Magnetic v-blocks - how useful these are?
Martin Dowing24/02/2021 20:29:21
355 forum posts
8 photos
There are on offer on ebay Indian magnetic v-blocks. Cannot include url because it is very long link and I don't know how to shorten it.
Of course words "Indian" and "precision" does not mix well but anyway how useful such a tool might be?
How well are they holding barstock?
Would they be useful for cross-drilling a bar (where geting rid of clamps can be a great advantage) or maybe for light milling operations, particularly if bar can be axially supported on one end to take a force of cut?
Do you have any experience with these and if so then what is your opinion about them?
Edited By Martin Dowing on 24/02/2021 20:30:34
Edited By Martin Dowing on 24/02/2021 20:33:23
Colin Heseltine24/02/2021 20:39:54
634 forum posts
220 photos
I have used mine to hold a length of rod whilst it was cross drilled, and it worked a dream. I was struggling with standard v blocks as the clamps kept getting in the way of the drill chuck.
Oily Rag24/02/2021 20:41:12
529 forum posts
172 photos
Good tool which has many uses, such as; marking out, inspection, drilling and milling. Have not looked at the ones you have pointed to on eBay but as with any magnetic unit the quality lies in the magnets the physical properties of the 'Vee' are the mechanical aspect of quality.
I bought 2 units about 4" long and about 2 1/2" square, with a single deep Vee, accurately ground on all major surfaces. The switch was substantial, a metal 'wing nut' type. They are very powerful and were good VFM. They came in a nice felt lined wooden box, not that that in itself is any guarantee, but nice all the same. If you asked me where they originated I would have said either Taiwan or India.
Martin
Michael Gilligan24/02/2021 20:41:58
19589 forum posts
997 photos
I would expect them to be more useful for alignment than serious work-holding .. but I may be surprised.
What I can tell you though, is that everything in your ebay URL ... from the question-mark onwards, is ‘tracking’ rather than the actual address.
This should work fine:
https://www.ebay.co.uk/itm/Precision-Magnetic-Engineers-V-block-2-5-65x65x50mm-Workhold-Premium-vee-block/363030766520
Edit: __ I am surprised alreadyblush
Edited By Michael Gilligan on 24/02/2021 20:43:43
Jeff Dayman24/02/2021 20:41:59
2200 forum posts
45 photos
I'd be hesitant about using magnetic V blocks because they will literally be a magnet for dirt and chips. If you are trying to do accurate work location and holding, a bunch of dirt and chips stuck to a V block will not help much. Getting them really clean may be a real chore too if the magnets are strong. Don't do it, is my opinion.
John Haine24/02/2021 21:18:45
4420 forum posts
262 photos
Duct tape gets chips off magnets.
David George 124/02/2021 21:30:32
1715 forum posts
500 photos
I have used magnetic V blocks many times and wish I had some now. I have only used Eclipse made ones and when you turn them off there is almost no magnetic flux. They were quite expensive to buy and hadn't looked for them since retiring. When at work we would use them to hold diameters to mill flats or drill holes in diamiter or square pieces as well as surface grinding as well.
David
old mart24/02/2021 21:49:17
3510 forum posts
216 photos
I bought a big one, probably Indian origin last year, but have not yet used it. It checked out ok on the surface table.
Clive Foster24/02/2021 22:00:38
2988 forum posts
105 photos
Cling film is your friend when keeping magnetic devices swarf free.
One layer has no noticeable effect on magnetic grip but can easily be simultaneously lifted off and and wrapped around the swarf. Pretty much an essential trick with a permanent magnet device but useful with switched ones to as it keeps swarf out of the works.
Like David I can't say that I've ever missed having magnetic Vee blocks at home as I (so far) already have sufficiently good alternatives.
They are useful devices though.
How much so depends on what you do and what other kit you have. Not, I think, something to get because they ought to come in handy somewhen. More something to aware of to be gotten when the need arises. You will know it when you see it!
Mike Poole24/02/2021 22:03:24
3162 forum posts
72 photos
I would be wary of anything but the lightest cuts on a mill, I think they are best for grinding, marking out and inspection tasks.
herbert punter25/02/2021 10:16:44
128 forum posts
Posted by Martin Dowing on 24/02/2021 20:29:21:
If you believe that the terms ‘indian’ and ‘precision ‘ are mutually exclusive, it may be interesting to look up Jantar Mantar, Jaipur. I went there a few years ago, and was very impressed.
