Machining phosphor bronzes
Martin Dowing03/03/2021 22:45:22
350 forum posts
8 photos
Some of them are nice and others are pig.
I got one difficult sample.
It turns well to a nice finish, will part off and drill with small (up to 5-8 mm drills).
However drilling with larger drills or slot drills ends up in failure, regardless how sharp they are. Regrinding doesnt help either.
I predrilled 8mm and tried to open up bore up to 12 mm and this was of most horrible drilling experiences I ever had, even if successful after long struggling.
Drill just doesnt want to cut and that's it.
It is not a very hard material either but now I better understand why it is so good for bearings.
Do you have any ideas why it behaves so or know tricks around it?
Lee Rogers04/03/2021 07:55:28
110 forum posts
Try a pilot hole no larger than the web on the next drill , it will reduce the tendancy to grab and pull in, and don't spare the cutting fluid. I've also heard that stopping occasionally and cooling the job helps reduce the grabbing. Cutwell do drills with a modified profile for bronze can't say I've used one though.
David George 104/03/2021 08:23:01
1521 forum posts
472 photos
I modify the drills I use on brass and bronze. I grind the front cutting edge to give a flat cutting face which stops the drill grabbing and use a cutting oil or coolant.brass drills (1).jpg
David
Mike Hurley04/03/2021 08:35:05
97 forum posts
53 photos
Fairly recently I had an issue with a piece of PB when using a brand new slitting saw. It was quite thin (about 1mm) and I ran it pretty much as I would for brass. It contstantly struggled, jammed ( tried with and without lubricant) but finally siezed and stripped several teeth off the saw.
In desperation I stuck it in a vise and attacked it with a hacksaw (32 tpi blade) and it cut like butter!
So if its heat or 'springiness' causing the seizures, slow and steady seems to be the byword.
regards Mike
Ramon Wilson04/03/2021 08:45:41
1074 forum posts
219 photos
If the bronze used by Martin is the drawn pinkish colour hard bronze I think it may be, the one thing you do not want to do is back a drill off as you would for brass to prevent snatching.
We've dealt with this issue recently somewhere - drawn bronze is notoriously difficult to drill due to heat build up and gripping the tool - either drill or reamer. It's self 'promoting' too in that it work hardens very quickly if a tool is not razor sharp so increasing friction and increasing heat extremely rapidly. If flood coolant is available then that does help but for those without this can be one machining op fraught with problems
Step drilling is an issue unless as Lee say the previous hole is no wider that the web of the next drill. Very sharp edges are required and it can help to grind one side of the drill slightly wider than the other.
This material always presents challenges when drilling - I have found it is much better to get as large a hole in as possible with one drilling from a very small pilot hole then bore it to size. Boring for some reason does not create any issues - providing the tool is sharp.
Tug
Neil Lickfold04/03/2021 09:09:13
678 forum posts
102 photos
One trick is to make the drill, cut oversize. Just slightly offset sharpen the drill. Some do work harden, and is a time when you do not want to be cutting dry. Water bases coolants are great for these sort of situations.The modern synthetic coolants have something in them that help in high pressure situations like drilling. A split point drill to the nearest you have and then bore from there. Step drilling does not seem to be as effective as drilling from solid. For a 12mm hole, use a 11.5mm drill straight in from the centre or starting drill. Pre drilling even at 4mm will make the material often work harden.
Nigel McBurney 104/03/2021 09:31:30
845 forum posts
There is a comment in the initial post that phos bronze is good for bearings,phos bronze is not a god bearing material,the only time phos bronze can be used a bearing for shafts,is when the shaft is very hard and ground and there is a lot of lubricant,leaded bronze is a far superior bearing material. One use is where steel or iron pivoting levers with limited motion are bushed with phos bronze to make the motion easier and to prevent seizure from corrosion in exposed situations,
Bo'sun04/03/2021 09:54:53
390 forum posts
Will "slow helix" drill bits work better than "standard" drill bits in phosphor bronze?
Mike Hurley04/03/2021 09:58:17
97 forum posts
53 photos
Have a look at Neil Wyatt's web site ( Stub Mandrel ), in the model engineering section there's an excellent overview of materials and their working properties - including PB. Hope that helps
Edited By Mike Hurley on 04/03/2021 09:58:57
Andrew Johnston04/03/2021 10:00:00
5969 forum posts
667 photos
Posted by Bo'sun on 04/03/2021 09:54:53:
Will "slow helix" drill bits work better than "standard" drill bits.....
They work fine for me in bronze and brass.
Martin Dowing04/03/2021 22:36:06
350 forum posts
8 photos
Many thanks for all your comments.
@David,
Will try your mehod of drill grinding next time.
@Ramon,
Yes, that was my phosphor bronze - very much like material you describe.
Interestingly turning and parting off, very much like boring is rouble free.
It is drilling what is problematic.
Did you or anyone else have tried to tap this material btw?
Also many thanks for comments of some of you that "small pilot hole is a good pilot hole" and Neil's remarks about usefulness of predrilling in such situation in general.
Martin
Peter Krogh05/03/2021 00:45:35
218 forum posts
20 photos
This thread brings up a question I've had: Can silicon bronze be used for boiler bushings, etc. ???
It machines very well.
Thanks,
Pete
Hopper05/03/2021 01:00:37
5379 forum posts
129 photos
Posted by Martin Dowing on 04/03/2021 22:36:06:...
...Interestingly turning and parting off, very much like boring is rouble free.
Possibly running the drill at lower rpm would help? Could explain why the smaller drill worked ok but the larger one was spinning too fast if the spindle speed was not reduced to suit?
Low speed and keeping the feed up to it so its taking a decent cut and not rubbing will in most cases reduce work hardening.
It's impossible to draw hard and fast conclusions about machining "bronze" because even among the phosphor bronze variants there are so many different alloys that all machine differently. You can get leaded phosphor bronze such as Colphos that is made to be machined easily. Others are just plain cows to deal with. Trial and error with any unidentified piece is the only way to really know.
not done it yet05/03/2021 07:05:11
5776 forum posts
20 photos
You may not have noticed that these cutters all have back-clearance?
Ramon Wilson05/03/2021 08:26:18
1074 forum posts
219 photos
@David,
@Ramon,
Martin
Martin,
I have made bushes using this material and had no issues with tapping but like any other cutting tool on bronze it does need a good sharp tap for best approach. However as already noted it is the drilling and reaming that brings out the worst in this particular material.
I would echo Nigels comment that this material is best suited as a bearing on hardened steel shafts for it can (not neccesarily will, gall and sieze) That said it is what I have made all the bottom end con rod bushes on my diesels and they are running on tough but unhardened EN24T steel without any issues so far.
Though theres quite a few pieces of it lying in the drawer, sourced from various shows over the years, it's a material I try to avoid if possible due to the propensity it to seize a drill. It was not that long ago that I had a drill (about 3mm) seize in a piece and snap the drill quicker 'than the eye could see'
Several years ago on a similar theme over bronzes I did this to show the differences in basic bronzes likely to be found in a home workshop.
As already said by someone else there are many different 'brasses' - gunmetal, not shown above probably the most used by ME's
Where possible I prefer to use manganse bronze for bearings in steam engines. The cast bronze is also an excellent bearing material in combination with leaded steel for slower running bearings .
Hope that's of a little further interest - Ramon (Tug)
Edited By Ramon Wilson on 05/03/2021 08:28:12
JD Metals
