Help to identify Lathe
James Hendry 101/07/2021 17:36:23
2 forum posts
4 photos
lathe 2.jpgHello
Looking for some help , can anyone identify this lathe ' obviously very old as it has been 'Foot Powered' in the past . Any ideas of Manufacturer and year of manufacture , any idea if I can get any literature on it. Many Thanks Jim
Brian Wood01/07/2021 18:24:06
2549 forum posts
39 photos
Hello James,
My guess is a Drummond. There are plenty of owners who will give you a better opinion and you will get a lot more information from the Drummond entry on Tony Griffith's superb archive website----www.lathes.co.uk
Keith Long01/07/2021 18:38:29
877 forum posts
11 photos
Yep, Drummond M type.
For a LOT of info try the "drummondlathe@groups.io".
Once you've become a "member" you can access the files and you'll find a load of information about all of the Drummond manufactured lathes. As a "non-member" you should still be able to see the topics under discussion and get a feel for the depth of knowledge, friendliness and helpfulness of the rest of the group.
Keith
Ady101/07/2021 19:24:34
5066 forum posts
734 photos
Drummond M. Solid as a rock. Loads of people still use them and lots of info about on the net
James Hendry 101/07/2021 21:30:59
2 forum posts
4 photos
Thanks for info guys , yes Drummond M Type , I have now downloaded plenty reading material
Thanks again
Jim
Howard Lewis01/07/2021 21:40:53
6021 forum posts
14 photos
Have never owned one, but know that there are folk who do good work on them
(An ex work colleague boughtb one for £10 as "surplus to requirements" from our R & D area. I just wish that i could produce the sort of work that he does with it, dwpite being at least a hundred years old. (Drummond Lathe not colleague )
You have the potential for Years of pleasure and useful work.
Enjoy!
Pete Rimmer02/07/2021 06:40:49
1219 forum posts
63 photos
Drummond M as said but whomever had it in that corner didn't use it there. You need good access to the end gears which are fiddly enough to swap about but stuck against the wall like that would be very frustrating.
Nicholas Farr02/07/2021 09:57:32
3312 forum posts
1529 photos
Hi, I would swap that on / off switch with a NVR start / stop before I use it, if it were mine.
Regards Nick.
Dave Halford02/07/2021 21:05:37
2007 forum posts
23 photos
You can get a simple non latch RCD that fulfills the NVR duty for small motors and still keep the handy on/off switch
Nicholas Farr02/07/2021 22:17:24
3312 forum posts
1529 photos
Hi, Dave, one of those non latch RCD's would suffice in the event of a power cut but apart from the switch and the wiring looking untidy and a potential safety hazard, a proper start / stop e.g. similar to NVR Switch will include an easy to reach and knock off, emergency stop button.
Regards Nick.
David George 103/07/2021 22:46:19
1808 forum posts
503 photos
Hi James. have a look on here. https://groups.io/g/drummondlathe there is loads of help and information on there. Join and look in the files section.
David
Lee Rogers04/07/2021 09:13:58
166 forum posts
Very early Drummond M Type . Belt drive is the give away.
Rob McSweeney05/07/2021 09:05:31
73 forum posts
If you do Facebook , there is also a Drummond?Myford group on there, which is more active than groups.io, and much easier to post photos to
Dreweatts
Rapid RC
