Paul. Edited By Paul Lousick on 28/08/2021 14:11:42 |
Russell Eberhardt | 28/08/2021 15:14:03 |
![]() 2728 forum posts 86 photos | I would be inclined just to buy one new. I've had good service from the Seven Workshop in the past. Probably cheaper than a chunk of bronze to make one. Russell |
Martyn Nutland 1 | 28/08/2021 16:20:06 |
20 forum posts | We have them as well - electricians! I know...key in your credit card co-ordinates and you have one by return (or something) of post from the usual suspects. Or most other Austin Seven parts for that matter.. I just wanted to make one, which is what I thought we were about. And I wanted to learn. Best
Michael Gilligan | 28/08/2021 16:45:17 |
![]() 20081 forum posts 1041 photos | Posted by Martyn Nutland 1 on 28/08/2021 16:20:06:
[…] I just wanted to make one, which is what I thought we were about. And I wanted to learn.
. That’’s the spirit Unfortunately; if the original is like ega showed … I would think it's formed from tube, and then closed with a soldered-on cap. I would love to see how they actually made that. MichaelG. |
