Ian Parkin | 31/03/2021 16:58:24 |
![]() 1016 forum posts 236 photos | I was browsing eBay looking for a new tap and noticed a few 18mm x 1.5 taps with + 004” and + 0.24 after the size i must confess i had not seen such before why have an oversize tap?...only seemed to be for 18mm that I’ve seen |
Pete. | 31/03/2021 17:04:06 |
![]() 794 forum posts 232 photos | I think it's for galvanised bolts etc? |
Ian Parkin | 31/03/2021 17:18:45 |
![]() 1016 forum posts 236 photos | And are galvanised bolts common in m18? |
colin hawes | 31/03/2021 17:28:44 |
557 forum posts 18 photos | They are used on steel that has to be case hardened to allow for hole shrinkage/distortion. Colin |
Tony Pratt 1 | 31/03/2021 17:59:10 |
1926 forum posts 12 photos | Posted by colin hawes on 31/03/2021 17:28:44:
They are used on steel that has to be case hardened to allow for hole shrinkage/distortion. Colin Good engineering practice is to plug tapped holes so the threads remain soft during the case hardening process or you can carburise the part then drill & tap the required holes then finally harden. Tony |
Pete. | 31/03/2021 18:50:40 |
![]() 794 forum posts 232 photos | Oversized taps do not only come in m18. |
colin hawes | 31/03/2021 19:12:09 |
557 forum posts 18 photos | Posted by Tony Pratt 1 on 31/03/2021 17:59:10:
They are used on steel that has to be case hardened to allow for hole shrinkage/distortion. Colin Good engineering practice is to plug tapped holes so the threads remain soft during the case hardening process or you can carburise the part then drill & tap the required holes then finally harden. Tony I have cyanide case hardened threads to about .005 deep on tooling that requires a wear resistant tapped hole. It gives long life and greater strength. The taps used were known as "B" taps. Colin |
old mart | 31/03/2021 19:48:22 |
3717 forum posts 233 photos | Pre plating and anodising taps will be different oversizes depending on the exact conditions. At the museum we have a large number of taps, mostly given to us and I get rid of the oversize ones before they cause problems. |
alan ord 2 | 31/03/2021 20:32:28 |
![]() 126 forum posts 35 photos | Old Mart you are correct. I used to source pre plating taps, which are slightly oversize for the tapped hole in a component. After plating the tapped hole is to the correct size. This is common in industry. Alan. Edited By alan ord 2 on 31/03/2021 20:33:34 Edited By alan ord 2 on 31/03/2021 20:34:18 |
Tim Stevens | 31/03/2021 21:18:32 |
![]() 1584 forum posts | M18 x 1.5 = sparking plug size before WWII* - just in case it helps. * except model T Fords, of course. Tim |
bernard towers | 31/03/2021 21:39:57 |
568 forum posts 109 photos | Didn’t know anodising changed dimension, mine doesn’t,!! |
Stueeee | 31/03/2021 22:16:49 |
![]() 121 forum posts | Posted by Tim Stevens on 31/03/2021 21:18:32:
M18 x 1.5 = sparking plug size before WWII* - just in case it helps. * except model T Fords, of course. Tim Model T was/is 14 TPI 1/2" American Pipe thread IIRC... Model "A" Ford and early Chevrolet used 7/8" x 18 UNS spark plugs, took a while for the world to arrive at "standard" spark plug threads. |
Tim Stevens | 01/04/2021 09:40:12 |
![]() 1584 forum posts | Not wishing to swerve away from the original thread, but there are currently 4 'standard' plug threads, as well as the piddly little things used in ic engine models. Tim |
