Steel tube for sand muller
Sand Muller
richard perrin31/03/2021 09:53:38
15 forum posts
18 photos
Hi, Have been watching Mark Preslings U Tube videos of his sand muller build, would like to build one as i'm getting to old and weary to be mixing by hand!
any idea where i can obtain the steel tube for the roller, 170mm dia by 160 long
as you can see i only need a short length, needs to have a reasonable wall thickness, i live in Oxfordshire near Chipping Norton.
Richard
JasonB31/03/2021 09:56:37
21652 forum posts
2495 photos
M-machine have a couple of thicknesses in 168OD and will cut to length
Les Jones 131/03/2021 10:20:39
2239 forum posts
153 photos
Possibly a rear roller from a cylinder type lawn mower.
Les.
Bazyle31/03/2021 11:53:23
6087 forum posts
221 photos
As Les says rather than slavishly following a design see what is to hand. Eg saucepan with plate welded on, multiple discs eg weight lifting discs that turn out to be concrete not nice iron. I'm no expert but think a muller rather than a mixer is more for oil bonded sand that is caked in use.
Keep updated on what you make - I hope to need one too one day (due to need to use not due to debility).
richard perrin31/03/2021 14:12:50
15 forum posts
18 photos
Hi, Thank you Bazyle.
I am using oil bonded sand, tried Greensand can't get on with it, my problem nothing to do with sand quality.
Richard
Speedy Builder531/03/2021 14:49:28
2454 forum posts
196 photos
Steel lamp posts - sometimes see them at the scrap yard. I found a bit of 8" some years ago for a log stove chimney
ega31/03/2021 15:05:15
2330 forum posts
191 photos
Posted by Speedy Builder5 on 31/03/2021 14:49:28:
Or a condemned air compressor tank?
Derek Lane31/03/2021 15:13:28
572 forum posts
112 photos
As a temporary stop gap have some turned from some Oak or some other hard wood
JasonB31/03/2021 15:22:49
21652 forum posts
2495 photos
Just to save too many more from making suggestions of rather thin tube the one in the video looks to be 10mm wall and is a "tyre" around some old lifting weights, the 12mm wall stuff from M-machine that I suggested earlier is more in keeping with whats likely to be wanted.
richard perrin31/03/2021 19:26:00
15 forum posts
18 photos
Thank You all, Think i might have a look around the local scrap yard tomorrow where i buy my scrap Alloy Wheels they are usually quite helpful.
Richard
rapid Direct
walker midge
JD Metals
