Lever collet closer problem
Gavlar26/07/2021 07:54:34
79 forum posts
4 photos
I've have a lever collet closer and collets that I will never use. (I have ER collets and holders for everything!)
I thought I'd check it out before passing it on so mounted it on my AUD.
Everything looks ok and moves freely but the collet doesn't close and I can't work out why. The fulcrum is anchored and the lever moves freely but I can't see what it's supposed to move to close the collet.
I strongly suspect user error!!
I've uploaded an album with photos.
model-engineer.co.uk/forums/new_thread.asp?t=162
Thanks for any advice, Gavin.
Edited By Gavlar on 26/07/2021 07:55:16
Gavlar26/07/2021 13:21:16
79 forum posts
4 photos
Cracked it, user error as I suspected.
Clive Foster26/07/2021 15:26:44
2815 forum posts
101 photos
Gavlar
What were you doing wrong?
I have a similar device that I might actually get round to using one day. Be nice to know how to set it up to close. Looking at It I don't properly see how it all goes. One reason why I've stuck to the screw tube operated by a handwheel at the back system.
Gavlar28/07/2021 06:32:01
79 forum posts
4 photos
I was expecting too much movement in the collet. I assumed the lever would take the collet through it's full range, which with Burnerd collets is around 120 thou. The lever only closes the collet the last few thou so I couldn't see it. Simply placing the workpiece in the collet, tightening it by hand then backing of a half turn, allowed the lever to do the rest.
rapid Direct
Dreweatts
JD Metals
walker midge
