Ballaarat construction series
Luker07/08/2021 07:34:25
179 forum posts
145 photos
The valve glands on the steam chest as well as the piston side cylinder cover has some interesting detail...
geoff walker 108/08/2021 14:35:27
491 forum posts
189 photos
Luker, that's a fine little engine you've made and in such a short space of time. Enjoyed the video doesn't she run well.
If I was 30 odd years younger I'd be tempted to have a go, but not now, not enough time and too many other things to do.
In the 20 or so years I have been visiting Australia I have been to the coastal town of Busselton on many occasions. First spotted the full size Ballaarat in 2018 not longer after it took pride of place in the visitor centre. A handsome engine beautifully restored. At the time I commented that it would be suitable for modelling and low and behold here we are. I like others will enjoy you're build series.
Are you an Aussie Luker? All the best
Geoff
Luker08/08/2021 17:26:37
179 forum posts
145 photos
Posted by geoff walker 1 on 08/08/2021 14:35:27:
Geoff
Thanks Geoff, she is a lot of fun on the track. One of the benefits of virtually checking everything before building it. No I'm not from Aus but I have done work there. Some of the local vernacular was used in the series to make it more interesting. I hope you and the readers find the series of interest. It’s always tricky writing a construction series; I try to keep it interesting enough so that non-builders won’t get bored.
I was invited to the 150 Year anniversary this year in Busselton, but unfortunately I could not attend. Maybe one day I'll get to see the old girl!
Luker17/08/2021 16:09:47
179 forum posts
145 photos
For everyone following the Ballaarat construction series here's a nice video showing the frames and linkage in motion.
Chris Perkins 317/08/2021 20:03:27
8 forum posts
Very Nice Luker !
I notice on the Drawings on the digital format of M E their are a few dimensions missing around the horns on the frames . Am I too keen or will these become apparent later in the series !?! Before I cut metal I prefer to model it in Inventor .
Enjoying what I have seen so far !
Chris
Luker18/08/2021 06:50:09
179 forum posts
145 photos
Posted by Chris Perkins 3 on 17/08/2021 20:03:27:
Very Nice Luker !
Chris
Hi Chris, yep you right I missed a few there. All the articles are written to complete a section of the build so I generally won't go back and say drill holes in a completed frame. If you find any dimensions missing please let me know and I'll add the drawings to the forum and update mine. Most of the missing dimensions will be because the item was laser cut using a DFX or 3D printed for the patterns.
Please post some pics of your progress! Can even add it to the series as a post script...
Chris Perkins 318/08/2021 07:15:43
8 forum posts
Thank you Luker for your prompt reply. Yes will post some photos / images as I progress. I was planning to mill the frames on the miller at work, the controller has the facility to convert DXF files to coordinates Hint !
Chris
Edited By Chris Perkins 3 on 18/08/2021 07:20:49
tom hardy08/09/2021 12:12:33
27 forum posts
1 photos
hi my name is tom hardy and i propose to build a 5 inch ballaarat i am a member of the northern districts model engineering society in perth west australia i live an hour and half drive from the original ballaarat in busselton is it possible to obtain dxf file of the frames and other components to give to a local laser cutter.
regards tom
Luker08/09/2021 13:28:01
179 forum posts
145 photos
Hi Tom, the DFX files for laser cutting are rather extensive and contain all the process specific tolerance and machining allowance built into the files. There is enough information for an unscrupulous commercial entity to use them to make kits at ridiculous prices to the detriment of the designer (and builders). I therefor will not give out the DFX files, but there is more than enough information in the series to draw them up yourself, or even better just let the laser cutting guys do it for you.
tom hardy09/09/2021 00:06:27
27 forum posts
1 photos
hi luker
understood
thanks luker
tom hardy12/09/2021 00:34:09
27 forum posts
1 photos
hi luker
information on the ballaarat there is a book titled steam in the forests by mrh southecombe available from the chart and map shop fremantle wa this gives a comprehensive account of timber logging in wa
if you are looking for another project 3 steam whims were made in yarloop wa around 1900 a modeller in the netherlands loek proper built one in 1918 and there are 2 videos on you tube he got his information from the pickering brook heritage web site when googling steam whim model i have started to do a whim
maybe of some use
tom
Luker12/09/2021 05:57:07
179 forum posts
145 photos
Posted by tom hardy on 12/09/2021 00:34:09:
Hi Tom, my next project is well on its way. Design complete, boiler, frames and all castings done. But these Whims look great! I won't tackle multiple projects at once but these will be added to my possible projects list!
