Hole diameters for single point threading
Joseph Noci 112/08/2021 21:40:27
1006 forum posts
1247 photos
I have tried to find methods of defining the hole size for a particular thread to be single point cut in the lathe.
This appears to always be based on thread engagement, which is influenced by the material being threaded, and the focus is strongly on tap life. So the hole is larger for aluminium than for a tough steel, etc.
However, tap longevity is not really directly applicable to single point threading, so does this engagement issue still apply unmodified?.
I am internal threading a mating part that screws onto a M1.25 threaded stub, 34.5mm OD. The OD is the OD of the thread on that stub. The mating thread will be in EN8. The thread section on the stub is 30mm long. There is not a great load on the thread when assembled, but slop needs to be as low as possible.
I would presume that I should therefore try to get as high a thread engagement as is possible. 80%? More maybe? I would assume that 80% or more should be easily achieved when single point threading? So do I just use 'ordinary' tapping tables and select 80% or better?
Most tables don't list a 34mmxM1.25 size, but there calculators that do the job - So one could just faff about till the part threads on in a good enough fashion but I don't particularly like that approach - some science (or engineering) is applicable! What engagement should I start with for the 'best' fit possible, including a little faffing?
Joe
Andrew Johnston12/08/2021 22:11:57
6263 forum posts
677 photos
When single point threading I ignore tapping tables and percentage thread engagement. For internal threads I turn the bore to the theoretical core diameter, ie, assuming 100% thread depth. When screwcutting I aim for the theoretical thread depth, checking fit with a mating part. Once near the theoretical depth I take fine cuts, may be a couple of thou off the diameter. When checking fits it is important to do a spring pass and clean the thread with a fine brush. Almost invisible dust or swarf can be the difference between a nice fit and loose. Most of my single point threading is done with full profile inserts rather than HSS, so I can assume that the thread profile is correct.
Martin Connelly12/08/2021 22:20:06
1886 forum posts
203 photos
I was about to answer much as Andrew but he just beat me to it. Thread engagement below 100% is only relevant to tapping with a tap. The point of less than 100% engagement is to reduce the torque required to cut the thread and so prolong the tap life or prevent the tool snapping from excessive torque. The other thing to consider that some materials such as aluminium alloys deform when the tap is used and so a larger tapping drill will result in some material being deformed inwards into the peaks of the resulting thread and less being cut as the tap goes into the hole. Neither of these things is relevant to single point tapping.
A similar thing done with dies is to start with a diameter slightly below nominal to reduce the torque required to cut the thread. Measuring the diameter after die cutting the thread will show that the diameter is slightly larger than the starting diameter as some material will deform outwards.
Martin C
duncan webster12/08/2021 22:38:10
3504 forum posts
63 photos
By slop do you mean axial? If so the thread engagement won't make any difference, and it makes surprisingly little difference to the strength within reasonable limits.
Ady112/08/2021 22:50:27
4724 forum posts
713 photos
Depends what its for
I just go for 0.5 or 0.25 each side if its general stuff
If its important I go for zero error/perfect bespoke fit which takes longer
The threads that always impressed me the most were gun breeches
Edited By Ady1 on 12/08/2021 22:55:21
JasonB13/08/2021 07:03:20
21431 forum posts
2448 photos
Although M34.5 is not standard so won't be listed, if you can find the information for any other 1.25mm pitch thread then just make allowance for the difference between the two nominal diameters. ( note it is the diameter that should be prefixed by the M)
As Howard says it's the flank contact that makes the difference between a sloppy thread or not so it is more a case of how deep you cut and as has been recently discussed that can depend on the form of your tool depending on if it has a flat, pointed or rounded form.
Joseph Noci 113/08/2021 08:09:26
1006 forum posts
1247 photos
Thanks to all for the comments and advice. The cutter I am using is an 16IR-A60 carbide insert. The tip radius appears very small under the microscope - maybe 0.1mm ? Low slop was a poor descriptor to use for what I am trying to achieve and strength is not the concern, but good coaxial alignment is the main aim. I will make one or two test rings and thread for best fit...
Thanks chaps!
Joe
Tony Pratt 113/08/2021 08:49:37
1687 forum posts
8 photos
Joe, 16IR-A60 is not a full form insert, as you say the tip has negligible radius so just using the theoretical core diameter will be I think problematic. A male gauge or mating part would be a good test of fit.
