Canon printer
Bill Dawes02/04/2021 23:42:54
472 forum posts
So you computer buffs any clues that might help me with this problem.
I have a Canon Pixma 3650 printer scanner, working wirelessly off my Win10 laptop. Had it for a while now and always worked ok but suddenly decided it will print ok but not scan, Clicking on 'Scan' shortcut I set up it just says 'To get started connect a scanner'. been through all sorts of settings and problem finders to no avail.
Any ideas guys.
Bill D,
Jeff Dayman03/04/2021 00:07:23
2176 forum posts
45 photos
Some ideas which have worked for me in similar device to computer issues:
-check that the printer is still seeing your network
-reboot the computer the wifi is run by, or boot the internet modem if using one.
-shut the printer scanner down, wait 30 sec, power back up.
-connect a USB cable between PC and scanner/printer and see if the scanner will work with that.
Hope this helps. Sorry if it is all obvious to you or has already been tried.
Edited By Jeff Dayman on 03/04/2021 00:07:38
Edited By Jeff Dayman on 03/04/2021 00:07:57
troy Guyette03/04/2021 02:43:54
3 forum posts
It does sound like a driver issue,
please consider going to the Canon web site and download the new version of the scanner driver or the whole suite.
Hopefully this will help your problem.
Sincerely
Troy Guyette
jimmy b03/04/2021 02:52:16
739 forum posts
42 photos
+1 for driver issue.
My Canon printer occasionally won't even print!
I suspect a Windows update causes the issue.
Incidentally, our computers at work started crashing after a Windows update last month, every time we tried to print from a Kyocera printer......
Jim
Speedy Builder503/04/2021 06:43:36
2408 forum posts
191 photos
Built in obsolescence ??? My CANON MP 560 stopped printing black, would scan and copy black, but not print black from the computer. Their drivers are now out of date for the latest operating system.
Also it would loose WiFi so often that it became a pain in the whatnot.
However I did replace it with another - CANON TS 5350. This has the Apple AirPrint (Good for me) OCR, and PDF scanning besides all the norms.
Their ink ( very expensive) is guaranteed for 100 years for photos but I doubt either Canon or myself will be around to verify that !
Oven Man03/04/2021 09:23:14
157 forum posts
31 photos
Have a look at VueScan. It has drivers for many obsolete scanners. It's free to try but you need to pay to use it without watermarks.
Peter
Howard Lewis03/04/2021 13:01:34
5299 forum posts
13 photos
My Epson printer claimed to be worn out. Apparently it contained a counter which declared it kaput and stopped it working after a set number. A local computer shop returned the counter to zero; for a sum.
The next time that it happened, it was no more expensive to buy a new Canon Printer, which would also scan, and copy..
So an otherwise serviceable machine went for scrap
Frances IoM03/04/2021 13:22:12
1157 forum posts
28 photos
another support for Vuescan - allowed my good quality slide scanner of Win98/XP vintage to work under linux as well as a large HP office scanner/printer (minus the very expensive print heads) bought for ?1 at auction pre-covid with the intention of stripping out the motors but the scanning is both fast + excellent quality - really need to find some way of stripping out the scanner
Nigel McBurney 103/04/2021 14:17:18
920 forum posts
After many years with two epson printers,the last Epson wanted some type of servicing and as it was at the start of this lockdown ,went in a hurry to Currys and bought a Cannon g4511 Pixma ,when it prints the quality of black type is very good but it will not work from my applemac unless connected with hard cable,instructions are useless ,helpline just gave a load of instructions to try to cure the non event wireless connection.but they were difficult to understand.I would never buy another cannon printer. Sometime I switch it on and it will print amother its a pig to get it to work,the screen is so tiny and the control buttons so small.
Howard Lewis03/04/2021 15:57:57
5299 forum posts
13 photos
Maybe some of the problems are not being close enough to the router?
I view the images from my Canon MG4200 on the screen of my PC, and being hard wired, the only troubles that I experience are those of an untrained operator, when scanning..
No doubt, familiarity will improve matters.
A comparison between wi fi and hard wired. Wife's lap top, 36 Mb/s hard wired, compared to wi fi, about 300 mm from the router!
