Problem with 4 jaw chuck
AJAX14/04/2021 10:06:58
188 forum posts
42 photos
I have an independent 4 jaw chuck sitting on my workbench not being used. It looks vintage and has no maker's name. The jaws "fit" and appear to be from a set (all marked 171) but I am unable to say if they are original.
20210410-111803 20210410-111819 20210410-111831 20210410-111842
The problem with this chuck is the jaws do not close parallel with each other. A superficial glance suggests bell-mouthing through wear but on closer inspection the inner faces of the chuck jaws show they are in excellent condition - they still show the original machining.
The "slides" in the chuck body look good as do the screws. The jaws have minimal slop in their respective slides.
I could make a ring to hold all 4 jaws in position and then grind their internal faces. I have previously done this with a 3 jaw scroll chuck but never needed nor thought I would need to do this with an independent chuck.
Any suggestions before I attempt a fix?
AJAX14/04/2021 10:08:20
188 forum posts
42 photos
Another thing I should mention is the jaws are numbered 1, 2, 3 and 4. The chuck is similarly marked with centre-punched dots.
Oily Rag14/04/2021 10:28:06
416 forum posts
147 photos
Do(es) the slotted screw(s) in the face just attach the rear adaptor plate or is the body of the chuck a 2 piece construction? If it is two piece, will it allow you to strip it out and measure the accuracy of the jaw tenons.
Looks like it has had a component held in the very end of the jaws and been over tightened (with a pipe on the chuck handle?). Common problem with unskilled operators attempting to 'true' work up.
Martin
Michael Gilligan14/04/2021 10:31:51
18080 forum posts
845 photos
I wonder if it has been previously used for holding short insertion-lengths very tightly
... is it possible that just the first ’step’ is distorted ?
Edit: Martin beat me to it
Edited By Michael Gilligan on 14/04/2021 10:32:39
JasonB14/04/2021 10:36:24
20637 forum posts
2296 photos
Just because the inner face of the jaws are in god nick does not mean it has not had a hard life, could well have done a lot of work with the jaws the other way round, nicks in the face of the jaws confirm that and worn the slots.
It all looks very worn, rounded and pitted, the "machine marks" could even be where someone else has had a go at it rather than being original which would probably have been ground anyway
larry phelan 114/04/2021 12:24:45
1031 forum posts
14 photos
4 jaw independent chuck, or self centring chuck ?indecision
Hopper14/04/2021 13:05:21
5505 forum posts
137 photos
The jaws, and body, could be distorted rather than worn, ie bent. To regrind using the usual clover-leaf plate could be fiddly with independent jaws, trying to get them all in exact alignment. Much easier on a self-centreing 3-jaw. So a common alternative is to regrind them square on a surface grinder with jaws clamped to a suitable angle plate etc. But could be done in the lathe with some fiddling. I suppose you don't have to do them all together like a three jaw. You could do them one at a time.
Ive done it with a couple of equally ancient and abused looking three jaws and very happy with the result.
Edited By Hopper on 14/04/2021 13:11:36
Roger Best14/04/2021 14:11:57
243 forum posts
31 photos
Strip it down and get a square onto those jaws, you can't fix what you can't measure.
I suspect that they will need re-machining, the best method will depend on what you have access to.
Michael Gilligan14/04/2021 14:16:18
18080 forum posts
845 photos
Posted by Roger Best on 14/04/2021 14:11:57:
star yes
Pete Rimmer14/04/2021 19:43:39
979 forum posts
57 photos
Take the jaws out and lat the chuck face down on a surface plate. I bet it will rock like a boat.
More often than not bell-mouthed jaws is actually bent chuck face IMO.
Dave Halford14/04/2021 19:53:23
1507 forum posts
16 photos
I had one like that, more commonly known as a door stop.
JD Metals
