Dressing / Truing a resin diamond wheel
Dave S29/06/2021 09:45:44
195 forum posts
41 photos
Morning all,
Im still building my tool grinder, but I have enough bits to do a few trial grinds to make sure that all the various angles and such work ok.
I have an alloy bodied resin diamond wheel that I am using - you can see it in this photo:
I have had it for a while, and it’s been used on the previous iterations of this grinder.
As a result the face isn’t flat anymore.
What do I use to dress / make flat again?
I have single mounted diamond for my Surface Grinder, a number of scrap alox wheels, and a norbide dressing stick.
Chris Evans 629/06/2021 09:58:45
1950 forum posts
I have never properly dressed the face of a cup wheel like that due to lack of the correct kit. What I do with mine is "Lap" the face on a criss/crossed cast iron lapping plate with a drop of paraffin. Worn faces can be restored quickly if not allowed to get to bad. No doubt people who used the correct method will be horrified.
John P29/06/2021 10:01:51
314 forum posts
212 photos
Try these
https://www.youtube.com/watch?v=W5W1_96lOuM
https://www.arceurotrade.co.uk/projects/d_wheels/dwdoc2.html
Or Google dressing resin diamond wheels plenty of options
David George 130/06/2021 13:56:56
1634 forum posts
492 photos
Hi Dave there is an attachment to true diamond wheels. It is a small spindle with a soft grinding wheel which when brought in to contact with the wheel has an inbuilt brake to slow it and it trues the wheel.
rapid Direct
Dreweatts
JD Metals
walker midge