Tony
Andrew Johnston13/08/2021 09:34:45
6263 forum posts
677 photos
To expand on the reply by Tony; this is a 16ER-AG60 insert:
It is an external insert intended to cut a range of ISO metric pitches. The nose radius will be set for the smallest pitch in the range covered. For larger pitches the radius will be too small and the depth of cut needed will be larger than theoretical to compensate. However the outer diameter will remain the same; for internal threads the core diameter will remain the same.
In contrast this is an 16ER 2.0ISO insert, full profile intended to cut only 2mm pitch external threads:
Note the larger nose radius. I will be using this insert later today as I have some M16 threads to screwcut.
SillyOldDuffer13/08/2021 10:00:11
7544 forum posts
1679 photos
Fools go where angels fear to tread, but it's never stopped me before!
The form of a metric thread, and relative dimensions, are defined whether or not the diameter is a preferred size or not. Details in Machinery's Handbook, and similar tomes. I pinched this chart off the web:
Internal Thread at top, external thread below. For all metric threads H = 0.866 × pitch. It's usual for metric threads to be cut or rolled rounded at top and bottom rather than sharp as shown in the diagram.
Thread tolerances are somewhat complicated, ranging from very tight to downright slack, such as threads that are going to be plated. More info on Tolerance Positions and Tolerance Grades here, but I don't think Joe need read it!
A thread made as shown in the diagram would be an uncomfortably tight fit, hard to assemble, and any error in it's manufacture would cause it to jamb. Force fits aren't acceptable if the joint is meant to be unscrewed, so practical threads are cut with slightly oversized 'V's, in effect broadening the bold line. The difference can be seen by comparing DIY store zinc-plated studding with the same sized thread on an Allen Bolt. Studding is crudely made and slack; the Allan Bolt should be much cleaner, well formed and tight fitting in it's socket.
I think Joe can control how tight his thread fit is simply by cutting less deeply than normal. Cutting less than 0.866 × pitch will create an over tight thread, exactly 0.866 × pitch will fit with difficulty, and cutting deeper than 0.866 × pitch will create an increasingly slack fit. I'd make the internal thread first getting as close to 0.866 × pitch as I can measure (not sure how I would do that!), and then use the internal thread as a gauge to make the external thread a tight fit. Could be very tight, needing a strap wrench, or hand tight, as required.
EN8 may not be a good choice because a smooth surface finish is vital for a tight thread fit intended to be screwed and unscrewed, and EN8 often tears roughly when cut.
A precision collar preventing slop might be an alternative to hard to make precision threads.
pgk pgk13/08/2021 10:15:49
2317 forum posts
293 photos
IIRC 'Toms Techniques' on YouTube did a vid showing how to make and use a form tool for a specific thread pitch including the helix angle of the tool worked out for Machinery Handbooks charts
pgk
Andrew Johnston13/08/2021 10:19:29
6263 forum posts
677 photos
Posted by SillyOldDuffer on 13/08/2021 10:00:11:
.......EN8 often tears roughly when cut.......
Agreed when turning, high surface speed often cures the problem. Strangely though the same isn't true when threading. Here's an M16 thread in EN8 I made earlier:
It's not a super smooth finish but works fine as a drawbar on the horizontal mill. The thread was cut on an imperial lathe, so I couldn't use my high speed threading attachment. Instead I was slow 'n' steady with the half nuts always engaged, 85rpm I think.
Incidentally H=0.866P is the theoretical depth of the 60° triangle, it's not the same as the actual thread depth, that's 5/8H, unless one uses Zeus.
old mart13/08/2021 15:31:24
3337 forum posts
208 photos
You will find that any given pitch of thread is the same depth, ie, a 6mm X 1mm pitch thread depth would be identical to a 20 X 1mm pitch thread. So if you need to make a unique diameter thread with a standard pitch, you can use the figures for that pitch of thread. If possible, you can get a perfect fit by using the mating part as a gauge and creep up on the last bit. If the fit is critical, but the mating part cannot be used as a gauge, you could make a threaded gauge of the same size to use instead.
Ady104/09/2021 10:28:00
4724 forum posts
713 photos
An M18 x 1.75 I'm working on at the moment
If it looks ok then it tends to be ok
I only worry if its something critical
The bit to remember is the higher the TPI the shallower the thread depth, no matter how big the job is
Edited By Ady1 on 04/09/2021 10:30:06
Joseph Noci 104/09/2021 14:48:38
1006 forum posts
1247 photos
Joe
Ady104/09/2021 17:20:22
4724 forum posts
713 photos
Run it up to 50 rpm to get the chuck on and off
walker midge
BOLDON
rapid Direct
JD Metals
