George Thomas retractable slide for the myford.
Brian Abbott17/06/2021 16:28:10
488 forum posts
93 photos
Hello all.
Looking to maybe make a George Thomas retractable slide,
Anyone know were i will find the drawings to purchase?
Thanks
Dave Wootton17/06/2021 16:45:18
201 forum posts
51 photos
Hi Brian
There are drawings and instructions in G.H.T's Model engineers workshop manual which is still in print and full of information and drawings for much else besides.
I think Hemingway do a kit for it.
There's an easier to make one in Graham Meek's book Projects for your workshop.
Edited By Dave Wootton on 17/06/2021 16:50:34
DC31k17/06/2021 16:45:18
578 forum posts
See third post of this thread:
https://www.model-engineer.co.uk/forums/postings.asp?th=108552
Ady118/06/2021 07:47:25
4754 forum posts
715 photos
These gadgets are quite useful for the easiest type of screwcutting, external threads
There is also a lifting type which can be used with a motor that reverses and no retraction is required between cuts, clever stuff
If you are looking to speed up screwcutting a reversing motor switch should be your number one priority
KWIL18/06/2021 10:00:48
3425 forum posts
66 photos
Posted by Ady1 on 18/06/2021 07:47:25:
Or alternatively you could make a Graham Meek style leadscrew reversing clutch and have the motor continue to run in a forwards direction.
GHT style retractable slide is, I find, very useful indeed.
ega18/06/2021 10:59:34
2267 forum posts
188 photos
I'm not clear whether the retractable top slide or retractable screw cutting tool holder is intended.
Graham Meek18/06/2021 11:08:43
402 forum posts
265 photos
There is one omission in the GHT plans with regards to the Retracting Topslide. An Erratum appeared some time during the articles publication in ME, but it never was included in his book. At least not the First Edition.
Myford provide a cast recess in the topslide casting to clear their adjustment collar. On some castings this recess is not long enough to allow the fully designed retraction. I do not know if Myford altered this when they remodelled the topslide. This may have been accommodated by Myford's, as there were very close links between George and Chris Moore.
Gray,
Martin Kyte18/06/2021 11:45:33
2570 forum posts
45 photos
I made one from the Hemmingway kit although I have the book as well. The Hemmingway kit suppies the bearings, gears and left hand lead screw and nut. Very pleased with mine. It doesn't get used for screwcutting much but the advantages of the smooth operation and large micrometer dial which is free settable with a clamp screw is very usefull. It's not hard to make and worth it just for the better micrometer dial.
Hemmingway kit
regards Martin
rapid Direct
JD Metals
walker midge
