-that's the question
Versaboss | 06/04/2021 22:23:02 |
483 forum posts 55 photos | Hello all, I'm trying to produce two small cocks (for relieving cylinder pressure at the ends of a steam cylinder, I'm not sure what the correct name for these is). Anyway I tried to bend the actuating stem (brass, 3 mm dia.) about 30°. I warmed the place where the bend had to be with a small gas burner, but the brass broke already after a very small bend. Any help appreciated, |
bernard towers | 06/04/2021 22:29:29 |
573 forum posts 109 photos | Anneal it first |
John Haine | 06/04/2021 22:30:39 |
4626 forum posts 273 photos | I think somewhere I read that you need to get brass VERY hot to anneal it before bending, I'll try to find the reference. |
Michael Gilligan | 06/04/2021 22:38:52 |
![]() 20081 forum posts 1041 photos | A potentially tricky, and unpredictable, job A lot depends on the grade of Brass [which may not be known] Brass is not so much a true alloy, but a mixture there may also be significant lead content to complicate things. MichaelG. |
Michael Gilligan | 06/04/2021 23:51:20 |
![]() 20081 forum posts 1041 photos | This may help : **LINK** https://www.copper.org/resources/properties/microstructure/brasses.html MichaelG. |
larry phelan 1 | 07/04/2021 09:55:02 |
1171 forum posts 15 photos | One of my jobs in a past life was to bend 1/4" round brass bar to 90deg. I heated it to red heat, let it cool then bent it. |
SillyOldDuffer | 07/04/2021 11:30:30 |
Moderator 8491 forum posts 1891 photos | As Michael says, much depends on the Brass. One of my old books says the properties of Brass alloys vary so much between extremes that they should be considered entirely different metals. Brass formulated for casting (plumbing), doesn't anneal or bend well. Naval Brass is strong, not very malleable, and formulated for corrosion resistance. Brass with Lead in it doesn't anneal. Cartridge Brass is specifically formulated to facilitate cold drawing and forming, which is ideal, but even it work hardens rapidly making it necessary to re-anneal at each of about nine stages from blank metal to finished cartridge. Plenty of advice on the web about annealing cartridges. The important thing is not to overheat the Brass, but that temperature depends on the alloy, between 300 and 700°. Common brass anneal at about 450°, a little under dull red-heat in the dark (approx 500°C). Don't know what alloy Jewellery brass is, except its soft and quenched in alcohol. Other brasses are left to air cool. Unfortunately the book I have to hand is vague about Brass, I'll look for another. Dave |
JasonB | 07/04/2021 11:38:10 |
![]() Moderator 22578 forum posts 2637 photos 1 articles | When I have made drain cocks I used 303 stainless for the tapered part and easily bent the handle. Although the softer brasses bend well it's not easy to find small lengths in round section. |
Clive Brown 1 | 07/04/2021 14:33:44 |
807 forum posts 39 photos | I've recently made a couple of drain-cock handles from drawn phosphor bronze rod, 3/16" dia. They bent through about 80 deg. with no sign of cracking, no annealing required. the dia. at the bend is .090" ish. Edited By Clive Brown 1 on 07/04/2021 14:35:52 |
Gareth Jones 9 | 07/04/2021 21:18:55 |
23 forum posts | I've recently been annealing brass by using a 50/50 salt bath of Potassium Nitrate/Sodium Nitrite. Temp is controlled by use of a digital thermometer fitted with thermocouple. The salt is contained in a steel welded crucible and heated with a propane torch. Target annealing temp is something like 350 to 400 deg C. I saw the set up described in Tubal Cain's Hardening, Tempering and Heat Treatment in the Workshop Practise series of books. Gareth |
Versaboss | 07/04/2021 21:50:16 |
483 forum posts 55 photos | Well, that's a lot of stuff to digest! In the meantime I decided to go the easy route and am making new cocks from some stuff I have which is called (by the supplier, Bergeon) "Nickel". I believe it is not really pure nickel, but rather German Silver. I could bend a sample easily without breaking. But as I expected, getting the same angle again on the conical part was almost impossible. I think applying a dab of Timesaver will be necessary. If the drain cocks (now I know the word, thanks) come out only half as good as these from Clive Brown, I will be happy! Many thanks to all for your help, Edited By Versaboss on 07/04/2021 21:50:54 Edited By Versaboss on 07/04/2021 21:51:16 |
Versaboss | 13/04/2021 16:28:11 |
483 forum posts 55 photos | So, finally I did it. The cocks came out quite well I think (but far away from Clive's works). I did not check if they are tight, but anyway they are more a decoration on a small Stuart 10H. Regards, |
