Magnetic swarf
steamdave03/05/2021 16:23:34
492 forum posts
39 photos
Many folk use magnetic bits such as magnetic DTI holders and the like on their machines. In time there must be a build up of magnetism in the machine which in turn attracts the ferrous swarf.
I've studiously avoided the use of magnetic equipment on my machines until recently when I started using a magnetic holder for a DTI.
So, how do people de-magnetise their machines, or do they not bother?
The Emerald Isle
mark costello 103/05/2021 16:44:17
677 forum posts
12 photos
Never had a problem.
Tony Pratt 103/05/2021 17:06:49
1767 forum posts
10 photos
Not a problem
Tony
Howard Lewis03/05/2021 17:16:25
5562 forum posts
13 photos
Not aware of a problem after 17 or more years with lathe and Mill.
I use a stick magnet in a copper tube to pick up ferrous swarf to get rid of.
Jon Lawes03/05/2021 17:17:14
700 forum posts
That sounds very much like a non-problem.
steamdave03/05/2021 17:27:19
492 forum posts
39 photos
OK. Thanks for putting my mind at rest.
The Emerald Isle
Brian Wood03/05/2021 17:32:59
2475 forum posts
39 photos
Cast iron does not hold residual magnetism in the same way as steel does which may explain why it is not noted as a problem with DTI mounts on such surfaces.
Regards Brian
Joseph Noci 103/05/2021 17:49:20
1013 forum posts
1253 photos
Irritatingly, I have had chuck jaws ( the hard type) become magnetic and then it's a pain clearing the fine swarf from the jaws when inserting the workpiece. Likewise tool steel lathe cutters, and some milling cutters and even the hard steel capscrews in the tool-holder. This only occurs in the hard steel bits on the lathe - I have never had issues with the lathe structure. I am not sure how, for example, the chuck jaws, become magnetic but they do so repeatedly. I demag all the bits with a homebrew demagnetiser, and all is well for a few weeks. There is that high-school science trick where you align a hard steel rod say North/South, hold it so and smack the one end with a hammer a dozen strokes - it becomes magnetic - maybe I should stop smacking the lathe so hard....
Joe
Samsaranda03/05/2021 19:31:35
1254 forum posts
5 photos
Are you sure that your lathe is pointing North/South then? Dave W
Tom Sheppard03/05/2021 20:35:04
31 forum posts
Yes, it is hung from a rope so it aligns magnetically.
old mart03/05/2021 20:55:12
3418 forum posts
210 photos
I have never noticed any adverse affects, in fact using lots of magnets when machining cast iron helps to control the mess.
rapid Direct
walker midge
JD Metals
