Listed on ebay as easily repaired
br24/07/2021 09:37:40
697 forum posts
Bob Stevenson24/07/2021 10:20:42
548 forum posts
7 photos
....It is easily repaired,....just bung it in the scrap and make a new wheel!...........(note cracked spokes!)
Rob McSweeney24/07/2021 10:21:34
58 forum posts
Never mind the flange, which could be built up with weld and re-turned , the spokes at 1 and 2 o'clock look to be cracked at the root.
not done it yet24/07/2021 11:21:09
6279 forum posts
20 photos
Could be turned down and a new ‘tire’ shrink fitted. But what about the other wheel on that axle (and all the rest, for that matter)?
I’m not considering buying it so I’m not going to worry about it, for sure.
Martin Connelly24/07/2021 11:38:26
1853 forum posts
197 photos
Dropped at some point I would guess.
Martin C
Rob McSweeney24/07/2021 11:39:58
58 forum posts
What is the model - are the wheel castings still available?
Nicholas Farr24/07/2021 11:50:53
2962 forum posts
1335 photos
Hi, you could clean the wheel in a ultrasonic cleaner and probably fill the cracked spokes with brazing and then as NDIY fit a new tyre by shrinking or using some high strength cylindrical retaining compound, which would be easier if the wheel is not too difficult to remove, or like Bob has said, fit a new wheel, but failing every thing else, if you have the skill, making a completely new wheel set would probably make it an economical repair. Like NDIY, I'm not going to buy it, so it won't bother me either.
Regards Nick.
br24/07/2021 12:23:35
697 forum posts
Posted by Rob McSweeney on 24/07/2021 11:39:58:
Pansy 0-6 0 G W R Pannier tank in 5 inch gauge.
Wheel casting is available from Reeves at about £36.
bill
Derek Lane24/07/2021 14:11:50
507 forum posts
95 photos
I like the comment at the bottom of the ad
"Condition is "Used" but like new. As far as I can work out it has never seen daylight!"
Mark Rand24/07/2021 17:48:09
1055 forum posts
12 photos
Probably why it got dropped then, someone tripped over with it in the dark.
BOB BLACKSHAW24/07/2021 18:48:07
425 forum posts
104 photos
Last comment made me laugh.
Brian H24/07/2021 20:03:08
2214 forum posts
113 photos
It would be a shame to spend time and money on the repair only to find more damage afterwards.
old mart24/07/2021 20:42:17
3316 forum posts
203 photos
If I was listing it, I would be honest and say that it could be repaired by an expert.
JD Metals
rapid Direct
walker midge
Dreweatts
