HB961 Digital Readout
Roger Stanton03/08/2021 15:53:50
3 forum posts
Hello, My first post here, sorrry if its in the wrong section.
I have a HB961 digital readout and Ive tried for a few hours to locate an English datasheet or user manual without success, can anyone point me in the right direction or maybe supply a link or a PDF.
Thanks in Advance
Roger.
Steviegtr03/08/2021 22:36:02
2244 forum posts
311 photos
Is it a raster table counter. If so try this in a foreign language but all there.
Raster table counter pdf
Steve.
Roger Stanton04/08/2021 11:48:39
3 forum posts
Hi Steve, Many thanks for the datasheet, I can get some info' from it.
When I ordered it I asked them to enclose a datasheet, which they did, but it was in Chinese!!, an order coming from the UK, beats me.
If anyone has an English datasheet I would appreciate a copy please or a link to one.
Best Regards,
Roger
Michael Gilligan04/08/2021 16:29:18
18972 forum posts
944 photos
Posted by Steviegtr on 03/08/2021 22:36:02:
Steve.
DeepL seems to make a reasonable job of translating that
… here’s the first paragraph:
Input signal: mechanical contact, pulse (low: -30V~+0.6V high: +4V~+30V)
- External signals: photocell, mechanical contact, inductive sensor, encoder
- Output voltage for sensor supply: 5V DC, 24V DC 30mA - Possibility to set A ratio, B increment,
initial value C and change of decimal point.
- Saving the set parameters in case of power failure.
- Set of 14 output relay modes
- 3 input modes including ascending and descending counting, counting
with phase difference accounting (raster form)
Ref. https://www.deepl.com/translate
Edited By Michael Gilligan on 04/08/2021 16:30:24
An Other04/08/2021 17:56:49
210 forum posts
Hi Roger,
On Amazon, there is some limited data for this device, and if you scroll down there is a section marked 'Reviews with Images' - this includes a tiny two page data sheet in 'Engrish'. I was able to save this image, paste it into a LibreOffice document, then enlarge it to A4 page size. Naturally this ends up rather indistinct without further processing, but it is just readable - may be some help.
The first part of the 'chinese' document mentioned above is actually Bulgarian, and can be simply copied and pasted into Google Translate, when, as mentioned, it produces a reasonably intelligible output - Ii did try to copy it into here, but although Google produces a fairly well ordered text which is not difficult to read, it loses the formatting when pasted into this message, so difficult to read here.
Roger Stanton04/08/2021 20:08:00
3 forum posts
Hi Michael and An Other,
Many thanks to all, I've now have enough info' to get the unit programmed.
Regards to all.
Roger
Jacques Van Damme05/08/2021 22:34:49
1 forum posts
Hi Roger,
You can find the English user manual of the HB961 digital readout on this link:
HB961 counter
In MEW 305, the recent july 2021 issue, page 26, you will find in my contribution how to connect it with a wire encoder. I used it for a DRO for my Myford ML7R lathe, one for the X-axis and one for the Y-axis. They work fine.
Best Regards,
Jacques
walker midge
JD Metals
rapid Direct
