Mark Simpson 1 | 21/08/2021 12:35:50 |
111 forum posts 30 photos | I need to get the spindle bearing assembly out of my quill to nip up (or replace) the bearings... It's similar to a Bridgeport but always some slight differences.. I have the lever of the bottom of the depth rod easily, but can't work out what the widget is at the top? (and then how to extract it) |
Michael Smith 15 | 21/08/2021 22:03:07 |
28 forum posts | On my XYZ1500 which I think is the same design as you KRV the bearing assembly can be removed without removeing the quill . In the quill at the bottom there is a small grub screw .remove this and undo the aluminium cap , The bearing assembly will then come out, adjust the lock nuts at the top.it only takes a couple of minuets . The grub screw is at the back of the quill and not obvious unless you know were it is Hope this helps Mike |
Gray62 | 21/08/2021 22:45:25 |
1058 forum posts 16 photos | The part at the top of the trip rod will look something like this, It is the reverse trip toggle. there should be a threaded hole in the end into which you screw a threaded bar to pull the toggle out. I am missing mine so if you take it out, can you take some measurements and post on here
Gray |
Mark Simpson 1 | 22/08/2021 10:03:00 |
111 forum posts 30 photos | Thank you Michael and Gray... Now I know what it's called,I've worked out what it does... It trips the feed if you drive it to the top... I've got about 1/2 of it out, after a lot of faffing with some ground down mosquito forceps... Michael, the nose piece has been butchered, prior to my ownership, and it seems was held in with araldite and the grub screw. I've built up the thread (looks like M74x1.25) with silicon bronze and will attempt to cut a new thread. The spindle assembly (sadly) shows no sign of movement, but will keep trying... |
Michael Smith 15 | 22/08/2021 19:04:42 |
28 forum posts | This video shows how to remove spindle https://www.youtube.com/watch?v=T1YJQUpNuaQ Edited By Michael Smith 15 on 22/08/2021 19:06:02 |
Mark Simpson 1 | 25/08/2021 11:12:48 |
111 forum posts 30 photos | After considerable faffing about I got the other part of the toggle out using a 4mm dia magnet... The depth stop rod fell out and I was able to remove the eye that bolts into the quill. Photo and Sketch below... dims are approximate it's fairly mangled (not all by me!) New bearings ordered and need new thread on the nose piece, more pratical now I can properly measure the thread inside the quill. Mark Edited By Mark Simpson 1 on 25/08/2021 11:15:50 |
