Myford Super 7 Toolpost issue
Matt Stevens 105/05/2021 03:57:09
100 forum posts
11 photos
Hi All,
So i just picked up a Myford Super 7B for a great price and with many accessories as well. It does have a quick change tool post holder, but its a real mini thing and will not accept 12mm tools which is most things i have!
I want to move the quick change tool post holder from my southbend lathe across which is much more substantial and of course will accept the 12mm / 1/2" tools.... trouble is, the height of the top slide of the Myford is such that with the holders bottomed out, i would not get to center height on the lathe!
How have most overcome this? I was hoping not to have to buy a new quick change system....
I can use the original tool post holder i guess, but thats like a down grade.
Open to suggestions....
JasonB05/05/2021 06:57:07
22746 forum posts
2653 photos
I think you will find most people use smaller tooling on the Myfords
Ady105/05/2021 07:38:37
5089 forum posts
736 photos
Myford sized lathes don't really do 1/2 inch tooling
They do make good parallels
John Baron05/05/2021 07:54:19
520 forum posts
194 photos
Hi Guys,
I can use 1/2" inch tools in mine but much prefer 6 or 10 mm HSS ! Far less work profiling and sharpening !
Andrew Moyes 105/05/2021 07:54:52
145 forum posts
23 photos
Look up the thread 'QCTP mounting on the Myford S7' and you will see some solutions.
Hopper05/05/2021 09:07:11
6393 forum posts
334 photos
Posted by Matt Stevens 1 on 05/05/2021 03:57:09:
The original Myford 4-way toolpost takes 3/8" tooling, about 9.5mm. So 12mm tooling will sit too high in it.
Ady105/05/2021 09:17:24
5089 forum posts
736 photos
Just picked up a Drummond M at the weekend and beside it was a Myford 7 which was waiting for another person to collect
It looked like what it was made for, a nice model makers lathe
Circlip05/05/2021 09:36:24
1510 forum posts
I feel the O/Ps pain, I have some perfectly good 1" (25mm) square shank lathe tools that won't fit in my Maximat.
Regards Ian.
Matt Harrington05/05/2021 09:40:30
187 forum posts
7 photos
Matt, What QC system is on the Myford at the moment? You can get a suitable low cost QC system that takes 12mm at a good price on Banggood (and UK stock and thus quick delivery). You could then sell on your exsisting one....Just a thought.
Matt
JasonB05/05/2021 10:10:27
22746 forum posts
2653 photos
Matt although there are plenty of cheap QCTP about the problem with one that would take 12mm tooling AND fit a Myford is the bottom of the toolholder would only be about 3mm thick!
Not ideal for rigidity and likely to open up but sounds about right for Banggood wink 2
Kiwi Bloke05/05/2021 11:49:57
666 forum posts
Q: 'How have most overcome this?'
A: Well, by getting the right sized tooling... If you insist on using over-sized toolholders in a system they don't fit, make them fit! Mill 2mm off the bottoms off the toolholders. This is probably the most commonly-used solution, and, as you know, far cheaper than buying replacement tooling.
Matt Harrington05/05/2021 12:04:47
187 forum posts
7 photos
Jason, the 250-001 holders are the same ones as sold by other vendors and to be honest, I have never had any issue with rigidity. In fact I also use a modified version of these holders on some of my Tripan toolposts, again with no issue. Matt
not done it yet05/05/2021 13:08:36
6809 forum posts
20 photos
Posted by Circlip on 05/05/2021 09:36:24:
Regards Ian.
Reduce the dims of those cutters? I much prefer to reduce the cutter/cutter holder than increase the tool holder capacity.
Steviegtr05/05/2021 17:21:45
2432 forum posts
336 photos
Have a look at a video i did a while ago on youtube. I explain & show how i made a 250-111 holder fit. Hope it helps you.
Steve.
Myford QCTP fitting for larger cutters
Dave Halford05/05/2021 17:40:38
2050 forum posts
23 photos
Southbend to a Myford .......... Nope, still don't get it.
Matt Stevens 105/05/2021 18:22:30
100 forum posts
11 photos
Dave - The Southbend i have is a 1939 Model C....so no QCGB, No reverse, no power cross feed, bed getting worn, no way to mount attachments to the cross slide (i.e. no T-bolts), less speed range, less tailstock feed etc. These are all advantages to the Myford which is much younger, in great condition and like i said - purchased at a good price.
Steve - I did watch your video, i see you machined down the top of the top slide quite a bit. I am not keen on that particularly, but perhaps modifying the tool holders is an option.
Jason - Understand your point about rigidity, however is it any different than using smaller tooling anyway? i.e. are they just comparable?
So it seems the main options are a) Buy all new tooling (expensive) or b) get a new QCTP suitable for a Myford with 12mm tooling or c) mill down my tool post holders so they will sit lower.
Perhaps option b) is the cleanest way to go and then when i sell the southbend, i can increase the cost by $100 to help offset. Any other ideas or am i concluding the right way?
Mike Poole05/05/2021 18:38:01
3335 forum posts
73 photos
The top slide is superfluous much of the time so a bolster to just fit your tool post could be made. Refitting the top slide is a quick job when required. The potential increase in rigidity could help to maximise the cut taken with the larger tool bits. The Gibraltar tool post from Hemingway is designed to take large tool bits and maximise rigidity and depth of cut but only for a single tool.
Michael Briggs05/05/2021 18:56:18
220 forum posts
12 photos
I would not compromise the rigidity of the top slide to accommodate oversize tooling. I would either take Mike's advice, or reduce the height of the tooling.
Michael
Matt Stevens 106/05/2021 02:26:24
100 forum posts
11 photos
Has anyone come across this solution?
Its advertised for the ML7, but i assume the topslide is the same between the ML7 and Super 7?
It also claims on this page that the slide can be milled to allow the usage of 1/2" tools in a QCTP....anyone seen these or got experience of them?
Matt Harrington06/05/2021 10:50:33
187 forum posts
7 photos
These guys claim their topslide casing is used for all '7's:
I always thought the ML7 topslide was of a different size. I'd be interested to know for sure....
Matt
Edited By JasonB on 06/05/2021 12:24:38
Dreweatts
Rapid RC
