Garmin sat nav
duncan webster10/07/2021 23:05:08
3711 forum posts
69 photos
I think the battery in mine is kaput, if left unplugged for any length of time it would then take a very long time to recover and switch back on. I brought it in and left it plugged in to a USB port on my computer. It recognises that this is not the car as it has data lines (they are connected with resistors in the car charger). Whilst plugged into the computer USB it displays a message to say so. Now even if I unplug it that message stays on, even plugged into the car, and even more strangely the on/off button doesn't have any effect.
I've tried connecting it to the Garmin software on the computer, doesn't recognise it
Unless someone has a bright idea it looks like a hand in pocket job. I'm not impressed, it's not that old (out of warranty)
Ady110/07/2021 23:19:30
4911 forum posts
726 photos
Just did my 10 y.o. Navman s70
1 Find someone who did it on utube
2 buy one from ebay
3 revisit utube
damned annoying is a total doddle because of utube
They can behave pretty strangely when the battery is totally gone, even if you try to run them from the usb link
cost a tenner
Edited By Ady1 on 10/07/2021 23:25:24
Chris Crew10/07/2021 23:33:01
179 forum posts
I had a not so dissimilar problem with a Tom Tom, approximately 7 years old. For no apparent reason the screen suddenly would not function upon being switched on the first time, but after several attempts and resets it would appear and then function normally. The number of resets then began to increase until I thought it may be an internal connection not making good contact. A YouTube video showed how to dismantle the device, an operation which I performed and re-seated and cleaned all the connectors, especially the ribbon to the display. All to no avail, the device malfunctioned exactly as before.
As Tom Tom had been bombarding me with 'promotions' and discounts for the last couple of years in an attempt to get me to purchase another device, I strongly suspect that these devices are programmed to self-destruct after a set period of time, rather like Apple slowing down the functions of their mobile phones as reported a while back.
I gave up in the end and disposed of the device in the electronic waste bin at the local tip and now just use the integral sat-nav of my car, but as car sat-navs do not come with regular free map upgrades it is a little out of date. Maybe I can use my phone's navigation facility or even go back to the old AA road atlas that got me to everywhere I ever wanted to go in the course of my itinerant employment in the days before reliance on electronic devices became the norm. I wonder if many other people have had similar experiences?
duncan webster10/07/2021 23:39:59
3711 forum posts
69 photos
Ok I've bought one, just concerned at its odd behaviour
Ady110/07/2021 23:40:03
4911 forum posts
726 photos
I found mine useful for public roads in the middle of nowhere, some of which run right through farmyards and look like a private road
My own street has a public road to the garages at the bottom, but the garages to the right are private land even though its all the same to look at, the satnav only shows the legal public road
I think some routes were publicly funded on otherwise private land but a condition of this asset to be built was to allow public access
2cents
Edited By Ady1 on 10/07/2021 23:44:22
Steviegtr10/07/2021 23:43:20
2320 forum posts
317 photos
1st comment would be , if you are sure it's the battery .Strip it & change the battery, not too hard to do. If you give up completely then use google maps on your phone. Google maps is way ahead of most of the sat nav data. Even tells you of road blockages etc, being live data. I have a Garmin Zumo on my motorcycle. The water proof version. It's ok but every now & then it looses it's marbles & does not know the road i am on, or the speed limit of said road.
The one in my expensive Jag is not as good as the phone google version.
Steve.
Calum Galleitch11/07/2021 00:32:09
111 forum posts
27 photos
As per Steve, I have never used a satnav unit, built in or separate, that was better than my phone's Google Maps app. I have a little phone mount and cigarette lighter to USB adapter that keeps it running on long journeys, though in fact I tend to only end up using it for 'last mile' directions most of the time.
Ady111/07/2021 00:53:07
4911 forum posts
726 photos
I found my phone too fiddly, too many options, too many wrong button presses too much weird stuff
You can use a satnav on the move
The phone was fine just as long as you didn't need to touch the screen
Peter Greene 🇨🇦11/07/2021 01:26:02
356 forum posts
4 photos
Posted by Chris Crew on 10/07/2021 23:33:01:
...... as car sat-navs do not come with regular free map upgrades it is a little out of date.
