Mike Donnerstag | 23/02/2021 16:48:50 |
![]() 210 forum posts 46 photos | I acquired this metal block many years ago. It appears to be etched and comes with its own wooden box. Can anyone tell me what it is used for? Many thanks, Mike |
Michael Gilligan | 23/02/2021 16:52:46 |
![]() 20070 forum posts 1040 photos | Your starter, for 10 https://shop.bsigroup.com/ProductDetail/?pid=000000000000163551 MichaelG. . ... and a useful Wikipedia page : https://en.wikipedia.org/wiki/Brinell_scale Edited By Michael Gilligan on 23/02/2021 17:10:36 |
Mike Donnerstag | 23/02/2021 16:56:45 |
![]() 210 forum posts 46 photos | Thanks Michael. Perhaps a better question would have been: Is it worth anything to anyone or should I scrap it? Mike |
Nigel Graham 2 | 23/02/2021 16:59:20 |
2026 forum posts 28 photos | I've never seen such a thing previously but you could be right, judging by the faint words along the front. There is a hardness-test technique based on indentation made by a hared steel ball, so this may be part of such a hardness-testing kit, but I am foxed by the disposition of the hollows. Might have been for some specific trade. Have you tried investigating the company itself - Avery Denison? (Probably long gone but worth a try.) |
David Jupp | 23/02/2021 17:03:49 |
822 forum posts 17 photos | It's a calibration standard for the Brinell hardness test. Used to verify that the test device / microscope / operator are giving sensible results. The ID of the standard, and the square used will be recorded in the calibration log. |
noel shelley | 23/02/2021 17:06:19 |
1281 forum posts 21 photos | The part number could be RS. A hardness tester where each square is a test ? Next question ? Noel |
Michael Gilligan | 23/02/2021 17:29:23 |
![]() 20070 forum posts 1040 photos | Notes available from NPL : **LINK** https://www.npl.co.uk/products-services/advanced-materials/hardness-testing MichaelG. |
SillyOldDuffer | 23/02/2021 18:49:57 |
Moderator 8487 forum posts 1890 photos | My guess is the plate was used to check a hardness testing machine is delivering the right whack and the ball isn't damaged. It tests the test machine, which is how I read David Jupp's answer. The plate would have started blank and then been dinged periodically to confirm the test machine is in good order. The dents should be identical, but will gradually deteriorate as the machine ages. The plate is evidence of how consistent the machine is. I suspect it's naughty to put more than one ding per square because a too close dent might effect the local hardness. If the plate was made to confirm a hardness tester was performing to standard, then the plate was also made to a standard. Expensive when new, I suggest this one is used up and useless. Could be completely wrong! Dave |
Grindstone Cowboy | 23/02/2021 18:54:20 |
854 forum posts 64 photos | Could you turn it over and use it as something flattish to stick wet and dry on? Thus saving your surface plate the indignity. Rob |
old mart | 23/02/2021 18:56:24 |
3720 forum posts 233 photos | Posted by David Jupp on 23/02/2021 17:03:49:
It's a calibration standard for the Brinell hardness test. Used to verify that the test device / microscope / operator are giving sensible results. The ID of the standard, and the square used will be recorded in the calibration log. It has BRINELL HARDNESS on the bottom.
Howard Lewis | 23/02/2021 20:09:46 |
6013 forum posts 14 photos | It would probably been part of the kit supplied with an Avery Denison Hardness Test Machine. And somewhere along the line, they become separated. Howard |
Bazyle | 23/02/2021 20:15:58 |
![]() 6295 forum posts 222 photos | Intergallactic multidimensional dominos. Anyone watching 'Fringe' will know it came from the parallel earth in exchange for a box of ballpoint pens. |
Hollowpoint | 23/02/2021 20:26:46 |
464 forum posts 56 photos | Predecessor to swiss cheese? Seriously though, don't scrap it! Its a nice looking thing in its own right. |
Jon Lawes | 23/02/2021 20:41:32 |
![]() 876 forum posts | Someone might be looking for one of those. Whack it on eBay with a sensible reserve and someone somewhere might be very glad to have it.
