Laptop with a SD card slot
Seems they are out of fashion!
Henry Brown12/04/2021 12:04:24
482 forum posts
106 photos
I'm looking to buy a 17.3" screen laptop with an SD card port! It seems that they don't come as standard on higher spec models these days which seems a bit silly. I need the SD Card to transfer files to my 3D printer after generating .STL's in Fusion 360 and to download files from my camera.
These are the recommended specs from the Autodesk site:
1.7Ghz minimum but I'd prefer 2.6GHz or greater, 6 or more cores, 16gb memory, Dedicated GPU with 4 GB or more VRAM, DirectX 12 supported, 1920 x 1080 or greater at 100% scale resolution.
Scan Computers (Bolton) can build me a special but I'm thinking it will be out of my price range so I'm guessing I will have to get an adapter, before I press the buy button on one without has anyone any other suggestion please?
Steviegtr12/04/2021 12:23:01
2244 forum posts
311 photos
My Partner has just bought a smaller Lenovo laptop. No dvd drive, SD slot or USB. What it does have is 2 USB C ports to charge & do all other jobs. With a USB to USB C adaptor. £2.00 off ebay. All items can be plugged in to those ports. Tried it the other day & DVD work fine , as do memory sticks & my 5 slot memory card reader.
I think it is the way new laptops are going.
Steve.
Henry Brown12/04/2021 12:36:44
482 forum posts
106 photos
Yes, it may have to be the way forward Steve but what a faff! I use my laptop on my lap so anything that has to be added or sticks out is a nuisance tbh, The one I nearly bought has 4 USB ports and numerous others, however most Creality 3D printers use SD (my adventures into wireless/Octoprint are away off) as does my camera so an SD card would be preferred.
Farmboy12/04/2021 12:46:24
147 forum posts
Might be worth checking out PCSpecialist. It's a couple of years since I used them but they still seem to have a good assortment to choose from. If you 'customize' to your requirements they build to order so might be a few weeks delivery time.
Frances IoM12/04/2021 12:48:38
1163 forum posts
28 photos
why not go for a desktop + larger monitor as much easier for CAD use to have a large 4k screen (tho of course this could be plugged into a laptop as many of my monitors are) - desktops can also be loaded with more memory + interface cards.
Clive Hartland12/04/2021 12:52:02
2729 forum posts
40 photos
I bought an adaptor that takes SD, MMC cards, works fine and fits into the USB port
Edited By Clive Hartland on 12/04/2021 12:52:29
larry phelan 112/04/2021 12:53:39
1095 forum posts
14 photos
Welcome to the brave new world of laptops ! I found the same thing when I had to replace mine.
When I asked about the slot for playing discs, they looked at me as if I had asked for a piece of moon rock.
They then explained, as if talking to a half wit, that "these things" are old hat. Such kind words !
I used to burn discs on my old unit, but I have no idea how this could be done on my present laptop.
Sad to say, due to the current "lockdown", I cannot even call on the services of the local 6 year old consultant.
Life is not simple.
Peter Cook 612/04/2021 12:58:00
166 forum posts
50 photos
You might want to look at a tablet computer with a keyboard.
Most of the Windows 10 tablets seem to have an SD card slot. Microsoft Surface Pro 7 (at the top end) for example has an SDXC reader built in. Amazon have a Fusion 5 tablet which also has an SD card slot (towards the bottom end).
Grindstone Cowboy12/04/2021 13:01:10
713 forum posts
58 photos
Larry - I have an external CD drive/burner that connects via USB (the old style, not USB-C) which comes in very handy at times.
Just did a quick search and they are still available for under £30 from Currys, Argos, etc.
Rob
Matt Harrington12/04/2021 13:35:59
183 forum posts
7 photos
I use this type of reader:
Just make sure that it doesn't foul nearby USB ports. I tend to transfer from the SD card and then remove ( or the otherway around!)
Matt
Journeyman12/04/2021 13:37:48
1035 forum posts
200 photos
These from a South American Rain Forest for about £10.
Ady112/04/2021 13:46:45
4754 forum posts
715 photos
It frees up a usb slot which is more flexible
modeng200012/04/2021 14:17:47
271 forum posts
1+ for PC Specialist
John Haine12/04/2021 14:24:43
4186 forum posts
242 photos
Just had the same problem, solved by spending ~£7.50 at Argos for a USB C adapter that takes SD and microSD cards and also gives you an ordinary USB port (my laptop has only one USB A but 2 USB C ports). My new phone and tablet also have USB C.
Martin Connelly12/04/2021 14:37:56
1901 forum posts
205 photos
I have an old router plugged into my home network (via powerline adaptors) that is configured just as a switcher. I have plugged a Wavlink network USB port into it and a 4 way USB hub into that and can run USB memory sticks, USB printers and USB external hard drives on it. I have not tried it with external CD but have just tried a USB SD card adaptor and that works fine. The Wavlink server allows plugged in items to be connected or disconnected so I leave the external 4TB drive disconnected most of the time as it slows printing down if it starts indexing. This is using a Windows 10 laptop.
Martin C
SillyOldDuffer12/04/2021 15:01:34
7572 forum posts
1681 photos
Buy an adaptor! Cheap as chips. Mine does 4 different connections, two of which I don't recognise!
I feel for Larry because the same happens to me even though I know computer technology changes every few years. Floppy Disks, CD-ROMs, DVDs, SCART Cables, Internet Exploder, USB 3.0 and much else are all going the way of the Raphus cucullatus.
Decades ago I laughed at that comedy sketch were a middle aged customer tries to buy a needle for his gramophone and is thoroughly humiliated by the sales-yoof asking about stylii, woofers and such. Now hi-fi shops have gone and my children bark orders at Alexa. I haven't a clue what they listen to, or if I have Disney Channel or not. Most worrying is my kids are starting to complain technology is leaving them behind too...
Oldiron12/04/2021 17:13:00
852 forum posts
23 photos
Another +1 for PCSpecialist. Last week my 550W power supply gave up on my PC. As the PC has a lot of addons I opted for a Corsair 850W modular P/S. Arrived next day. Excellent service.
regards
mechman4812/04/2021 17:36:32
2933 forum posts
460 photos
My Dell Inspiron 17 3000 has a dvd player/ writer, Radeon graphics, Intel core i5 8th gen' 4gb ram, 1Tb hard drive, 3 USB ports, HDMI port. I still have a CD writer bought back in the 90's,still with it's mains adapter !, 2 x 500Gb ext hard drives, I think I am pretty well covered for most needs.
George.
Nick Clarke 312/04/2021 17:40:26
1258 forum posts
50 photos
Posted by SillyOldDuffer on 12/04/2021 15:01:34:
In my experience, no matter how old said children are the solution always appears to be an injection of Dad cash laugh
Robert Atkinson 212/04/2021 18:08:53
1091 forum posts
20 photos
Rant on:
This moving to 2x USB C wth one taken for power and no CD/DVD/Blueray just seems to be a plot to push us into using "the cloud" and streaming services. Trouble is you then don't have assured access to your data and don't own the music or movie. Then they have killed the "old tech" off I bet the costs of the alternatives go up.
Rant off:
Robert G8RPI
walker midge
JD Metals
rapid Direct
