Cleaning Circuit board - Replacing NiCad Batteries
Colin Heseltine10/07/2021 10:35:39
654 forum posts
227 photos
I have an underwater strobe light which is no longer holding charge and wish to change the batteries. It is fitted with 6 off 1.2v 2200mAh tagged batteries giving a 7.2V supply.
Having opened the battery pack I can see couple of the batteries have started to weep. The other problem is the printed circuit switch has corrosion on its tracks. What is the best way to clean this corrosion of the board and its corresponding rotating connector.
Any recommendations for procedures to follow when changing the batteries.
Thanks,
Colin
Martin Kyte10/07/2021 10:51:26
2721 forum posts
48 photos
RS used to do fibreglass scratch pens for track cleaning. Garry blocks also are a help.
Is this a photography strobe or come and find me if I am in trouble beacon. If the latter get a new one.
regards Martin
Grindstone Cowboy10/07/2021 11:13:21
854 forum posts
64 photos
Battery corrosion can be dealt with by wiping with vinegar, cleaning the vinegar off with water, then isopropyl alcohol to dry it all up. In the absence of a fibreglass pen or Garryflex block, you can use the ink end of an eraser (do they even do those two-coloured ones these days?).
Rob
Colin Heseltine10/07/2021 11:38:10
654 forum posts
227 photos
Martin,
It is a photography strobe.
Colin
Robert Atkinson 210/07/2021 11:50:25
1195 forum posts
20 photos
Nothing special to do when changing th cells as lon as you use tagged ones. Give the tags a rub with emory paper or garry block to break the oxide befor soldering and don't overheat them.
After you have cleaned the contacts lubricate them with a smear of vaselene. DON'T use the divers favorite, silicon grease, any arcing will turn it into silicon dioxide (glass) and ruin the contacts.
Robert G8RPI.
Paul Lousick10/07/2021 11:52:49
2013 forum posts
711 photos
Faber Castell still make fibreglass erasor pens which I used to used many moons ago when I was a draftsman on a drawing board. Used to use them for modifying ink drawings. Still remember getting itchy hands after brushing the broken fibres with my hand.
Paul.
not done it yet10/07/2021 11:56:51
6733 forum posts
20 photos
I would think that a change of battery chemistry might be prudent? Cadmium is on the ‘naughty list’ and just two lithium cells would suffice (with a decent battery management system - which would likely be at the cell level). Nickel metal hydride might also be an alternative.
peak410/07/2021 16:23:44
1674 forum posts
175 photos
If you have a fast charger, please make sure the cells you select are capable of accepting that maximum charge rate.
A few years ago I replaced a couple of duff cells in a Skill battery pack (with Maplin cells of the same capacity, and claimed charge rate).
Everything worked fine for several recharges.
One day I pressed the Fast Charge button and wandered downstairs to make a brew.
A little while later there was an exceedingly loud bang from the bedroom.
One of the new cells had expanded and blown the end out. The insides followed leaving a spring like Zeberdee.
The adjacent cell was blown straight through the plastic case, and made a sizeable dent in the bedroom ceiling.
Bill
Dave Daniels10/07/2021 17:09:14
83 forum posts
CPC stock fibreglass cleaning pens.
https://cpc.farnell.com/c/tools-maintenance/cleaning-chemicals/precision-cleaning/fibreglass-pens?searchref=searchlookahead
D.
Dave Halford10/07/2021 17:42:37
2006 forum posts
23 photos
Replace the negative wires, black wire corrosion wont go away.
Buy good cells with a long date
Dreweatts
Rapid RC
