Help, New ARC Sieg SX2.7 mill reverse???
Rob Wheatley19/04/2021 14:21:15
35 forum posts
12 photos
Hi all, my new Sieg SX2.7 from Arceurotrade arrived this morning, spent a couple of hours unboxing, taking the column off, moving it down the mancave and putting it back together, all went well.
Had a good look over it and have to say I'm very happy so far, checked the table X axis, maybe 0.005 mm end to end, less for the Y axis, (dti is only 0.01mm) all with no play as far as I could tell, table looks very good, everything moves nice and easy with only the last 10mm of X axis tight at the left end of travel.
Chuck is very stiff to remove from the spindle but the ER32 collet holder is fine.
I did remove the spring from behind the X axis handle that pops the dog clutch out as that would really annoy me also the guard as its far to big!
Run it for 10 mins each @ 500, 1000 and 2000 rpm, spindle was warm at the end but not hot.
This one has the new control panel with the speed knob, emergency stop, start and tapping mode, but nothing for reverse apart from in tapping mode with the green quill buttons, I have tried everything but cannot find how to run it in reverse unless in tapping mode, manual is for the old panel so no help at all.
Do the new ones now not run in reverse or am I being stupid?
Tried a few quick test cuts just on aluminium and all is good.
Few things it will need very soon, X powerfeed and Z powerlift, I would end up lopsided other wise winding them handles so much.
Neil Wyatt19/04/2021 14:29:14
18805 forum posts
733 photos
80 articles
Posted by Rob Wheatley on 19/04/2021 14:21:15:
Most mills only run in one direction.
There are a few exceptions as you can get left-handed drills and mills for special purposes.
John Hinkley19/04/2021 14:31:59
1197 forum posts
393 photos
You have reached the top of the slippery, spendy slope!
A 'phone call to ARC should elicit the definitive answer to your particular query. I think Jason has one, or had one for his book, so maybe he'll chip in.
Rob Wheatley19/04/2021 14:42:28
35 forum posts
12 photos
Posted by John Hinkley on 19/04/2021 14:31:59:
Oh yes a very slippery slope lol, going to use stepper motors for them, one more axis and it might as well be CNC!!
Will ring and ask Arc.
Rob Wheatley19/04/2021 14:44:12
35 forum posts
12 photos
Posted by Neil Wyatt on 19/04/2021 14:29:14:
The push button one did do reverse and still says on the description for it.
JasonB19/04/2021 15:37:14
21629 forum posts
2493 photos
What you really need is a good book on the subject that will tell you that on the new panelled machines "Forwards and reverse on these machines can only be operated by pressing one of the green buttons on the spider when in tapping mode" wink 2
So no high speed rev but you can make use of it for under 500rpm milling by pressing the tapping mode button on the panel and then one of the green buttons.
Also make sure you use the small stop button to stop the machine unless it's an emergency in which case hit the big red one.
Edited By JasonB on 19/04/2021 15:38:19
Edited By JasonB on 19/04/2021 15:39:51
Jim Nic19/04/2021 15:48:48
358 forum posts
202 photos
I have a Warco mill with spindle reverse capability. I can't recall any time I have used that feature In the 10 years I've had it.
Jim
Rob Wheatley19/04/2021 16:22:23
35 forum posts
12 photos
Yup saw that in the book I have called " Milling for beginners" written by some bloke called Jason Ballamy (whoever he is smile p) after I have posted and phoned lol.
Probably never need reverse but knew the old version did it.
John Haine19/04/2021 17:24:47
4272 forum posts
251 photos
If you build the Hemingway speed increaser then you will need it! Otherwise only useful for tapping.
walker midge
rapid Direct
JD Metals
