Myford Super 7 spanner sizes
Spanner sizes wanted please
StephenS07/04/2021 00:10:48
38 forum posts
Hi all,
Can anyone help me with the specific BSW or BSF spanner sizes that would have come with a Myford Super 7 that is approx 40 years old?
Or any other spanners that would be needed (eg BA)?
Many thanks,
Stephen S.
Steviegtr07/04/2021 00:24:08
2432 forum posts
336 photos
There are BA sizes on the S7 e.g the oilers are all 2BA. There are also i think whitworth too. I have a stack of old spanners & just go for what fits. Never bothered to look at what size they were. My little Bahco adjustable fits everything.
Steve.
Edited By Steviegtr on 07/04/2021 00:24:54
T.B07/04/2021 01:52:00
54 forum posts
21 photos
2BA , 1/4" BSF and 7/16" BSF would be a good start.
Bo'sun07/04/2021 11:32:03
609 forum posts
If I remember correctly, you need to bear in mind that not all BSF/BSW spanner sizes refer to the thread size as you might expect. Something to do with reducing the hex size to save material during WW2.
Howard Lewis07/04/2021 14:41:24
6104 forum posts
14 photos
The Myford 7 Series was introduced in 1947, so being post War would, most likely, use the later, smaller BSW and BSF hexagon sizes.
Spanner likely to see most use is the 7/16 BSF on the Toolpost.
A 2 BA one for the locknuts on the gib adjusters, unless the nuts are oversize.
Others are unlikeley to see much wear, unless you are planning a complete strip down and rebuild.
A set of Imperial Allen keys will be useful.
If you are, just be sure of what is involved before upsetting any adjustments.
JA07/04/2021 15:01:21
1359 forum posts
80 photos
Stephen
My ten year old Myford came with two open ended spanners - 3/16W & 1/4W, 5/16W & 3/8W - and two Allen keys - 3/16AF and 5/32AF. Other than an open ended 2BA spanner these are all I have needed. The same goes, if my memory serves me well, for my earlier Super 7 Myford (the one with the flooded headstock bearing).
JA
Tim Stevens07/04/2021 21:12:36
1598 forum posts
One caveat: I have found that some of the whitworth spanners sold new on well known sites are rather loose in the fit on the nuts. The open ends seem to be made oversize, while the rings are not a series of 6 flats, or 12 half-flats, but a ring of rounded lumps. These tend to wear the heads - especially of adjusters as used on machines - much more rapidly than 'proper' flats. Combine this with the too slack fit to start with and it can be very disappointing.
The answer - look for used Whitworth spanners on the same sites, and then look for reliable makes, such as:
Britool, Gedore, Stahlwille, Blue point, Elora, etc. Look closely at the pictures, and avoid anything (whatever the make) which shows serious wear, hammer marks, and such signs of abuse. Many spanners hang in sheds for years, and hardly get used - so a bit of surface rust should not put you off, as long as the signs of abuse are missing.
Hope this helps
Cheers, Tim
Robert Butler07/04/2021 21:45:46
394 forum posts
6 photos
And use ring spanners where ever possible.
Robert Butler
Nigel Graham 208/04/2021 12:51:19
2133 forum posts
29 photos
Note though that some of the accessories now sold appear to use fastenings to ISO-Somewhere-near, with a 17mm spanner fitting one or two of those on mine - and these were bought new.
Most of the originals though are BSF/BSW.
John Purdy08/04/2021 17:33:26
349 forum posts
204 photos
As well as the ones mentioned by JA my Myford (1977) came with a single ended 3/8 A/F spanner for use on the lock screws on the cross slide to retain the top slide. My two double ended Whitworth spanners are "Snail Brand".
Edited By John Purdy on 08/04/2021 17:34:05
Michael Gilligan08/04/2021 17:51:21
20182 forum posts
1053 photos
Posted by Tim Stevens on 07/04/2021 21:12:36:
That’s interesting, Tim
... it seems to completely contradict the story that Snap-on tells about ‘Flank Drive’
Ref. https://worldwide.espacenet.com/patent/search?q=pn%3DUS3273430A
[click the vertical column of three dots, at upper-right of the page, to find the download option]
Edited By Michael Gilligan on 08/04/2021 17:53:19
Peter Sansom09/04/2021 11:45:03
109 forum posts
Just look for Ring Open End spanners from a good brand. A set comprising 2BA and 1/4"BS to 7/16"BS.
The largest 2 Nuts are the Lead Screw Hand wheel nut and the Tail stock nut.
