Portass dreadnought restoration
Bull wheel
Carl Dorling16/03/2021 19:25:51
77 forum posts
56 photos
Hi, I have discovered the bull wheel is past repair does anyone know what the teeth count is .
Mick Dobson16/03/2021 20:29:32
35 forum posts
20 photos
Hi Carl,
I'll have a look tomorrow after work.
Regards, Mick
Mick Dobson17/03/2021 19:20:32
35 forum posts
20 photos
Hello Carl;
The bull wheel has 75 teeth.
Regards, Mick
Carl Dorling17/03/2021 19:37:05
77 forum posts
56 photos
Thank you Mick , and would I correct in saying that it’s 16DP .
Brian Wood17/03/2021 19:44:02
2475 forum posts
39 photos
My apologies Carl for inadvertently leading you astray. Clearly the Dreadnought is a very different lathe to the ordinary Portass versions which were I believe Myford clones.
Regards Brian.
Carl Dorling17/03/2021 19:53:44
77 forum posts
56 photos
Good evening Brian, no problem I’m learning all the time.
Mick Dobson18/03/2021 19:21:16
35 forum posts
20 photos
Hello Carl,
For your question regarding the bull wheel. Yes it is 16DP, same as the change wheels.
Regards, Mick
Carl Dorling12/04/2021 14:30:23
77 forum posts
56 photos
Hi All, I have had a good look at the lathe and noticed more differences to all others I can find pictures of, it has a short rack and a different apron to others that and the headstock design plus the number 5 stamped on all parts leads me to believe this was a very early example so possibly quite a rare lathe definitely worth saving.
rapid Direct
walker midge
JD Metals
