Organising M.E. index spreadsheet
steamdave30/06/2021 12:34:27
521 forum posts
45 photos
Is it possible to organise Excel into ascending or descending order across all columns?
I particularly would like to reorganise the Model Engineer index Excel spreadsheet to show contributors in alphabetical order with their contributions. This would make it easier to search for particular articles.
I can sort and filter Authors in alphabetical order but the remaining columns are not sorted using the Sort & Filter button.
The Emerald Isle
DC31k30/06/2021 12:57:07
725 forum posts
https://support.microsoft.com/en-us/office/sort-data-in-a-table-77b781bf-5074-41b0-897a-dc37d4515f27
Your question starts at sub-section number 3.
Bizibilder30/06/2021 12:57:52
125 forum posts
7 photos
Highlight the entire sheet and then use custom sort to sort on the column you require - the whole sheet will be sorted.
Calum Galleitch30/06/2021 13:07:55
194 forum posts
65 photos
Dave, if you highlight the entire table before turning on the sort/filter tool (or off and on again), it should keep all the rows in order. Let me know if you're struggling and I'll see if I can sort it out for you.
Paul Lousick30/06/2021 13:12:01
2071 forum posts
725 photos
Make a copy and use it for sorting columns. Unlike a database (MS Access, etc) the data in the columns for each record is not linked together and easy to mix them up and ruin the file.
Edited By Paul Lousick on 30/06/2021 13:13:18
steamdave30/06/2021 16:32:00
521 forum posts
45 photos
Thanks gents for your help. All sorted now.
The Emerald Isle
John Haine30/06/2021 16:58:54
4712 forum posts
273 photos
You have probably seen this now, but if, having sorted, you click on the little down arrow next to the column head it gives you a list of all the contents in that column with a tick box. If you untick them all by clicking on the "select all" box then click the (say author) you want it will show you just the relevant entries.
Dreweatts
Rapid RC
