Painting staircase spindles
JimmieS12/05/2021 14:04:37
276 forum posts
I am in the process of painting 70 previously varnished mahogany spindles each turned from 2" stock. The rubbing down and priming went well (!) but trying to make a decent job of the top coat is proving impossible probably not helped with my slow work rate due to arthritic hands. I was advise to use Johnstone's Aqua System top coat but it is drying off almost from the brush. Temp in the stair well is around the 25C mark which will not help.with paint flow. Any help and advice would be of great help.
Also anyone have experience of Floetrol as an additive for making paint flow?
Tony Pratt 112/05/2021 15:30:30
1752 forum posts
8 photos
I did 21 spindles last year & that was enough! I do sometimes use water based paints but they don't flow as you have found out, on the spindles I used solvent based gloss with me one side & the wife the other, turned out really well.
Tony
AdrianR12/05/2021 16:47:13
542 forum posts
36 photos
I have not used Floetrol, but I have used a similar product from the same company for oil paints and it was superb. Having struggled with these new-fangled water-based paints I would defiantly give Floetrol a try.
I have had some success with using a synthetic brush, pre-wetting the brush with water and using a very fine spray of water on the surface prior to painting.
Apart from that, I take my glasses off and it all looks perfect.
larry phelan 112/05/2021 17:10:48
1113 forum posts
14 photos
I find ALL water based paints a total pain-in-the-arse.
JimmieS12/05/2021 18:30:03
276 forum posts
Sorry that should have read 40 spindles. Tony, I suppose you and your good wide do not do any sub contract work!
Jim
Tony Pratt 112/05/2021 18:35:41
1752 forum posts
8 photos
Posted by JimmieS on 12/05/2021 18:30:03:
Jim
Sorry no, it's not an experience I want to repeat.smiley
Tony
Bill Dawes12/05/2021 19:22:28
493 forum posts
Agree with all the above re water based paints, tried them to save the planet but they are a waste of time in my opinion. We too have a staircase with a million spindles, takes an age but oil based paint lasts well for us oldies anyway, no kids or dogs/cats to wear them out.
Bill D.
John Billard 112/05/2021 19:56:32
101 forum posts
There is a job worse than that - getting paint off staircase spindles. Ours were white painted - ugh - in a Victorian house (built by the GWR incidentally). After that huge job with Nitromors and wire wool we varnished them and they have looked good ever since. And will never want repainting!
John B
Mike Poole12/05/2021 20:02:50
3095 forum posts
72 photos
Dulux Trade Gloss is nice to apply and should stay white for longer if you want white.
Edited By Mike Poole on 12/05/2021 20:04:30
Steviegtr12/05/2021 22:50:40
2269 forum posts
313 photos
My fullest sympathy. Horrible job. Mask up the house & spray them..... No just kidding.
Steve.
AJW12/05/2021 23:37:49
359 forum posts
135 photos
Many moons ago when faced with painting our new spindles white I wheeled the compressor in and sprayed them. No carpet's were fitted at the time, the spindles came out a treat but what a mess everywhere else! Only did it once!
Last time I used a roller for basically applying the paint quickly, finishing of with a good brush worked well.
Alan
modeng200013/05/2021 09:20:34
273 forum posts
Posted by Mike Poole on 12/05/2021 20:02:50:
I find this much thinner than the domestic version and so is much more inclined to produce runs.
Howi13/05/2021 09:40:13
321 forum posts
19 photos
Buy a bungalow.........
Mark Rand13/05/2021 10:04:39
1076 forum posts
12 photos
There's a lot to be said for French polish on mahogany spindles. cheeky
Samsaranda13/05/2021 10:10:42
1244 forum posts
5 photos
Cant beat the good old fashioned lead based paints! I can already hear the health & safety lobby complaining in the background, yes I know you can’t use lead based paints nowadays but that doesn’t change the fact they were incredibly better than today’s offering of low VOC water based rubbish. Dave W
Mike Hurley13/05/2021 10:29:35
205 forum posts
69 photos
Just cannot understand why the genius chemists of the massive paint industry seem totally unable to come up with a water based paint that's any good. I've always hated the smell of white spirit and use 'quick drying' stuff inside the house but am always disappointed with the finish no matter how carefully I put it on. Although I approve of the idea to remove the high VOC spirits in the atmosphere.
What about using an airbrush? Might take ages but you can be precise and not contaminate the rest of the house. Just a thought.
regards
Dave Halford13/05/2021 13:09:20
1816 forum posts
19 photos
Posted by Mike Hurley on 13/05/2021 10:29:35:
regards
They did, it goes on your car smiley
Floetrol adverts seem refer to a ceiling, frankly a dab of water will thin emulsion enough if that's the problem, I wonder if it works on gloss.
The makers seem to know there's a problem, hence the fine artifical fibre brush requirement.
Andy Stopford13/05/2021 13:26:16
104 forum posts
16 photos
The only water-based gloss I've found that gives a comparable finish to oil-based is Albany:
https://www.brewers.co.uk/product/AA0142001J
I did an Edwardian-ish staircase with it recently, no problem at all (apart from the awful tedium - you need something good on the radio).
if I have a painting job I always insist on using Albany now - absolutely no horrible stinky oil-based allowed. And as for lead paint - yes, great, let's spend an hour stirring the wretched stuff and as an added bonus, poison ourselves!
By the way, it's reputed that water-based paints won't yellow in dim light the way oil-based does.
duncan webster13/05/2021 16:42:50
3581 forum posts
65 photos
Well for decorating I think water based is the bee's knees. Goes on a lot easier, dries more quickly, cleaning brushes is a doddle and it doesn't go yellow. As a bonus it isn't polluting the atmosphere. I will admit the finish isn't quite as good, but it's only interior decorating, it's not important, not like a loco or stationary engine. Keeps SWMBO happy, so job done. For outside I use Sadolin Supadec, same advantages and it doesn't crack or flake off. OK it isn't very glossy, but who cares.
I did once use Dulux Weathershield on an internal window frame, I'd run out of the normal stuff and the shops were shut. It stank for days, never again
Nigel Graham 216/05/2021 20:56:12
1767 forum posts
22 photos
"It stank for days..."
Don't remind me.
I used outdoor timber preservative on my varnished hardwood front door, then after several days of a still-waxy finish and the front porch smelling like an engine-room, thought I ought read the label again, more carefully.
Turned out the stuff is for raw wood, so it can soak in, and one of its few main ingredients is diesel-oil.
Ah well. As long as it works.
walker midge
JD Metals
rapid Direct
