Alternative for a flywheel
BOB BLACKSHAW06/03/2021 16:44:34
451 forum posts
115 photos
20210306_110203.jpgHello all,
I'm making a Stuart 10v from bar stock and need a flywheel, I've made a few in the past from fabrication to cutting out on the rotary table. Looking in the shed I found two cast iron weights and made one out of it, I thought that it would be difficult cutting through the skin but it cut with ease. I thought I would mention this as I think they look quite good for a flywheel with the lettering and they don't cost a lot to make.
Bob
old mart06/03/2021 17:07:36
3775 forum posts
233 photos
Careful, you may incur the wrath of the OCIWA.
Alfie Peacock07/03/2021 10:15:52
55 forum posts
Who are OCIWA, looking on Google something to do with alcoholism.
Looks good Bob, just shows a bit of junk and a flywheel appears.
Alfie.
old mart07/03/2021 20:49:27
3775 forum posts
233 photos
Old Cast Iron Weights Association. wink
Nigel Graham 207/03/2021 21:27:03
2133 forum posts
29 photos
Ingenious!
You were lucky Avery used a decent foundry (perhaps their own). I once tried machining a piston out of a bit of architectural cast-iron, and inside, it looked as if attacked by woodworm with anaemia. It wasn't wasted though as I needed to make a weight for a small, lift-off cover, and it was fine for that.
My OCIWs are safe though. I need 'em as I bake the occasional cake.
Dreweatts
Rapid RC
