Superglue and Oil?
Brian H06/03/2021 15:18:15
2185 forum posts
113 photos
I have made 2 oilers from glass globes and brass.
Does anyone know if superglue is affected by oil once it is cured?
Brian Wood06/03/2021 17:54:01
2409 forum posts
37 photos
Brian H
Loctite make an oil tolerant 603 retaining compound which should work in your case.
Regards Brian [another]
Ramon Wilson06/03/2021 18:39:36
1098 forum posts
223 photos
Brian I have made several oilers over the years using the Slo Zap super glue. This does not fog and no I've not had any fail though oil. Sometines the glue does become a bit brittle with age and a slight knock might unseat it but it is soon re- glued.
I must point out though I have not used glass but clear plastic tube - either the clear tube that protects artist type paint brushes or the clear tubular enclosures that some cutting tools have. I have used glass on the aquariums on the Corliss engine.
Tug
Brian H07/03/2021 08:20:52
2185 forum posts
113 photos
Many thanks for the answers Brian & Tug, as it happens I have a bottle of Loctite 603, just never thought of using it.
From Tugs answer it would seem that a normal superglue would be OK. The one that I have used is fairly thick and is not an instant one, meaning that repositioning is possible for a short time.
ega07/03/2021 16:21:59
2186 forum posts
179 photos
As we have moved on to Loctite, may I mention that 603 is also tolerant of surfaces which are not "consistently clean" and it can be used for gluing oil impregnated bushes into housings.
According to the data sheets, 601, 603 and 638 all appear to have similar resistance to oil after cure.
Ramon Wilson07/03/2021 17:04:38
1098 forum posts
223 photos
Just to say Brian Pacer products Slo Zap is a medium thick CA which unlike the fast does not have a tendency to fog
Loctite of course is anerobic so works best when gaps are at a minimum.
I've found acetone to be the best clean up for CA and always use Methylated spirits for Loctite - it kills it dead!
Pete Rimmer07/03/2021 19:19:04
1004 forum posts
57 photos
Araldite is also fuel and oil proof once cured. The nromal cure stuff not the rapid one.
Brian H08/03/2021 11:35:26
2185 forum posts
113 photos
I never considered Araldite, even though I have some!
Many thanks to all who replied, you've been very helpful.
Below is a picture of one of the oilers, it just needs a split pin and some worsted thread to complete.
The glass globe is 5/8"inches in diameter.
Cylinder Oiler
JD Metals
walker midge