In contrast, this wi fi keyboard and mouse need the transmitter to be within 300 mm to be trouble free.
Hardwiring gets my vote
HOWARDT03/04/2021 16:10:19
778 forum posts
28 photos
There are sometimes restrictions in the driver between hard wired and wireless resulting in less functions under wireless. I too use Vuescan with an Epson V750 scanner for film scanning on a Mac, over the years it has operated faultlessly over OS version updates. It is hardware specific so unless you intend to keep the scanner it may be an expensive get out.
J Hancock03/04/2021 16:32:18
724 forum posts
It's that or the paper feed fails, as on my 5750 !
Every sheet has to helped on its way now.
Speedy Builder503/04/2021 16:42:02
2408 forum posts
191 photos
The CANON TS 5350 has an auto power off (Energy saver) but also has a configurable power on when data received. So far, very pleased with it, but it does do a lot of "background" mechanical stuff after a print run - hope its not just gobbling up ink !!
Bill Dawes03/04/2021 19:16:52
472 forum posts
The strange thing is printer will print ok and until recently scanned ok, probably 3-4 weeks ago I last scanned.
Laptop usually 2 to 3 metres away from router, now something just occurred to me, a few weeks ago had internet problems, low speed or stopping all together, BT advised me to press the reset button every few months (the one where you use with a sharp point in a little hole) maybe a coincidence maybe not. The only other thing is that it keeps saying cartridge needs replacing, we know the colour one does, but too tight to replace it yet.
I think I will try the update driver and risk the wrath of 'er indoors if it totally stuffs up the printer.
I have had Canon printers for some years now, probably replace every 5-6 years, compared to the first couple of printers we had many moons ago, Lexmark, Canon faff about whirring and clanking for ever, the Lexmark used to clack once and just got on with it.
Thanks for response guys, will let you know.
Bill D.
Frances IoM03/04/2021 19:28:23
1157 forum posts
28 photos
it needs the yellow ink to print the unique identifying code at top of each page - these identify the individual printer and from sales receipts the owner - just in case you start running off anti-Boris tracts.
Grindstone Cowboy03/04/2021 19:42:33
709 forum posts
58 photos
Posted by Frances IoM on 03/04/2021 19:28:23:
frown
Nick Clarke 303/04/2021 22:00:38
1253 forum posts
50 photos
I too use VueScan but while drivers are available for my HP G4050  scanner they produce scans of appallingly poor quality.
I bought the scanner off the reduced table in PCWorld and I suspect it was returned for this very reason. Thinking I had wasted (some more!) money I was persuaded to try VueScan. Instant superb quality scans!
I bought a registered version and it has updated with every change of OS since.
A great buy!
Edited By Nick Clarke 3 on 03/04/2021 22:01:34
Windy03/04/2021 22:39:08
872 forum posts
185 photos
Am fortunate to have an easy fix for noisy printers I just switch my hearing aid off.
Peter Greene03/04/2021 23:25:07
287 forum posts
Posted by Howard Lewis on 03/04/2021 13:01:34:
Canon printers with the large ink supply do that too. When the printer cleans the head there is excess ink which gets dumped on an absorbent pad. They have calculated how many times the heads can be cleaned before the pad gets saturated and they stop the printer at that point. (The whole thing is pretty crude). You have to take it to a Canon repair station to get it fixed (they say) where they replace the pad and reset the counter. It costs as much as a new printer.
The fix is actually do-able by anyone practically-minded .... the pad replacement is pretty trivial (new pads from BangGood) but you need to summon up the service software to reset the counter.
Funnily enough, I just did mine about a week ago.
The bulk-ink models of these printers sound great but I only got through half the first lot of ink before the pads got saturated.
Grindstone Cowboy04/04/2021 00:53:11
709 forum posts
58 photos
I have an Epson printer (XP332/335) that directs the excess ink through a tube into a little tank at the back, where presumably it congeals and some sort of sensor disables the printer until it's either cleaned out or thrown away - it certainly doesn't get re-used, which is a shame. Not mentioned in the manual, I discovered it whilst sorting out another problem.
Rob
JD Metals
BOLDON
walker midge
rapid Direct
