Michael Gilligan | 21/02/2021 20:14:51 |
![]() 20182 forum posts 1053 photos | On the off-chance that people may find another use for them: Radiator Keys for 1/4” square are available from HomeBargains at 79p for two. They are remarkably similar to these: **LINK** https://www.castironradiatorcentre.co.uk/products.asp?code=CDC-BLEEDKEY&name=radiator-bleed-key Not a very convincing ‘square’ compared to some alternatives, but that may make them even more adaptable. MichaelG. . https://storelocator.homebargains.co.uk/ Edited By Michael Gilligan on 21/02/2021 20:16:12 |
Paul Lousick | 21/02/2021 21:20:30 |
2043 forum posts 722 photos | You could make your own by forging one. Making a square intermal shape can be done by drilling a hole in a piece of round bar that just slides over the corners of the spindle on the valve. Then heat the round bar (red hot), insert a piece if square rod with the same size as the spindle and squash it down onto the square rod. Remove the square rod while still hot or it may not come out.
Michael Gilligan | 21/02/2021 21:31:14 |
![]() 20182 forum posts 1053 photos | That’s why I remarked upon the price. MichaelG. |
Steviegtr | 21/02/2021 21:34:59 |
![]() 2432 forum posts 336 photos | I have a few good quality brass ones on key rings. I did buy a cheap couple for the tool box only to find they were a bit oversized & slipped on well used & bled rads. Steve |
Michael Gilligan | 21/02/2021 21:43:13 |
![]() 20182 forum posts 1053 photos | In case it’s not obvious ... I was proposing them as “make from” material, not as radiator keys. MichaelG. Edited By Michael Gilligan on 21/02/2021 21:44:28 |
Steviegtr | 21/02/2021 21:45:20 |
![]() 2432 forum posts 336 photos | Posted by Michael Gilligan on 21/02/2021 21:43:13:
In case it’s not obvious ... I was proposing them as “make from” material, not as radiator keys. MichaelG. Edited By Michael Gilligan on 21/02/2021 21:44:28 Steve. |