Peter
Robert Butler09/04/2021 23:08:47
394 forum posts
6 photos
If you are looking for Ring Open End spanners try instead for Combination spanners, ring at one end open ended at the other, Each spanner only fits one size.
Robert Butler
PS the ex Myford fitter who serviced my lathe advised Myford used the cheapest spanner sets available
DMB09/04/2021 23:35:24
1312 forum posts
My S7, new in ?1971?, came with the 2 big double open ended spanners mentioned above and 2 small single open ended spanners, one fits topside locking screws, cant remember what the other was for, maybe banjo locking screws. Still need 2BA to fit Oilers and Allen keys for all the skt hds. L/S Brkts held by 2BA skt hds, e.g. A C - spanner was also in the kit to adjust the mandrel bearing.
DMB09/04/2021 23:38:27
1312 forum posts
Tim,
That sounds like another brainless modern idea to save on production costs and bugger the result. Complete trash.
Hopper10/04/2021 03:11:13
6393 forum posts
334 photos
Posted by Robert Butler on 09/04/2021 23:08:47:
Yes but in those days the cheapest spanners were still made in Britain and still quite reasonable quality for home use. They must have churned out millions of Snail brand and King Dick, Vincent etc spanners over the years so costs were low. But they used good steel and good dies to make them. Different story with today's cheapest cheese-metal spanners.
I round up handfuls of good old BS spanners for peanuts whenever I am at garage sales and flea markets etc. The supply will run out one day so I figure I might as well keep them out of the hands of the hoarders. So I have a full set for each Brit motorbike and lathe in the shed.
Nigel McBurney 110/04/2021 09:18:06
1000 forum posts
Myford used the cheap end of the market black as forged UK made spanners as they knew that their lathes were good and did not need frequent adjustment so these spanners would not see much use.
Matt Harrington10/04/2021 09:42:41
187 forum posts
7 photos
As Steve says, my 'go to' spanner for day to day stuff is a quality Bahco adjustable.
Matt
ega10/04/2021 10:03:54
2539 forum posts
201 photos
Did anyone mention the square socket wrench needed for the standard Super 7 topslide clamp screws?
I long ago changed mine for hex socket screws: easier to access with a ball-ended driver and less temptation to overtighten.
I think that one reason folk reach for the inherently inferior shifting spanner is the difficulty in selecting the right conventional tool from a bunch of others but colour-coding would solve that problem.
SillyOldDuffer10/04/2021 10:56:48
8691 forum posts
1967 photos
Posted by Hopper on 10/04/2021 03:11:13:
Isn't it odd Model Engineers are the only people in the world who believe steel made 60 years ago is better than anything produced today? It's not my experience. When I bought my first socket-set, an elderly chap intervened to explain Japanese tools were rubbish and because it wouldn't last I should spend 3 times more on a British set. Fifty years later the Japanese set is fine (and is now recognised as a reputable Brand!) He was wrong!
In the last 3 years the Chinese made more steel than the British steel industry produced throughout their entire history. It is an enormous quantity of steel and although some of it might be below par, in general it's closer to specification than historic steels. Not paddy farmers stirring old bicycles into a pot, the production is from large modern steelworks using the world's most advanced processes.
Too many British firms after WW2 believed their own propaganda. Rather than accept the need to change and modernise, they tried to convince customers their over-priced products were 'quality' and appealed to our patriotism. Unfortunately, patriotism cuts no ice in export markets. Abroad, British goods came to be associated with average quality and high-prices. At home, people gradually realised they were paying over the odds for stuff that was just expensive.
I suggest we rose-tint the past as we grow older! The past was better because I was young, not because things were done properly then. Now retired, I remember the good bits and expunge the less creditable episodes! Spanners are an example: lasted jolly well most them, but is it due to them being solid, lightly used and kept indoors or ' they used good steel and good dies to make them'. If spanners were wonderful, why did UK makers churn out millions of third rate steel cars? Nice spanner, shame about the car?
I have a GPO tool roll full of well-made British screwdrivers and a contemporary British screwdriver that bends! It's rubbish. Nothing to do with steel, or when and where the screw-drivers were made. The bendy example is too cheap whereas the GPO bought the best tools available at the time, unaffordable for amateur purposes. Important to compare like with like before jumping to conclusions.
Always dangerous to believe your own propaganda. Faced with the need to compete in a rapidly changing world, looking to the obsolete methods of the past is unlikely to work for industry today, no matter how effective they once were. Time flies. It's what customers want tomorrow that matters. There's no place for small 'c' conservatism in manufacturing: such thinking does too much damage.
Dreweatts
Rapid RC
