Removing Column form SX2.7
Ian L31/05/2021 13:08:22
6 forum posts
I am trying to move my SX2.7 milling machine and need to remove the column. I have removed the 4 bolts and it looks like it will separate when moving the column forward, but when trying to lift the column it won’t separate from base. Can someone who has done this before offer advice. Thanks.
Ian
JasonB31/05/2021 13:21:13
21284 forum posts
2416 photos
The two dowel pins are put in at a slight angle so won't allow you to pull the two apart, remove pins first, they should be threaded for a make shift slide hammer.
Ron Laden31/05/2021 13:24:47
2233 forum posts
443 photos
I have not split a SX2.7 but pretty sure there is two location dowel pins as well as the 4 bolts, so probably tight on the pins. Is there a gap anywhere around the column/base connection where you can get a flat blade in as a lever..?
Ron Laden31/05/2021 13:26:42
2233 forum posts
443 photos
Post crossed with Jason's didn't know the pins are angled.
Ian L31/05/2021 13:39:21
6 forum posts
Thank you Jason & Ron. I was wondering if the pins would need removing but had seen a photo on the internet with the pins in the base.
walker midge
JD Metals
Dreweatts
rapid Direct
