Gamage's Steam Engine
Details sought
JasonB21/06/2021 18:57:24
21315 forum posts
2419 photos
A bit of a long shot but I wonder if anyone has one of these engines or another image as I'd like to see it from the other side to see what the bearing and eccentric arrangement is rather that take a guess at it based on other similar models.
Thanks J.
br21/06/2021 19:33:26
697 forum posts
Jason
As a member, the USA Office of steam forum would be worth posting on as there are collectors on there with this area of interest.
PM of other sources in UK to be sent shortly
bill
michael potts23/06/2021 21:06:10
40 forum posts
This is a rather poorly NDC belonging to my son, the eccentric sheave is part of the crank disc.
Regards. Mike.
Edited By michael potts on 23/06/2021 21:07:14
br23/06/2021 21:20:16
697 forum posts
Good to see the pictures Michael Never seen an eccentric like that befor, and nice to know one exsists,.
bill
PS. Is the strap broken or just disconnected ?
Edited By br on 23/06/2021 21:21:45
michael potts23/06/2021 21:26:13
40 forum posts
The strap and rod are broken and a solder repair has been attempted in the past. It seems to have just melted more of the rod away though.
Mike.
Michael Gilligan23/06/2021 22:33:48
18734 forum posts
916 photos
Posted by michael potts on 23/06/2021 21:26:13:
Ah … that makes sense of the cleverly worded advert yes
JasonB24/06/2021 07:00:37
21315 forum posts
2419 photos
Thank you so much for that Michael P, No excuse not to make one now!
I would probably have ended up with one of the bearing blocks between crank and eccentric had I not had those images.
Bazyle24/06/2021 13:28:42
6010 forum posts
220 photos
Can you afford to make one with the highest grade anti-friction metal like the original?
JasonB24/06/2021 13:54:08
21315 forum posts
2419 photos
No and I don't want any zinc alloy monkey metal failing over timewink 2
Colour of parts suggests I will be using bronze, it's also going to be the big bore version at 16mm rather than 5/8"
Roderick Jenkins24/06/2021 14:18:42
2122 forum posts
582 photos
Are you sure you can match the superfine limits available from die casting? wink
Rod
MichaelR24/06/2021 14:49:53
442 forum posts
82 photos
Posted by Roderick Jenkins on 24/06/2021 14:18:42:
Rod
And also the 16/- price tag frown However it's going to make a nice engine.
Michaelr
JasonB24/06/2021 15:05:45
21315 forum posts
2419 photos
Rod
I'll die tryingsmile p
br24/06/2021 16:23:16
697 forum posts
Posted by JasonB on 24/06/2021 15:05:45:
Rod
You are forbidden to die trying The forum needs you.laugh
More than pleased to see you have picked this one up to make and also good to see that an original survives.
Looking forward to the build.
bill
JasonB30/06/2021 20:07:00
21315 forum posts
2419 photos
I've made a start, decided on steel bearing posts with bronze bearings rather than solid bronze ones.
Fresh out of the pickle.
Harry Wilkes30/06/2021 20:51:34
1166 forum posts
64 photos
It will be an interesting build to watch keep the photos coming please Jason
H
JasonB04/07/2021 18:45:48
21315 forum posts
2419 photos
A bit more progress over the last week, cylinder still needs a bit more work and then the end covers will be profiled to a similar shape. I think this is the smallest flywheel I have made for an engine so will be interesting to see how it runs, I don't expect it to turn over as slowly as I like but that's not really what it was designed for.
JasonB25/07/2021 19:08:36
21315 forum posts
2419 photos
Almost done, just a lock nut to make and file down some plugs once the JBWeld has set then should be ready to try on air.
br25/07/2021 19:53:39
697 forum posts
I recall a song that sums this up nicely, something like :-
Nice one Jason, nice one son. Nice one Jason, let's have another one. wink
On a more serious note, well done and good to see the result.
bill
Edited By br on 25/07/2021 19:55:07
Ady126/07/2021 13:09:38
4689 forum posts
713 photos
Lovely
A good save Jason, the info was getting sketchy
JasonB26/07/2021 18:45:25
21315 forum posts
2419 photos
Well the JBWeld set overnight but still needs filing down and I have not made the locknut either but thought I would try it on a bit of air. Locked at TDC the first time but an adjustment to the valve rod length soon had the valve centralised and off it went. Should be better with a decent air connection, gland packing and the aforementioned locknut plus a lick of paint but here is the rough and ready version.
Edited By JasonB on 26/07/2021 18:46:02
Dreweatts
rapid Direct
walker midge
JD Metals
