New Chuck won’t screw on
Richard Jarvis21/07/2021 16:50:43
25 forum posts
6 photos
I decided to fit a new Chuck to my ml7, being a relative newcomer to precision work I opted for the easy way of purchasing a Chuck complete with fitted backplate. Well it will only screw on half a turn, told supplier only to be told that they are machined on a myford and then checked on two other spindles to check fit. When looking at the thread on my backplate you can see a full turn of the thread before it is fully formed, but on the new one the full thread is formed at just over half a turn. If anything I would have thought my spindle thread would be worn not larger than original, any thoughts please.
Thanks Richard
Ian Parkin21/07/2021 17:13:46
973 forum posts
231 photos
Richard
do you have thread gauges to check that your new backplate has the same tpi as your spindle?
if not a piece of blutack or plasticene on your finger will make an impression so you can check against your spindle
Edited By Ian Parkin on 21/07/2021 17:16:25
Tony Pratt 121/07/2021 17:14:09
1648 forum posts
8 photos
A picture paints a thousand words. In the meantime check both threads are completely clean.
Tony
Harry Wilkes21/07/2021 17:18:20
1166 forum posts
64 photos
Hi Richard firstly may I say I've purchased two back plates from different companies and neither have screwed on my S7, what would help members to advise you would be a photo if possible and in the meantime make sure the thread on your ML7 is clean and undamaged also would you like to tell us the company who supplied your chuck.
H
Richard Jarvis21/07/2021 17:37:03
25 forum posts
6 photos
I am trying to post two pictures and a video of me trying to screw on the Chuck but am struggling, just reading the info on posting pics. I have done the thread impression and it seem to be the same tpi but I don’t think it’s cut deep enough.
Edited By Richard Jarvis on 21/07/2021 17:46:27
Richard Jarvis21/07/2021 18:05:43
25 forum posts
6 photos
7560fbfb-f111-43ca-bbe9-ac026cd0f81b.jpegRight it says file for video too big, but I managed to do pictures, I have marked the start of thread with pen it starts at 12 o’clock position and my chuck is a full turn to form the thread whereas new chuck seems to have it formed just after half a turn. The way I have written that is not very clear hopefully you can decipher my poor explanation. I have managed to post the same picture twice but I can’t see how to delete the second copy.ac21575e-8dde-404e-a37d-05c7fbf059cb.jpegac21575e-8dde-404e-a37d-05c7fbf059cb.jpeg
Edited By Richard Jarvis on 21/07/2021 18:07:17
bernard towers21/07/2021 18:24:17
275 forum posts
82 photos
All backplates that I have bought from non genuine suppliers have needed work!!!
Richard Jarvis21/07/2021 18:35:18
25 forum posts
6 photos
e25aee9f-5063-4cbb-8f17-1bc0fdda111f.jpegThe Chuck on the left is the new one, the first thread is nearly square but on my old one on the right it seems to be formed correctly or does that not matter. I found a thread gauge and they both read at 12 tpi but I am sure the gauge hits the top of the threads on the new chuck but I think the gauge has a small gap between it and the top of the thread on the old one, I think the thread is not deep enough.Thanks Richard
Edited By Richard Jarvis on 21/07/2021 18:40:14
Edited By Richard Jarvis on 21/07/2021 18:42:43
Richard Jarvis21/07/2021 18:45:30
25 forum posts
6 photos
You will all be getting fed up with me now, only one picture downloaded, here goes this is the new Chuck.
Richard Jarvis21/07/2021 19:05:38
25 forum posts
6 photos
Posted by bernard towers on 21/07/2021 18:24:17:
Without mentioning where it came from, they should know how to make the backplate fit a myford.
Maurice Taylor21/07/2021 19:40:29
196 forum posts
32 photos
Hi ,I had the same problem with a backplate for an ML7, I bought a tap ,tapped the hole and backplate went on ok by hand
Maurice
Flywheel21/07/2021 19:48:48
31 forum posts
Richard, check your inbox I have sent you a message
Peter
Harry Wilkes21/07/2021 21:07:21
1166 forum posts
64 photos
Posted by Maurice Taylor on 21/07/2021 19:40:29:
Maurice
Snap that's what I did with the one's for my S7
H
not done it yet21/07/2021 21:54:45
6279 forum posts
20 photos
I think you need to speak with a supervisor, rather than the ‘phone answerer’, for a more sensible response to a customer problem with their product.
Steviegtr21/07/2021 21:55:14
2225 forum posts
311 photos
I have a new plate somewhere that will not go on more than a couple of threads. Best of luck getting it sorted out.
Steve.
duncan webster21/07/2021 22:23:29
3456 forum posts
63 photos
Posted by Richard Jarvis on 21/07/2021 16:50:43:
........., told supplier only to be told that they are machined on a myford and then checked on two other spindles to check fit. .........
Thanks Richard
If I were making backplates for a living I'd use something more 'industrial' than a Myford. Don't get me wrong I'm on my second, but only as a hobby
Not that this helps, but the backplate I bought from RDG/Myford fits lovely. If you divulge your approximate location there might be another Myford owner near you and you could try it on their machine. With a bit of care you can do this Covid secure
Edited By duncan webster on 21/07/2021 22:23:50
Edited By duncan webster on 21/07/2021 22:24:25
Richard Jarvis21/07/2021 22:34:18
25 forum posts
6 photos
This seems to be a common fault, I sent them some pictures earlier so I will see what tomorrow brings. Thank you for the replies.
Richard.
Richard Jarvis21/07/2021 22:46:20
25 forum posts
6 photos
Posted by duncan webster on 21/07/2021 22:23:29:
Thanks Richard
Thanks I’m in Orkney, I did not realise that was not shown. I have tried two face plates and a spindle nut from an Amollco mill so am sure it’s not my spindle at fault because they all fit ok.
Richard.
Howard Lewis22/07/2021 09:30:27
5237 forum posts
13 photos
Maybe the thread needs to be truncated by a couple of thou, to prevent root / crest interference?
Put a substantial bar into an existing chuck.
Skim to obtain a concentric diameter.
Clamp the new chuck to the bar.
If the chuck on the mandrel is a 4 jaw, clock the register of the new chuck and centre as accurately as possible..
Skim the thread of the new chuck, to take out just a thou or so.
With a thread depth of 0.053", the core diameter should be 1.019", so you are looking to enlarge the ID of the thread to about 1.022 / 1.023.
Possibly, before you start work on the new chuck, turn up a piece of bar to 1.022/3" to use as a plug gauge.
Hopefully, the truncated thread will allow the chuck to screw fully onto the mandrel.
Howard  WHY do I only spot the typos after posting?
Edited By Howard Lewis on 22/07/2021 09:31:40
Michael Gilligan22/07/2021 09:41:27
18734 forum posts
916 photos
told supplier only to be told that they are machined on a myford and then checked on two other spindles to check fit. …
That’s the disappointing bit ^^^
Supplier needs to understand GO/NOGO gauging
Dreweatts
rapid Direct
walker midge
JD Metals
