Dividing this would have been an interesting exercise !!
Michael Gilligan15/08/2021 08:26:35
19323 forum posts
964 photos
This exhibit is described as a Wire Diffraction Grating : **LINK**
http://waywiser.fas.harvard.edu/objects/261/wire-diffraction-grating
The description is brief; but of course the fundamental requirement would be to have the wires parallel and equispaced. … So, I wonder how much effort must have gone into placing the holes neatly on three concentric circles ?
Unfortunately, the photo is not at high resolution; but it looks to be a fine piece of Scientific Instrument Making !
How would you have done it, with the tools of the day ?
Note that the centres of the ‘tuning pegs’ would be offset to account for their own diameters, and that of the wire !
Edit: __ for comparison, here is a description of some ‘rectangular’ versions:
https://digital.kenyon.edu/cgi/viewcontent.cgi?referer=https://www.google.co.uk/&httpsredir=1&article=1109&context=physics_publications
Edited By Michael Gilligan on 15/08/2021 08:53:54
Dave S15/08/2021 09:02:08
266 forum posts
56 photos
16 lines per inch, there are at most 72 wires.
Think they are 1/16" apart - sounds like rule and dividers layout. : )
Michael Gilligan15/08/2021 09:20:59
19323 forum posts
964 photos
I would respectfully suggest that you may not have considered some subtleties of the problem, Dave
pgk pgk15/08/2021 09:25:21
2366 forum posts
293 photos
Without a DRO and with my limited skills, I would go about it as follows:
Make up/order/buy a strip of metal 1/4in + 4 wire diameters wide and drill/ream holes to match my punch's diameter and spaced and offset for the middle and outer pin holes and in it’s middle for the inner holes, noting the 'handedness' of the pins is different left than right. I'd also create a fixture ring as a stop for my marking bar.
At that point I'd mark/punch and drill the first pair of inner holes and place the pins then lay my marking bar against them for the next set of holes to be marked and drilled, placing only the inner pins and repeat.
Yes I accept that there is a tiny angular difference between inner pins since the wire run starts from an outer but depending on the purpose of this fixture it may not matter and it'd be a heck of a lot more accurate than me trying to work and keep track of all the dial numbers...
pgk
John Haine15/08/2021 09:34:21
4279 forum posts
252 photos
Never mind how they made it, with a spacing of ~1/16" what was it used for?
pgk pgk15/08/2021 09:58:38
2366 forum posts
293 photos
Posted by John Haine on 15/08/2021 09:34:21:
Apparently it was attached to a telescope, presumably a large objective lens and if so then I’d guess used for plate photography?
Either that of the astronomers were fond of egg sandwiches...?
pgk
Dave S15/08/2021 10:01:22
266 forum posts
56 photos
They have to be parallel and equally spaced.
The divider gives me a set of circles, the 1/16" scribe ensures I don't make a gross error.
The (assumed) milling machine /jig bore table takes care of the parallelism - drill one side then move in Y to the other side and drill. Move a precise 1/16 in X, set up over the scribed circle, drill the next one, move in Y.
Repeat until done.
That's how I would do it.
The item is a diffraction grating, used for looking at spectrums of stars I think
Edited to add: the circular pin layout is purely aesthetic, and it isnt that old -1920 - that it would preclude the use of an accurate leadscrew driven xy machine
Edited By Dave S on 15/08/2021 10:05:15
Michael Gilligan15/08/2021 10:14:19
19323 forum posts
964 photos
The listing suggests Microwave or Infra-Red [click the + signs]
… but there’s not much detail there.
bernard towers15/08/2021 10:15:00
343 forum posts
89 photos
Is it possibly a bahtinov mask
JasonB15/08/2021 10:20:05
21650 forum posts
2495 photos
I would have laid it out say 10 times bigger and use some form of pantograph machine to place the holes, would also have made it relatively quick assuming these were made in batches rather than a one off.
Michael Gilligan15/08/2021 10:20:22
19323 forum posts
964 photos
Posted by Dave S on 15/08/2021 10:01:22:
Edited to add: the circular pin layout is purely aesthetic, […]
… and that’s what piqued my interest : The craftsmanship that appears to have gone into that elegant but unnecessary layout.
Mick B115/08/2021 10:30:46
2047 forum posts
117 photos
Posted by Michael Gilligan on 15/08/2021 10:20:22:
Yes, but AFAICS a rectangular layout would have to be bigger. It may be the whole thing had to fit inside a tube of particular diameter to be at the right focal distance or suchlike.
John Haine15/08/2021 10:31:58
4279 forum posts
252 photos
Well no, surely? If the rows were straight either the aperture would have to be smaller or the OD larger which might not fit. If it was microwave it wouldn't be used on an optical telescope, and the spacing is too large even for infra red.
I think Bernard is on the right lines, it generates a diffraction pattern in the telescope focal plane when focused on a bright star, which is characteristic of the optical performance. Ideally if the spatial frequency of the wires is constant across the array there should just be a single line, but that would be smeared out by aberrations. Maybe Neil could cast some (coherent) light as our resident astronomer?
SillyOldDuffer15/08/2021 10:38:37
7709 forum posts
1704 photos
Posted by Michael Gilligan on 15/08/2021 08:26:35:
... for comparison, here is a description of some ‘rectangular’ versions:
Dave's method would work, and is the only way I can think of producing a round diffraction grating to fit in the end of a telescope. (Rectangular gratings are rather easier to make once the kenyon paper has been read.)
The hard part is the accuracy required. Not difficult to make a rough grating if the purpose is only to demonstrate diffraction. Much harder to make a good grating for accurate measurements. Fine results demand the wires be accurately equidistant and accurately parallel, and I don't think an ordinary mill and DRO would do the job particularly well. I think the wires need to be much the same diameter too - accurarely made, and not stretched randomly when the grating is strung.
Really annoying, I can't give it a go. My workshop is full of boxes at the moment pending daughter leaving home, and I can't get at my tools or bench.
This paper has more on the theory. Went clean over my head at school! Don't bother reading it unless diffraction gratings are your thing.
Ady115/08/2021 10:50:25
4827 forum posts
724 photos
Its a 1920s veg-o-matic insert
Michael Gilligan15/08/2021 11:40:38
19323 forum posts
964 photos
Posted by John Haine on 15/08/2021 10:31:58:
There would be no need to change the size or shape of the item, John
There is already an infinite number of possible locations for each peg.
The maker chose the elegant layout.
Samsaranda15/08/2021 11:59:00
1253 forum posts
5 photos
Michael’s link at the top of the page lists one of the users as Oak Ridge from 1931 to 2005. Oak Ridge was the premier nuclear facility for preparing enriched uranium for the Manhattan project and the USA’s subsequent nuclear Arsenal, could there be a use for this item that we are not considering? Dave W
John Haine15/08/2021 12:33:36
4279 forum posts
252 photos
Different Oak Ridge - this one is in Massachusetts, the "nuclear" one in Tennessee.
Peter Cook 615/08/2021 12:40:03
194 forum posts
54 photos
I would have thought dividing to that precision would be well within the capabilities of the clockmakers of the time.
This is mid 19th century work.
The dial is 230mm across, the third wheel (centred in the dial) is about 75mm diameter and less than 1mm thick. I haven't counted the teeth. And I don't think I want to try and make it!
Michael Gilligan15/08/2021 13:36:26
19323 forum posts
964 photos
Angular dividing is simple, Peter … But this device also needs to include all the offsets that relate to the use of those ‘tuning pegs’ and I think it would be a little trickier than dividing a clock wheel.
rapid Direct
JD Metals
walker midge
