Robin | 12/07/2021 11:59:12 |
![]() 592 forum posts | Did I really just buy a set of M1 involute gear cutters for £34.49 on offer from Amazon with free shipping and delivery in 3 weeks? Perhaps I imagined it. I couldn't help myself. It was an involuntary burst of mouse clicking and all over before I knew what was happening. I mean, what's the worst that can happen? 8Pcs Involute Gear Milling Cutter High Speed Steel Cutting Tools Set Machine Tool Accessories 14.5° Pressure Angle 55mm 22mm |
JasonB | 12/07/2021 12:16:15 |
![]() Moderator 23088 forum posts 2774 photos 1 articles | I bought some similar very cheap ones and found they wear quite quickly, OK for a couple of gears but could see the finish going off after that. I hope they are MOD1 as your image shows 16DP which is close but not MOD1 and the 14.5pa is not usual on MOD cutters. No mention of MOD or DP on Amazon either Edited By JasonB on 12/07/2021 12:17:18 |
Robin | 12/07/2021 12:26:34 |
![]() 592 forum posts | I shall hope for 16DP then, sounds better than MOD1 already. What material were you cutting to blunt HSS? Do you think they might be high carbon steel dressed up as lamb? |
JasonB | 12/07/2021 12:32:32 |
![]() Moderator 23088 forum posts 2774 photos 1 articles | EN1A on the smaller gears, Larger one was more likely EN3, blunted a lot faster than say the £20 ea RDG ones. Think they were MOD0.5 and about £5 each |
Emgee | 12/07/2021 13:33:42 |
2446 forum posts 291 photos | Robin If you had looked a bit deeper they are even cheaper, MOD1 and MOD.5 Emgee
Robin | 12/07/2021 14:18:57 |
![]() 592 forum posts | So many things to buy and my mill in pieces, whatever next? |
Robin | 12/07/2021 14:38:18 |
![]() 592 forum posts | Posted by JasonB on 12/07/2021 12:32:32:
EN1A on the smaller gears, Larger one was more likely EN3, blunted a lot faster than say the £20 ea RDG ones. Think they were MOD0.5 and about £5 each My goodness, your gear pictures make me even more determined to cut involute teeth. What is wrong with me? |