Doesn't the car dealership do that during a regular service .... or on request?
not done it yet11/07/2021 07:41:34
6520 forum posts
20 photos
First time ever, last week, my wife’s Garmin suddenly showed a pic of a PC with a connection to the sat nav. It would not do anything, even switch off (battery was poor as it normally switches off only a few seconds after power disconnection).
I found that the ‘net had a ‘fix’ for some fault and tried it, although the screen did not have the item showing to press.
I pressed both the on-off button and the right side bottom corner of the screen simultaneously and it turned off. Got it working adequately, to drive to Somerset, then it failed again, so had to follow the M5 to get to Slimbridge (terrible congestion all the way!).
We left the motorway at the earliest opportunity (Tewkesbury exit) and followed directions on her mobile phone until the route was obvious.
Ady111/07/2021 07:43:52
4911 forum posts
726 photos
The best thing of all is you never need any internet to make a satnav work
There was about 24 sats originally but I think a couple are a bit dodgy and the originals are all coming to the end of their service life over the next decade
...so one day your old satnav will simply stop working...
brian roberts 211/07/2021 08:22:50
21 forum posts
6 photos
Duncan's original post mentioned a possible flat battery, which may not be easily charged in the usual way. This is because Lithium ion batteries have tightly-controlled voltage limits to prevent overcharging, but they also do not permit recovery of a fully discharged battery.
I have managed to overcome this on some appliances by opening the item and disconnecting one leg of the battery to isolate it from the control circuitry. Then I connected a higher voltage battery across the failed battery for a few seconds to partially charge it, eg use a 12V batt. to charge a failed 7V battery.
This action lifts the failed battery voltage over the threshold sufficiently for the control circuitry to recognise that it is still viable and normal charging is then usually successful.
It's worth a try before binning things.
Chris Crew11/07/2021 08:37:53
179 forum posts
Posted by Peter Greene on 11/07/2021 01:26:02:
Peter, the maps as far as I am aware are held on a removable memory chip (SD card?) and I have been told that an updated replacement would be a couple of hundred quid. The car is a Volvo V90 D5 on a 17 plate which I have had for two years and the Volvo dealership has done a couple of Volvo software updates and replaced a part under the warranty at the service intervals, but nothing to the sat-nav. I bought my wife a Volvo XC60 B4 on a 20 plate and it has a newer map, obviously, but I am not expecting its sat-nav to be updated either although I will ask again when it is due for a service.
For someone who used to think nothing of stripping engines and gearboxes down to get re-bores done and crankshafts re-ground etc. it came a little hard to me when I had to read the manual to find out how to open the bonnet just to fill the washer bottle!
Edited By Chris Crew on 11/07/2021 08:39:46
John Haine11/07/2021 10:10:13
4435 forum posts
265 photos
Posted by Ady1 on 11/07/2021 07:43:52:
Unlikely as there are 29 in orbit as of 2020, 4 or 5 of which are "spares". Given that GPS and other systems have become essential infrastructure for navigation, positioning, and precision time & frequency distribution globally I can't see that the system would be allowed to degrade. Also it depends on what you mean by "old" - for several years GNSS receivers have been multi-standard and able to derive time & position from GPS, GLONASS, Galileo, and BeiDou.
