Dividing head - Beval gear ?
Me.08/06/2021 15:06:31
127 forum posts
18 photos
Hi - recently been given a tilting dividing head - can't find a makers mark on it yet but it looks very well made.
It looks like it was taken apart for some reason and the main drive bevel gear is missing along with the handle - the surround doesn't look like too much work to make a new one but the bevel gear is my sticking point.
How do I work out what gear ratio it needs to be - ive not counted the teeth on the gear that remains yet but that's my next job.
Dave Halford08/06/2021 15:16:17
1669 forum posts
19 photos
The BS0 is 40:1
A photo would help
Me.08/06/2021 15:35:00
127 forum posts
18 photos
Seems to me that most run a 40-1 final drive but how do I work out what the missing gear is.
I take it there is a mathematical formula for such ?
I will add some photos later.
Edited By Me. on 08/06/2021 15:35:27
old mart08/06/2021 17:21:01
3313 forum posts
203 photos
Did it have a beval gear, or a worm drive?
Tony Pratt 108/06/2021 17:57:03
1644 forum posts
8 photos
Posted by Me. on 08/06/2021 15:35:00:
Not all run a 40:1 ratio.
Tony
John Haine08/06/2021 21:10:20
4099 forum posts
241 photos
I think we are all puzzled as to what a bevel gear is doing in this - does the OP mean a worm or wheel?
Nigel Graham 208/06/2021 21:47:35
1666 forum posts
20 photos
Odd that anyone would have removed the gear in the first place, but unless this was some special type, dividing-heads and rotary-tables normally use worms drive, not bevel-gears.
The dimensions of the innards should give you a guide to the sizes required, but unless spares are available for the specific device it's likely you'll have to buy an appropriate stock set (usually 40:1 but not always so verify on the particular head) and modify as and where necessary to suit.
Robin Dufton08/06/2021 21:52:11
34 forum posts
10 photos
I remember reading something like the worms on small dividing heads and rotary tables are peened in the factory to reduce backlash, as they're too small to fit in any other way of eliminating it. Even with a new worm gear it may be more hassle than it's worth getting it set up correctly because of that.
If it's a well made unit from a decent company that has a few parts missing, and worth saving, there is the option of buying a foreign copy and stripping it for parts.
Edited By Robin Dufton on 08/06/2021 21:52:26
John Olsen09/06/2021 11:09:19
1189 forum posts
92 photos
You might find a bevel gear on the outside if it is a differential dividing head, but the gears on the inside will normally be a worm and pinion. The number of teeth on the pinion would tell you the ratio of the head, it is unlikely to be a multi-start worm. The worm would have to have a tooth form and pitch to match the pinion. Could be made, but is it going to be worth the trouble?
Me.09/06/2021 11:11:22
127 forum posts
18 photos
Its defiantly a bevel gear drive that's missing - I can work that out from where the original handle would have been - I will attach a photo later.
John Reese13/06/2021 23:47:45
961 forum posts
Universal dividing heads had a shaft geared to the hollow shaft that carreis the dividing pates. It could be geared to the table leadscrew for milling helices. In some cases it could be geared to the spindle to enable divisions that were not possible with the index plates alone. That is the only pace I would expect a bevel gear.
Me.17/06/2021 15:53:06
127 forum posts
18 photos
As you can see - there should be a gear (bevel) to help turn the other bevel gear.
Dave Halford17/06/2021 16:11:11
1669 forum posts
19 photos
The bevel engages with the missing aux. input shaft (and change gears) for milling helix's, it operates via a mill power take off when the division plates are not used.
Oldiron17/06/2021 16:30:19
829 forum posts
23 photos
You probably do not need the missing parts unless you want to machine helix' helix's helixes helii devil
regards
RobCox17/06/2021 16:43:25
36 forum posts
19 photos
helicesdevil
And if you want to do that you'll need the gear on the end of the mill leadscrew and the banjo and gears to get the desired lead on the helix. But... you can use the dividing head as it stands to index the gear blanks to cut themsmiley
Edited By RobCox on 17/06/2021 16:47:41
Howard Lewis17/06/2021 17:08:00
5228 forum posts
13 photos
Measure the OD of the gear that is present, count the teeth and look to see if HPC, Reliance, Davall, or any of the other gear specialists have to offer. It may be necessary to modify the bore to suit the spindle.
If you know the make and model of the Dividing Head, it may be possible to obtain a replacement gear.
Andrew Johnston17/06/2021 17:11:16
6222 forum posts
676 photos
It's common for the drive shaft from the mill table leadscrew to maintain a ratio of 1:1 until it reaches the worm drive on the dividing head spindle. Bearing that in mind, and looking at the existing gear and witness marks, I think the bevel gears are a special case, ie, mitre gears. So we just need a copy of the existing gear in terms of tooth count and angles.
When spiral milling the division plates are still used, unless the helix is single start. While the drive from the mill table creates the helix:
the division plates are still needed for indexing multiple starts:
The only time I've machined a single start helix I used a 4-axis CNC mill:
Dave Halford17/06/2021 17:31:43
1669 forum posts
19 photos
Helix, smelix smiley oh yeah spiral milling. My head hurts.smiley
Me.18/06/2021 11:33:44
127 forum posts
18 photos
Thanks for the detailed answers - I had it in my head that the extra drive was needed to rotate the head in normal operation.
I understand the Helixieseezze's idea - maybe in the future if i ever need to cut one i will try to get it working properly so I can cut a "spiral "...
Andrew Johnston18/06/2021 11:54:36
6222 forum posts
676 photos
A helix and a spiral are not the same. In a spiral the radius changes as the angle increases. A helix is a special case where the radius is a constant.
walker midge
Dreweatts
JD Metals
rapid Direct
