Jonathon Bywater | 16/04/2021 01:08:47 |
34 forum posts | Bit of advice please. I m looking for a new drilling machine on a small budget. I ve sort of whittled it down to a SIP 01701 16 -12. I I m only really going going for that as its more than big enough and hopefully wont bend and shake like smaller ones. Also is 350w motor likey to be up to drilling through up to 3 inch mild steel sometimes. Was looking at older British machines at under £200 but they look like new motors are needed too and usually too far to bother. Thanks Jonathon |
Ady1 | 16/04/2021 09:59:54 |
![]() 5071 forum posts 734 photos | 3 inches in mild steel is a pretty big ask from a cheap drill I use my lathe for more serious drilling depths |
Clive Foster | 16/04/2021 10:58:57 |
3105 forum posts 107 photos | Jonathon Not really man enough for such deep holes. In smaller diameters likely to bend the drill and at larger ones it just doesn't have the power or rigidity to do the job without multiple pecks and swarf clearance. Holes deeper than about 2/3 rds of the standard jobber drill flute length tend to be tricky. Even my Pollard 15AY, which is a full blown industrial machine of pretty massive construction based on a square cast iron pillar, likes coolant for that sort of thing. Realistically nothing with the standard sort of round column is going to be very happy on that sort of duty. When it comes to affordable machines you have to be realistic about the price / performance ratio. Could be coaxed into doing a once in a blue moon job if you are careful. A friend had a splendidly Victorian looking Denbiegh of considerable height driven via multiple flat belts that handled such things with casual aplomb using its self feed. Clive |
Emgee | 16/04/2021 10:59:14 |
2409 forum posts 287 photos | Jonathon The model you state only has 60mm spindle travel so to drill 75mm depth will need the table lifting for the last 15mm. Emgee |
Mike Hurley | 16/04/2021 11:45:26 |
305 forum posts 87 photos | Up to 3" ms but what diameters? If your'e thinking anything much more than 8 - 10mm dia think it might struggle, and 60mm spindle travle is another key consideration. Emgee's comments re swarf are also very pertinant. As is often said on this forum, you'll always wish later that you had bought the next model up to the one you purchased of any machine - as the extra rigidity /power will come in handy on a number of jobs you never forsaw coming up against! regards |
Clive Foster | 16/04/2021 12:16:16 |
3105 forum posts 107 photos | Jonathon Ultimately the issue with all deep hole drilling is getting the swarf out. Power feed with coolant is always better because the constant force and steady feed keeps the swarf flowing out in a pretty constant chip stream. Manual feed and pecking tends to break the chip so the gremlins can tie it up in a knot round the drill. You can push a machine significantly beyond what its designed to do but care, concentration, knowing exactly what you are doing and what parts of the envelope you are pushing are essential. Clive |
Jonathon Bywater | 16/04/2021 13:56:49 |
34 forum posts | 3 inches is occassional due to odd shaped things. I think finding an older' proper' cast iron one and fitting new motor is the way. Thank you for the help |
Jonathon Bywater | 17/04/2021 12:35:21 |
34 forum posts | The internet is as useful as it can be infuriating. After so long looking I ve found Neil s answer to a post ,he has a Chester drill, if its good enough for Neil........,bit over my price range but others similar available. |
