Luker | 21/05/2021 15:19:30 |
![]() 179 forum posts 145 photos | Hi everyone. Here’s a little sneak peak of my next construction series… hopefully not much longer before it gets published. An exceptional video of the Ballaarat by Anthony Dawson (thanks to him for permission to embed it here)… |
Meunier | 21/05/2021 19:25:12 |
448 forum posts 8 photos | ...and no problems with having to remove the cab roof ! |
SillyOldDuffer | 21/05/2021 21:15:51 |
Moderator 8903 forum posts 1999 photos | Thanks for posting the video - fascinating connection between Wales and Australia, then and now. I wonder who the men in the photo are? Judging by how it's staged, with the shed door behind covered by a tarpaulin, I think this is the occasion of the engine being handed over to the customer. My guess is the men are posed in strict social hierarchy:
Dave |
clivel | 21/05/2021 21:55:27 |
344 forum posts 17 photos | Fascinating video. I doubt though, that this was a factor in your choice of prototype. Clive
Luker | 22/05/2021 07:15:41 |
![]() 179 forum posts 145 photos | Yep this little loco is loads of fun on the track, and easy to drive (no pesky roof or cut-outs to take skin off I like the analysis of the gents in the manufacturing yard picture! Seems like, even in those days the person that’ll do most of the work is furthest from the loco. Na, I just liked the look of that low pitched boiler and the odd valve gear. I actually didn’t know of the connection to Pretoria… I call this my COVID loco; it was designed and built in the first 9 months of 2020 when we had a very restrictive lockdown. |
Luker | 20/07/2021 13:40:48 |
![]() 179 forum posts 145 photos | Hi All, the first installment of the little Ballaarat is in the current issue. I'm quite excited about sharing this build! I hope everybody enjoys the series. Here's a small animation of the design. I removed the back panel to make the backhead more visible. |
Luker | 04/08/2021 07:07:31 |
![]() 179 forum posts 145 photos | Hi everyone, here's a video of the real Ballaarat resting in state... Thanks to Jacquie for sending it through! |
Luker | 04/08/2021 07:09:24 |
![]() 179 forum posts 145 photos | And a video of the little one going around our little track... |
Phil H1 | 04/08/2021 12:39:19 |
459 forum posts 60 photos | Thanks for posting. I have seen issue 1 of the build in the ME and I will definitely be following this with interest. |
Rob McSweeney | 04/08/2021 14:21:52 |
73 forum posts | Anyone done a build cost estimate on Ballaarat yet? |
Luker | 04/08/2021 15:59:20 |
![]() 179 forum posts 145 photos | Posted by Rob McSweeney on 04/08/2021 14:21:52:
Anyone done a build cost estimate on Ballaarat yet? I can’t help with exact costing because most of the materials came from scrap or left over stock from one of my previous builds. The design uses common bar stock and metric fasteners available from pretty much anywhere. The main items were as follows: Laser cutting $138 (this includes the frames, linkages and boiler - laser cut and rolled) Castings from scrap All boiler fittings machined from risers or non-ferrous hex bar, depending on the position All copper steam lines from refrigeration tubing Paint - 2k automotive paint I used a model engineering trade gauge someone gave me but this will be replaced as soon as I make a batch of gauges for my current loco. |
Chris Perkins 3 | 04/08/2021 20:10:35 |
8 forum posts | Watching with interest , love the idea of Metric Fasteners ! |
Former Member | 04/08/2021 20:32:32 |
1085 forum posts | [This posting has been removed] |
Jon Lawes | 04/08/2021 20:35:10 |
![]() 995 forum posts | Fantastic to see a new construction series. Once it's in ME, it's a part of history! |
Jon Lawes | 04/08/2021 20:51:49 |
![]() 995 forum posts | I've started a Wiki page on the SmallLiveSteamEngines site; I'll flesh it out as more information is forthcoming.
https://smalllivesteamengines.fandom.com/wiki/Ballaarat_(5_Gauge) Edited By Jon Lawes on 04/08/2021 20:52:07 |
JasonB | 05/08/2021 07:43:03 |
![]() Moderator 23070 forum posts 2769 photos 1 articles | Posted by Luker on 04/08/2021 15:59:20:
Anyone done a build cost estimate on Ballaarat yet? I can’t help with exact costing because most of the materials came from scrap or left over stock from one of my previous builds. The design uses common bar stock and metric fasteners available from pretty much anywhere. The main items were as follows: Laser cutting $138 (this includes the frames, linkages and boiler - laser cut and rolled) Castings from scrap All boiler fittings machined from risers.....................................
The "Castings" are likely to be where the costs and work are for those that do not have the facility to cast their own like you do so will either have to make patterns to have the parts cast or fabricate/cut from solid presumably from bronze which could be costly. They also won't have any risers as a material source. Will the drawings have sufficient dimensions of the "cast" surfaces so that builders can make patterns, fabricate or cut from solid as it's usual to just dimension the machined features for cast parts? Though some of this could be offset by getting a hacksaw and file out rather than laser cutting Edited By JasonB on 05/08/2021 07:45:20 |
Luker | 05/08/2021 15:53:40 |
![]() 179 forum posts 145 photos | Thanks guys; Jon I like the wiki page! Jason; there should be enough dimensions to make patterns. If any are missing it wasn't intentional. I have no doubt that there is no casting I can come up with that you can't fabricate! But for the average builder or even the beginner I don't think any of the parts will pose much of a problem (to fabricate). The cylinders will require a decent torch, and some of the detail can be left out to simplify. With the price of hacksaw blades and files I think the laser cutting comes out cheaper, I’ve started cutting up my old band saw blades to make hacksaw blades… |
Phil H1 | 06/08/2021 20:25:04 |
459 forum posts 60 photos | I would have thought that the wheels can be taken from another design? Maybe even the cylinders too? There is bound to be an engine out there already with similar sizing? |
Luker | 07/08/2021 07:28:00 |
![]() 179 forum posts 145 photos | Posted by Phil H1 on 06/08/2021 20:25:04:
I would have thought that the wheels can be taken from another design? Maybe even the cylinders too? There is bound to be an engine out there already with similar sizing? I think you may find similar castings, any inside frame Stephenson 5g model with similar bore and stroke could probably be modified. The cylinder castings and cylinders are shown below. The fancy cutouts around the steam ports are only to improve the castability, and aren't necessary (besides these are at the bottom and on the large loco this was covered in cladding). |
Luker | 07/08/2021 07:30:07 |
![]() 179 forum posts 145 photos | One casting that might be difficult to find is the smokebox door, but this could easily be built up or machined from a disk. The cutout at the bottom is something unique. |
