Ternplate
Dr. MC Black08/03/2021 01:08:21
266 forum posts
I have come across a reference to TERNPLATE in a book first published in forty years ago.
I have not been able to discover exactly what Ternplate is, nor whether it is still available.
A chum suggested asking Mr. Google (who, he assured me, was my friend!) but without success.
What is Ternplate, please?
Is it available in the UK?
If not, is something similar now manufactured under a different name?
I look forward to some light on the subject.
Very many thanks
MC Black
Jon Lawes08/03/2021 01:30:44
733 forum posts
Do you have any more info to give us a bit of context? Out of interest I did a bit of googling too, as as you say not much is out there other than a mention of it being a type of roofing similar to (or possibly identical to) tinplate.
We used to have a couple of pieces of steel plate called a turnplate or greaseplate which we used to put under the chinook wheel before castoring it 180 degrees; this made it easier to spin the wheel with one person and I guess spared the tyre a little bit too. I suspect this isn't what you are referring to though!
Jeff Dayman08/03/2021 01:37:39
2199 forum posts
45 photos
https://en.wikipedia.org/wiki/Terne
Graham Williams 1108/03/2021 05:26:21
76 forum posts
41 photos
Memory not so good these days but back in the 60s I'm sure we used Terneplate to press Timing Gear Covers for David Brown Tractors, 2 types, Grey in colour, can't remember the gauge exactly but around 18/20 swg EDD sourced from a plant in North Wales in 20 ton minimum lots.
Speedy Builder508/03/2021 06:40:11
2500 forum posts
196 photos
TERNPLATE
Terne coated stainless steel roof panels (Terne coating is a a zinc-tin alloy metal coating process that gives extra corrosion resistance. Terne metals produced acccording to US ASTM A308 are expected to contain alloys copper, nickel, chromium, molybdenum, vanadium, titanium, columbium, and boron, at alloy mixes depending on the specific product requirement.
Edited By Speedy Builder5 on 08/03/2021 06:46:09
not done it yet08/03/2021 07:03:44
6519 forum posts
20 photos
Worked OK for me. Without the ’e’ comes up half a dozen hits down the list for ‘including terneplate’ on my google.
Dr. MC Black08/03/2021 08:11:24
266 forum posts
Posted by Jon Lawes on 08/03/2021 01:30:44:
Thank you all for taking the time to respond.
The reference (in a book about building model engines) was that Ternplate was easy to bend and solder and preferable to Tinplate.
With best wishes and thanks again.
MC
Andrew Johnston08/03/2021 09:10:20
6405 forum posts
682 photos
From "Definitions & Formulae for Students - Metallurgy" published by Pitman in 1942 at 6d!
Terneplates - steel sheets coated with a mixture of tin and lead
Probably not obtainable now due to the lead.
Michael Gilligan08/03/2021 09:29:42
19599 forum posts
997 photos
Posted by Speedy Builder5 on 08/03/2021 06:40:11:
TERNPLATE
Interesting to note [now that we know the context of the question] that the text which follows after your quotation is probably of more relevance.
... As per Andrew’s historic reference ; the Lead would be a useful aid to soldering.
Rod Renshaw08/03/2021 09:32:16
361 forum posts
From memory, ternplate was used for the bodies of older Landrovers.
Rod
Andrew Johnston08/03/2021 09:42:27
6405 forum posts
682 photos
Posted by Rod Renshaw on 08/03/2021 09:32:16:
...was used for the bodies of older Landrovers.
From the same book:
Used for roofing, oil paint and varnish drums and in the motor-car industry.
Nigel Graham 208/03/2021 10:15:24
1898 forum posts
26 photos
Rod -
Some may have had steel bodies, but I think most of the Series I - III (and the Defender?) LandRovers' panels were made from Birmabright, not steel but an aluminium-alloy, on a galvanised-steel frame.
I suppose a modern equivalent is Corten Steel, a group of weather-resistant alloys widely used for making shipping-containers, sheds and fences. If not painted, they develop surface rust, but otherwise corrode but much more slowly than ordinary mild-steel.
Rod Renshaw08/03/2021 10:20:00
361 forum posts
Nigel,
Yes, now you have said Birmabright, I realise I have misremembered.
Rod
Dave Wootton08/03/2021 10:45:46
230 forum posts
56 photos
I know that for vintage car work where Ternplate was specified coachbuilders now use Zintec sheet, which is I think just mild steel with a zinc coating or plating on it. Seems readily available in large sheets, was given some offcuts and it's lovely stuff to work with, very ductile.
Solders easily too with Bakers fluid or Fluxite.
Edited By Dave Wootton on 08/03/2021 10:47:44
JD Metals
MIDLNDS GARDEN RAIL Jan 2022
rapid Direct
