UNUSUAL THREAD
ray jones 1 | 30/07/2021 11:25:50 |
54 forum posts 29 photos | Hi Everyone I am repairing a very early English made cast iron fuel tank , age approximately 1910. . The drain plug is is a brass/ bronze stopper. The problem is I cant identify the thread type/ size. The stopper plug is 0.424 inches diameter x 25 TPI. My thread gauge identifies it as 25G Can anyone identify this please many thank ray |
not done it yet | 30/07/2021 11:59:03 |
6889 forum posts 20 photos | Repairing or restoring? I doubt it would be unacceptable if a repair changed the thread to something more ‘standard’? |
Steviegtr | 30/07/2021 12:24:50 |
![]() 2460 forum posts 341 photos | Sorry cannot help. But there will be someone helpful along shortly. Maybe with an actual answer to your question. Steve. |
Emgee | 30/07/2021 12:32:52 |
2446 forum posts 291 photos | Ray I believe you have identified the thread as 25TPI at the given diameter, it may not be a standard thread used today but certainly fits the bill for a brass thread that is now more usually 26TPI Emgee |
Lee Rogers | 30/07/2021 12:34:54 |
![]() 176 forum posts | 1/2 inch 26 tpi would be BSB ( British Standard Brass ). It's so close that I wonder if another look ar the tpi might be worth a go?
Nicholas Farr | 30/07/2021 12:45:46 |
![]() 3423 forum posts 1592 photos | Hi, 7 / 16" is close to the diameter that you have measured and the difference between 25 and 26 TPI is hardly noticeable if you are measuring a short section with your thread gauge, so a 7 / 16 x 26 TPI BSB might be OK. Regards Nick. |
JasonB | 30/07/2021 12:50:28 |
![]() Moderator 23076 forum posts 2771 photos 1 articles | 7/16 x 26 was also the old CEI (Cycle Engineers Institute) thread so would be a possibility if a 26tpi gauge looks close |
Nicholas Farr | 30/07/2021 13:05:46 |
![]() 3423 forum posts 1592 photos | Hi, as JasonB has said, and the only difference between British Standard Cycle (B.S.Cy.) is 60 degrees and BSB is 55 degrees thread angle, so either of those may work. Regards Nick. |
Andrew Tinsley | 30/07/2021 16:05:07 |
1615 forum posts | I have an old book on threads dating from 1914 and the usual Machinery's "Screw Thread Book". The nearest thread to 25 tpi is in fact 0 BA (at 25.4 tpi), but obviously this falls down on diameter and the same for 1mm threads. I am pretty certain that Nicholas Farr is correct and that it is 7/16" 26 tpi brass thread (you say the plug is bronze or brass!). Tracy tools do a carbon tap for £3 and a die for £4, plus postage, plus Vat, so you could spruce up the threads if need be. Andrew. |
DC31k | 30/07/2021 17:34:05 |
729 forum posts 2 photos | If we are going for a 'nearest the bull' on thread angle, diameter and pitch (one dart for each property), can I use my three arrows to hit M11 x 1.0? It is closer on two out of three counts than anything thus far suggested. Edited By DC31k on 30/07/2021 17:37:21 |
Howard Lewis | 30/07/2021 20:27:30 |
6316 forum posts 15 photos | I very much doubt if a British manufacturer, back in 1910 would use a Metric thread, particularly 11 x 1 mm which is a bit of a fine pitch oddball (even by modern standards ) I would much more inclined to put my money on an undersize Brass 26 tpi thread. Unless it was a "bastard" deliberately made of keep it unique. We are assuming that the thread form is Whitworth, of course! What is it? (Checking Whit form pitch with a 60 degree gauge will introduce some inaccuracy. ) It could be something REALLY peculiar, that none of us have considered. Howard |
JasonB | 30/07/2021 20:48:44 |
![]() Moderator 23076 forum posts 2771 photos 1 articles | I did not assume whit form, I suggested a 60deg form at 26tpi. I suppose we could also go 1tpi the otherway and come up with 7/16" Admiralty which is 24tpi. What is the fuel tank from? |
Howard Lewis | 31/07/2021 10:01:20 |
6316 forum posts 15 photos | In 1910, I would assume, possibly incorrectly, that almost anything of British manufacture would have used Whit form threads If the plug is the original, thread gauges should settle that argument. A little more information would make life easier for all concerned. Howard. Fat Fingers again Edited By Howard Lewis on 31/07/2021 10:02:41 |
