Fractal vice
norman valentine26/06/2021 10:51:19
280 forum posts
40 photos
I came across this on youtube. The chap did a complete restoration which dd708c32-2422-47ae-8846-2cf5981030ec.jpegincluded making a replacement jaw to replace one that was missing. d3271766-3dcf-4680-a48a-d644a56cdb7f.jpeg
ega26/06/2021 11:10:06
2242 forum posts
186 photos
Is this wonderful vice design actually based on fractal geometry?
There is a degree of self-replication in the jaws. What was the state of fractal science at the date of the patent? Mandelbrot came along later, I think.
Clive Foster26/06/2021 11:48:01
2817 forum posts
101 photos
Fractal refers to replication of identical elements in ever smaller sizes starting from a single base shape.
All the pivoting arrangements of the vice segments are the same shape. Each little segment moves independently, as each larger segment does, so the vice jaws are true fractal! 2 to the 4th power.
Mandelbrot basically formalised the mathematics to establish the general solution and demonstrate the capability of infinite expansion.
Infinite replication of ever smaller elements doesn't actually have to refer to identical shapes but the maths is more than a little challenging rendering the concept pretty much impractical in an analytical sense.
Calum Galleitch26/06/2021 14:38:50
96 forum posts
27 photos
The term 'fractal' was first used by mathematicians to explore the idea that between the common concepts of one, two, and three dimensional spaces, there could be other, in-between fractal dimensions. This gives rise to things like shapes with infinite perimeters yet finite area, or bounded lines of infinite length. Self-similarity isn't a necessary condition, but it's easy to come up with rules to create fractals that are self-similar and mathematically tractable. Discovering non-similar fractals is a trickier enterprise. It turns out that generalising the concept of 'fractal' to a usable, precise mathematical definition isn't especially useful, so nowadays fractal is more of "I know it when I see it" term.
Jon Lawes26/06/2021 14:52:41
636 forum posts
What a fantastic piece of equipment, whatever it is called. I wish they still sold them as I haven't a hope in hell of making one!
Jeff Dayman26/06/2021 14:55:07
2166 forum posts
45 photos
Does it matter what it is called? It's a clever design, and well made. Could be very useful in some circumstances.
Frances IoM26/06/2021 14:57:07
1154 forum posts
28 photos
looks an ideal task to make use of 'parametric instantiation' - (see a prev thread complaining such a term had no place in Model Engineering) followed by CNC machining
Nigel Bennett26/06/2021 14:59:36
413 forum posts
11 photos
One thing that did please me in his very interesting YouTube video - his use of Sheffield-made Eclipse Vee blocks when drilling a hole at one point.
Amazing vice, though - and a lot of precision needed to make it in 1913. What would it cost to make it today?
Bazyle26/06/2021 15:59:13
6010 forum posts
220 photos
Certainly something to consider for 3D printing - to be lazy about it.
Meanwhile a simpler version might be a rectangular (smallest) jaw with a pivot like a seesaw on its side, (two off) mounted on the end of a bigger seesaw etc.
Will one of the CAD gurus have the design out before I can finish typing?
Peter Greene23/07/2021 19:28:33
272 forum posts
This 3D Printed Version at Thingiverse might be of interest.
Rod Renshaw23/07/2021 19:54:21
301 forum posts
Fantastic vice!
I wonder if they could be made today using CNC setups to keep the cost down compared to the hand fitting methods presumably needed for the original. Potentially small market though I suppose.
The Swedish firm SEVO make or made a much simpler version which seems to work reasonably well.
Rod
Brian G23/07/2021 20:27:04
777 forum posts
34 photos
There is another vice rebuild on YouTube featuring similarly adaptive gripping, this Ampogrip vice that uses ball bearings as a hydraulic fluid.
Ampogrip Vise Rehab
Journeyman24/07/2021 08:30:10
1021 forum posts
192 photos
For light work you could print this one from Thingiverse
3D Printed Fractal  Vice
Edit: Oops, missed Peter's post above.
Edited By Journeyman on 24/07/2021 08:59:16
Ady124/07/2021 09:18:24
4689 forum posts
713 photos
Looks brilliant in theory but with so many moving parts it's going to be a bit wonky after a bit of use
David Colwill24/07/2021 09:46:37
763 forum posts
40 photos
Question.
What does the "B" in Benoir B Mandlebrot stand for?
Answer Benoir B Mandlebrot.
I'll get me hat!
walker midge
Dreweatts
JD Metals
rapid Direct