Samsaranda11/07/2021 11:27:20
1307 forum posts
5 photos
I always thought that the primary purpose of the satellite navigation system was for the guidance of nuclear bombers and cruise missiles, the civilian use is coincidental. Anyways I had reason to use my garmin sat nav the other day, the sat nav is I don’t know how many years old, it acted very strangely when turned on, bearing in mind it must be at least two years since last used and it is was plugged into the car electrics, it seemed to take forever to settle down and when it did it seemed to think I was at various different points in the country trying to start my journey. Eventually once the car was moving it seemed to find its bearings and worked ok for the rest of the journey, I don’t think mine has ever been upgraded so working on the original maps. Keep threatening to purchase a new one but whilst I can coax the old one to keep working expenditure is delayed. Dave W
Nicholas Farr11/07/2021 11:28:05
3154 forum posts
1435 photos
Hi, I have two Garman sat nav's, one is older than the other neither of which charge very fast via a computer USB port. The older one I used to keep at work, so I always had it if and when I was sent on site to unknown areas. Both of these have lifetime map updates which you have to do three or four times each year to keep the lifetime going and if you don't update to the minimum requirement, the lifetime aspect is deemed to have come to an end and they will no longer update, The other thing is, that new versions of the update app are required and the app won't recognize the sat nav's until the app is updated, I also have to launch the app, then click on which sat nav I wish to update before plugging it into the computer and it the battery is down, I'll charge it up with a phone charger rather than my computer. I don't think many sat nav batteries have a very big capacity as I think they are only meant for keeping a selected route, should you make a stop for refreshments and that is why they go to auto shutoff when disconnected from a power source.
Regards Nick.
Vic11/07/2021 11:30:39
3017 forum posts
8 photos
The battery on my Garmin isn’t very good either. I bought one of their chargers to use indoors from time to time.
I would have liked it in my car but it was an additional £600. I’ve got a fairly decent iPhone though so I can use that if needed.
duncan webster11/07/2021 11:49:26
3711 forum posts
69 photos
The main purpose of a sat nav is to avoid nuclear war in the car. SWMBO is incapable of {or unwilling to} read a map whilst the car is moving. Her best performance was to announce I'd have to stop and read the map whilst we were on the Peripherique, the Paris inner ring road. This makes the M25 look like a country lane. I'll let you know how the battery upgrade goes.
noel shelley11/07/2021 11:57:26
1022 forum posts
19 photos
I found my old NAVMAN far clearer in the way it portrayed the map, far better than TOMTOM. Map updates expensive. The FURUNO marine set I use started to play up and we were told that the soft wear was date limited and the set would die soon as a new version came on stream - just buy a new one !!!! If a set is powered down for a while( or taken to a distant location whilst off) it may loose it's almanac, this will take some time to re establish and get a good fix. I always check the number of satelites being used for an initial fix. Noel.
Bob Mc11/07/2021 18:39:02
205 forum posts
26 photos
It seems to me that this satnav service is a big problem, I had a car with satnav and although the maps were becoming out of date, I didn't update the version as I was about to get a much newer car.
I was told by the salesman that the car being the same model but newer was identical to the old one, and I did a calibrated tyre kick test... and sure enough on the dashboard screen there was an icon for navigation. After going through the trauma of parting with a few thousand pounds I collected aforementioned vehicle and went off quite happily... a few days later I thought to try out the navigation ... surprise surprise! there was no on board satnav device, I spoke to the salesman.... " you need a smartphone...everyone has a smartphone" .... "no they don't" I says... I ain't got one! ... its like me....its not smart enough to realise that I should take no notice of car salesmen.
"anyway...he says..its dead easy to get the phone to display the navigation map on the screen... no problem at all"
The fact is I need a larger screen to view the maps, and I don't want something hanging off the dashboard which I have to take off every time I park up, as has been said, the mobile phone icon buttons are too fiddly to mess about with.
So I obtained a smartphone to try it out, the dashboard screen informs me that I need to have the correct app for the service... but no indication of what this is... I trawled the manufacturers websites and went round in circles for a few hours eventually ending up speaking on a chat line..
A very nice lady who informs me that the car needs its software updating..."can I do it online" I says...."no" she says...you have to take it in for that service....."will it cost me" I says...."yes" she says.... so basically I have bought a smartphone and now will have to pay to have what should have been in the car in the first place...!
Its all a load of Old B********ks
MIDLNDS GARDEN RAIL Jan 2022
JD Metals
rapid Direct
