Can auto darkening welding helmet capsule be restored.
Windy16/07/2021 20:35:37
871 forum posts
185 photos
Can auto darkening welding helmets capsule be restored..
After some years decided to practice Aluminium Tig welding today.
I have a Parweld helmet that is as new I hardly used as not fine enough for low amp welding that I was doing on my flash steam stainless generators.
Also a SWP that was great for welding with a few amps.
The auto capsules are not working any chance they can be made working again.
Did get an odd darkening but very rare..
They both are hardly used I know there are some cheap solar ones on Ebay.
If I can repair them easily would prefer to do that..
Edited By Windy on 16/07/2021 20:37:40
Andrew Johnston16/07/2021 20:52:13
6235 forum posts
676 photos
Flat batteries?
Joseph Noci 116/07/2021 21:01:20
987 forum posts
1247 photos
As Andrew said, probably the batteries, and most of these cheap helmets don't allow easy battery replacement - I had two such and did cut open the module - there were two lithium cells, in series, with the center tap also connected so seems like it used a split supply. Did that about 7 months ago, and this weekend the helmet is playing up again..
This helmet also has small PV panels, but as I don't do much welding, the helmet sits in a box so no sunlight and no welding UV and it appears the quiescent current is not insignificant.
I again replaced the batteries, but with two D Cells, duct taped to the top of the helmet..
Joe
peak416/07/2021 21:21:50
1469 forum posts
159 photos
If your local store has any left, Lidl had some on offer recently, which may work out easier.
I've not tried them, so I don't know the quality
Bill
Windy16/07/2021 22:54:52
871 forum posts
185 photos
Have jumped the gun the parweld has mainly been in its box for ten years its manual says the built in battery will only last 6 years.
After being in the light all day its working again.
The 10 year old SWP has started working again after leaving near when I practiced a few hours ally Tig welding.
Dave Halford17/07/2021 16:10:21
1671 forum posts
19 photos
The SIP basic £40 one has a grinding option which switches the battery off. The battery is a CR3032 car key fob type. If it sees welding flash it still darkens.
Jim Smith 817/07/2021 17:06:40
29 forum posts
8 photos
It will be the batteries. I had 2 Chinese that went the same way. The first had a draw for an AAA cell but the cell had been in too long and I had to clean up the terminals. The second had a coin cell battery inside which I replaced and neither helmet is now going to land fill.
During the helmet recovery process I discovered in addition to the electronic auto shut off, my darkening control knob had a switch on the end and when off, nothing drains the battery. I now remember to turn it to the off position.
Andy_G17/07/2021 19:34:31
133 forum posts
Posted by Windy on 16/07/2021 20:35:37:
If they are the type with the small solar cells on the front, I believe they can sometimes be 'kick started' by leaving them in the sun for a few hours.
I have one of the cheap supermarket ones (Aldi, I think) with 2 arc sensors and while it is/was fine for stick welding, it wouldn't reliably stay dark with low-ish amp TIG. (A relatively inexpensive 'Tacklife' branded one with 4 arc sensors did work OK, however.)
Dave Halford17/07/2021 20:23:16
1671 forum posts
19 photos
Posted by Jim Smith 8 on 17/07/2021 17:06:40:
Otherwise known as grinding mode smiley
JD Metals
rapid Direct
walker midge
Dreweatts