Bert
Nigel McBurney 125/02/2021 15:13:55
962 forum posts
I have had a Mitutoyo magnetic vee block for 30 years,I rarely use it,the snag I found was that if you want to drill a cross hole in a shaft on a drilling machine,a centre pop on the shaft is set central by eye,then the mag "on" lever is operated,thats ok it holds the work resonably securely but the magnetism in the base stops the block being slid around on the drill table to get the centre pop under the drill point,I prefer an ordinary vee block,if precision is required then its either use a vee centre in the lathe tailstock or on larger round bar work its a machine vice on the vert mill set up central using a wobler tool.I have three sets of paired vee blocks ,plus a very precise Bilton single block and an Eclipse toolmakers vee vise. Though they all suffer with the snag of the drill chuck can hit the clamp on occasions. I do have a pair of old Verdict v blocks which have the an arrangement of slots on the sides of the block which contain the clamp so if the block is laid on its side the clamps do not foul the surface plate or drill table,My mag vee block came "free" I would certainly not buy one.My pair of Eclipse hardened steel vee blocks,are now 60 years old very expensive in those days bought at a small discount via the company apprentice tool scheme,though still in excellent condition.
Martin Dowing25/02/2021 23:02:40
355 forum posts
8 photos
Posted by herbert punter on 25/02/2021 10:16:44:
Bert
I am aware of story from Myford (Beeston; N'gham) - they have ordered from India collets for ML7/S7 lathes - they had to be returned because specification was not met. So Indians made a new lot - also had to be returned.
This was long time ago. More recently I have purchased rotary table from Indian conpany - it was simply unusable.
Rotating part of this table was simply "wiggling" in its housing. I had a lot of troubles to make it working (remachining and loctiting of processed precision ring from bearing made a trick, though CBN insert have gone damaged in the process).
But it is a large country so surely somewhere must be few companies which are keeping good standard.
Anyway, many thans for comments all of you.
It seems o be useful device.
Martin Dowing25/02/2021 23:18:52
355 forum posts
8 photos
Posted by Nigel McBurney 1 on 25/02/2021 15:13:55:
Nigel,
I have made myself a simple device (precision ground bar with 2 holes precisely crossdrilled & reamed 4 inches apart and exactly through center).
This allows me to set vee block exactly at centerheight and parallel to lathe bed (short section of precision rod hold in collet must pass without any resistance through these crossdrilled holes - made to h6/H7 fit.
Vertical slide is manipulated to achieve that.
Once done you are ready to for cross drilling. Setting milling machine would be comparable.
Gary Wooding26/02/2021 11:17:11
932 forum posts
236 photos
.............................................................. Cannot include url because it is very long link and I don't how to shorten it.
I use a website called TinyURL. It converts any URL into a very short URL that you can then use directly, or copy into an email or anything else you want.
Ketan Swali26/02/2021 12:18:28
1400 forum posts
126 photos
Martin,
The quality of Indian magnetic stuff depends on maker. To the best of my knowledge, there is only one good maker near Delhi, but the probability of his stuff getting onto eBay is next to zero, because his product range is extremely expensive. There are plenty of small makers of magnetic V blocks in that region, but most are poorly made. The better makers are to be found in the south of India, such as in or near Puna, but again, very expensive, and selling on eBay would be outside their interest, as they are usually very busy working with big industry customers.
90%+ of eBay Indian sellers are extremely small traders similar to the one shown in Michaels G's link, with a small number being large stockists hiding behind different names for tax reasons, or to avoid conflict with their overseas agents/partners with whom they have territory distribution agreements which are made in their real name smiley. They buy two to four pieces at a time of a product from a maker, as and when an order comes in. The makers are usually small scale cottage industry operations, and they usually have stock of good, bad and rejects, which they are happy to sell on to the eBay sellers at different rates. The product may or may not meet your requirement.
ARCs magnetic V blocks come from China only and we are happy with the product we sell. However, regardless of the force of the magnet, I would generally agree with Michael Pools comments: ' I would be wary of anything but the lightest cuts on a mill, I think they are best for grinding, marking out and inspection tasks. '
If you wish to buy Indian, you would be better to look at supply from Chronos - Soba range. Soba have an inspection process, and what ever they reject goes back to the maker, and what is left with the maker ends up on eBay. At least, if you are not happy with the product, you can always return it to Chronos.
Ketan at ARC
Edited By Ketan Swali on 26/02/2021 12:21:19
walker midge
JD Metals
rapid Direct
