HydroVane PR303E question
Gary Wooding15/03/2021 09:45:24
873 forum posts
227 photos
I originally posed this question in another thread, but got no response. Quite simply, I've got a PR303E but cannot find a user manual for it. In the photos, I think 'A' is the oil filler cap, but don't know what 'B' and 'C' are. Can anyone help please? Does anybody have a copy of the user manual?
Grindstone Cowboy15/03/2021 09:58:36
713 forum posts
58 photos
Just guessing, but I suspect C would access the filter. Not so sure about B though.
Rob
Edit - from the photos, this one on Ebay appears to have an instruction sheet. Might be worth contacting the seller and asking for a photocopy?
Edited By Grindstone Cowboy on 15/03/2021 10:01:33
noel shelley15/03/2021 10:01:57
765 forum posts
19 photos
I haven't got a manual either BUT I have got one of these ! A wonderful and almost bombproof small air commpressor. It has a built in pressure relief set at about 40PSI. A) is the oil level. B) is the filler. C) is the filter. Any oilis better than NONE. I would use SAE 30 unless you have any better info. I can't check mine as I have lent it out. The were made for paint spraying. Hope this is helpful ? Noel.
Gary Wooding15/03/2021 11:15:21
873 forum posts
227 photos
Thanks for your responses guys.
I haven't asked, but judging by the price of the one on eBay (£650), I don't think the seller would co-operate.
Emgee15/03/2021 14:13:48
2158 forum posts
265 photos
Posted by Gary Wooding on 15/03/2021 11:15:21:
I have the same compressor so asked the seller cost for copy of the instruction sheet PDF by email, not surprising £20, bit like the asking price.
All you really need to know is change the oil regularly and clean the intake filter so not bothering with instructions !!!
Emgee
Andrew Evans15/03/2021 14:27:09
342 forum posts
8 photos
Yes, i have one too. Someone left one by the side of the road a few months ago for free and i grabbed it. It was filthy, so i cleaned it up, sorted out the dodgy cable and it works perfectly. Mine has a tyre inflator attachment fitted. Yes, its the oil and filter. You can take them apart easily, there is viirtally no moving parts.
I have a plan to use it to power a mist coolant system as it is pretty quiet - not sure if it can deliver enough air.
John Rudd15/03/2021 15:34:05
1439 forum posts
9 photos
I asked him "what work exactly has been done to this compressor as it is described as 'seller refurbished', did you use any spares?" (potential for mis-selling, not as described)
It wouldn't surprise me if it didn't sell....
Just got a reply on the instructions...£20....Greedy!!
Edited By John Rudd on 15/03/2021 15:41:10
noel shelley15/03/2021 15:43:59
765 forum posts
19 photos
£650 ! Be lucky to get £150
Idear for tyres relief valve lifts at about 40 PSI. Pumps continuously, no electric cutout. Noel.
Bob Rodgerson15/03/2021 15:45:34
609 forum posts
174 photos
Have you priced the cost of a new small capacity Hydrovane compressor. I think that if it is in good working order the asking price might well be reasonable.
Clive Foster15/03/2021 15:53:32
2837 forum posts
103 photos
Mine runs professional Bijur Spraymist systems just fine on my lathes and mill.
DIY mist coolant systems usually need less air so you should be fine. Use a fog buster design.
KWIL15/03/2021 16:08:07
3424 forum posts
66 photos
I do have the manual, but alas my scanner is down at the moment. I also have the bigger HV0* series, but rather more expensive.
Originally used to power a constant bleed paint gun around 30psi. There was also a dental model avai;able (because it is so quiet)
not done it yet15/03/2021 16:22:28
6346 forum posts
20 photos
Make him an offer of £3 and only buy at £5 tops.🙂. But best wait for KWIL.
A pic, with a mobile phone/tablet/camera, and saved as a screenshot is likely good enough for purpose. Especially if emailed at full resolution.
Andrew Evans15/03/2021 23:22:46
342 forum posts
8 photos
I think the instruction manual would boil down to 'clean the filter occasionally and change the oil periodically'. I can't see there is anything else to do or go go wrong.
bernard towers15/03/2021 23:37:00
298 forum posts
85 photos
Hi Gary, had mine for over 35 years now and sad to say have never put oil in it (level hasn’t gone down) or cleaned the filter and touch wood is still ok. It was ex BT cable pressurisation comp.
Emgee15/03/2021 23:52:36
2158 forum posts
265 photos
Posted by bernard towers on 15/03/2021 23:37:00:
Mine also came from a retired BT worker so perhaps it was the std compressor for that job.
Emgee
KWIL18/03/2021 10:52:35
3424 forum posts
66 photos
Gary Wooding.
PM me with your email. I will supply some photos. Note to all, I paid £55 when I bought it new.
noel shelley18/03/2021 11:00:02
765 forum posts
19 photos
You were robbed ! I got mine out of a skip 25 years ago ! Noel.
KWIL19/03/2021 11:26:47
3424 forum posts
66 photos
Yes but mine was brand new (60 years ago) not some grubby throw awaycrying
Tiger12/07/2021 10:06:37
15 forum posts
4 photos
Hi everyone!
It's almost four months later and the one for 650 on ebay is still up for sale. I think it will be up there for another ten years.
Anyway bought one yesterday for 20 quid. Yes, without finding this post I wouldn't know that it has an oil filter, so a manual would be useful. Powered it up yesterday, to test it. It runs and makes air, though I saw the gauge going up quite fast I turned it off to prevent it blowing up. Now I read here that it has a relief valve, something I was thinking of too that it should have, but couldn't see any so turned it off to protect it.
Very silent, took oil level out and oil is a very milky inside. Is that supposed to be white-ish? My main question is, what grade of oil should I get? I can see a net search brings up ISO VG150 for hydrovane compressors. Is that the right oil. Is the oil filter obtainable from somewhere online? I will pop it out once I finish work today.
Thanks!
P.S: also, I want to the attach the output to a used gas cylinder to have some buffer. Anyone done that?
Edited By Tiger on 12/07/2021 10:19:29
KWIL12/07/2021 10:46:58
3424 forum posts
66 photos
Tiger, yes but I run mine attached to an old red floor standing fire extinguisher
walker midge
JD Metals
rapid Direct
