Countersink bits
How to prevent chatter?
Bo'sun27/02/2021 11:22:46
390 forum posts
Good morning,
When using HSS "rose" style countersink bits to countersink and chamfer holes in mild steel, how do I prevent them chattering? It occurs with both machine and hand operations.
It doesn't happen all the time, but when it does, it's impossible to correct.
I guess speed and lubrication might be the main considerations.
Michael Gilligan27/02/2021 11:27:10
17641 forum posts
810 photos
Try putting a small piece of thin cotton fabric between the cutter and the work.
P.S. 1, 2 or 3 flute cutters are usually less troublesome
Edited By Michael Gilligan on 27/02/2021 11:30:15
Rod Renshaw27/02/2021 11:30:42
254 forum posts
I think I read somewhere that rose bits were really woodworkers' tools.
Single cutting edge countersink bits, of which there are several patterns, cut mild steel without chattering.
Rod
Bo'sun27/02/2021 11:43:15
390 forum posts
Thank you Michael. Now you mention it, I remember one of the guys at work using a piece of spent emery cloth.
Rod. I did try the "snail" type bits, and they worked realy well, but they didn't appear to be very hard. Probably meant for woodwork. I'll do a search and see if I can find them in HSS.
Howard Lewis27/02/2021 11:44:35
4662 forum posts
10 photos
In my experience, Chamfering tools chatter unless the speed is kept low, and fed very gently.
The 1/2 " one is better than the 3/4" when they are used in the 3 MT Tailstock..
Emgee27/02/2021 11:47:48
1980 forum posts
250 photos
Posted by Bo'sun on 27/02/2021 11:22:46:
Good morning,
Hi Bo'sun
I have experienced the same but found low speed (200) and lube with 1 good hit does the job and leaves a smooth finish if countersinking, for de-burring of small holes I use the same cutter but held in a chuck and operated by hand.
Emgee
Mike Hurley27/02/2021 12:06:45
97 forum posts
53 photos
After years getting oval, off centre or chattered countersinks with these type of cutters, I now get pretty well 100% success with the following 'rules'
1. Work firmly clamped down
2. Slow speed
3. (Probably the key one) be decisive! By this I mean, decide on your depth of countersink, set your stop on the drill press or equivalent on lathe/mill, then 'drill' in ONE FIRM motion to full depth. It always seemed to be the intermittent and 'bit less / or a tiny bit more' approach that causes issues.
regards. Mike
Hollowpoint27/02/2021 12:13:09
414 forum posts
51 photos
While we are on the topic of countersink bits does anyone have any recommendations for good value/performance?
I always found the cheap ones are shockingly bad and the good ones are shockingly expensive. frown
Emgee27/02/2021 12:30:18
1980 forum posts
250 photos
Posted by Hollowpoint on 27/02/2021 12:13:09:
You can make your own single point from silver steel hardened of course, just make sure you back off to give clearance.
Or if you have access to a tool grinder do the same from HSS.
Emgee
Bill Phinn27/02/2021 12:38:32
470 forum posts
78 photos
The range of Sherwood single-flute csks from Zoro are excellent in performance and value.
Alpen three-flute csks give very good performance as well though are a little pricier.
Machine countersinking shouldn't cause chattering as long as you keep the speed and downfeed pressure low, and have good stiffness in the set-up. I tend to use Vactra no.2 as a lubricant, when I do use a lubricant.
Edited By Bill Phinn on 27/02/2021 12:46:23
bernard towers27/02/2021 12:54:26
138 forum posts
70 photos
I use the through hole ones in various sizes as I have zero success with any that have more than one cutting edge, and speed is definitely a factor.
Philip Rowe27/02/2021 13:41:43
205 forum posts
29 photos
Since I switched to using spotting drills instead of centre drills, I have found that they also make excellent countersink bits with no chatter at all.
Phil
Douglas Johnston27/02/2021 14:26:55
738 forum posts
34 photos
Posted by Philip Rowe on 27/02/2021 13:41:43:
Phil
+1 for that. I discovered this quite recently after buying a set of various diameter 90 degree spotting drills on the bay. They cut a treat and give a very neat countersink if you pick one just a tad bigger than the screwhead.
Doug
Martin Dowing27/02/2021 16:13:26
350 forum posts
8 photos
There are *asymmetrical* countersinks where 3 segments with cutting edges are at different angles to each other.
This design is implemmented explicitly to reduce / prevent chatter.
Martin
Henry Brown27/02/2021 17:47:25
434 forum posts
99 photos
The RDG 3 flute ones are good. I've got a few, 25mm is the largest, they need to be run slowly with lots of cutting oil, I use CT90.
Georgineer27/02/2021 18:25:48
502 forum posts
30 photos
Posted by Martin Dowing on 27/02/2021 16:13:26:
Martin
Dad had one he made when he was an apprentice which had just one 'tooth' at a different angle from the others. It was a delight to use. I think one of my brothers had it when we sorted out Dad's workshop.
George B.
JD Metals