Luker12/09/2021 06:06:22
179 forum posts
145 photos
The little Ballaarat goes to our track often, but last weekend there was a quiet time when I could play around a little. I raked the fire bare and waited for the pressure to dip below 30Psi (roughly, the loco has a commercial ME gauge soon to be replaced!). Added cold anthracite and set off... It kept that low pressure for a while on our long track then slowly started to build pressure and at the end of the run was on working pressure. I was pleasantly surprised by that little boiler and loco!
For the Wahya and Ballaarat I did some simulations and design work on the boiler and front ends; comparing these locos to the other locos I've built it looks like it’s paid off...
photo 14 steve taking a closer look at the author?s little ballaarat (photo patrick ackerman).jpg
Luker02/10/2021 09:02:13
179 forum posts
145 photos
The young lad mentioned in the beginning of the Ballaarat series is moving along nicely with his build. Bearing in mind he never went to a technical school, nor has he decided to follow a career in engineering, his model engineering skills are moving along incredibly fast. I asked him to write a piece for our little club newsletter and one of his statements struck home and I thought it was rather inspirational: “This hobby sucks when you do things wrong the first time or two but it’s amazing when you finally get it right.” He sent me a picture of one of the wheels, machined according to the instructions in the articles. The picture shows him checking the profile with a gauge I designed to make life a little easier. Looks pretty good to me (in fact spot on!). The eccentrics came out nicely as well. Well done, young man!
Jon Lawes02/10/2021 09:40:05
976 forum posts
Anything that encourages some continuation in this hobby sounds fantastic to me. He's made a lovely job there.
tom hardy13/10/2021 08:16:38
27 forum posts
1 photos
hi luker
is it possible to give me measurements of the motion plate
tom
Luker13/10/2021 12:06:34
179 forum posts
145 photos
Posted by tom hardy on 13/10/2021 08:16:38:
hi luker
tom
Of course! I think I've added the missing dimension you're looking for, and updated the drawing (and mine). There's bound to be more as you go; please give me a shout and I'll update the drawings, and add it to the forum. Please post pictures as you go!
Luker13/10/2021 12:15:26
179 forum posts
145 photos
I see the guys at ME have posted the Ballaarat GA (very good quality) on the front page of this site, thanks guys! Should print out nicely...
As a side note my drawings have the design tractive effort, cylinder sizing etc. on the GA but this is generally removed for print.
Check the 'look out for...' blocks at the bottom of the page or click the link below (this should work)...
Ballaarat GA
Edited By Luker on 13/10/2021 12:22:08
Ronald Wagner21/10/2021 00:17:33
1 forum posts
Hi Luker,
In your intro to the Ballaarat you mention having your mentee complete a "wobbler". Do you have an article you've already written on that, or a drawing? Seems like a good idea as an intro machining project.
Ron
Luker21/10/2021 12:06:27
179 forum posts
145 photos
Posted by Ronald Wagner on 21/10/2021 00:17:33:
Hi Luker,
Ron
Hi Ron, I never did an article on the wobbler. It is very simple! It was designed to be made by sales guys that had never machined anything, for a course I presented many years ago (for fun). There are many better designs out there, but if you want the drawings you are welcome to them. I might need to make a few notes for you, as the drawings specifically omit one dimension that was up to the class to work out (and find). There were a couple of other outcomes of the course besides the machining for example engine balance, low vs high rev's etc. One of the builds are in the video below...
Rapid RC
Dreweatts
