You think you have trouble starting your car on a cold morning?
Neil Wyatt16/02/2021 18:00:44
18548 forum posts
723 photos
78 articles
That took a bit of effort!
Joseph Noci 116/02/2021 18:07:51
881 forum posts
1071 photos
Nice One Neil!
There are many utube videos with engine starts as the theme ( some steam as well) - from old aviation engines, tanks, trucks, ships, etc and, for some odd reason, I am hooked on watching them...
Joe
Bazyle16/02/2021 18:22:02
5831 forum posts
216 photos
wouldn't fancy having to do a push start wink
Grizzly bear16/02/2021 18:35:52
278 forum posts
8 photos
Not much thought for the batteries and starter motor. Typical driver!
V8Eng16/02/2021 18:37:13
1556 forum posts
30 photos
Should’ve got some decent Welsh steam coal.devil
Edited By V8Eng on 16/02/2021 18:37:38
Mike Poole16/02/2021 18:39:58
2936 forum posts
70 photos
If it had to have an MOT it might be a bit marginal on the smoke testsmiley
Edited By Mike Poole on 16/02/2021 18:40:14
Nick Clarke 316/02/2021 18:47:06
1154 forum posts
48 photos
One of the more senior members of our club was a fireman on the GWR and a driver on GWR and BR. He says that the multiple units would go flat overnight on shed so they were just left running instead!
Edited By Nick Clarke 3 on 16/02/2021 18:47:32
Phil Whitley16/02/2021 18:52:10
1316 forum posts
147 photos
Kigas? Easystart?
JohnF16/02/2021 19:01:46
1054 forum posts
158 photos
Should have had a lamp under the sump !
Howard Lewis16/02/2021 19:02:02
4662 forum posts
10 photos
Kigas, yes. Easystart NO.
The ether tends to wash bores clear of oil.
Have you seen film of an Alco loco starting, even under reasonable conditions? As bad if not worse than that Class 50.
At -30C if an engine cranked for more than 30 seconds before first fire, it was deemed a failure.
The electrician at Bognor depot once timed a bus that had stood outside overnight, cranking for SEVEN minutes before it self sustained! The starter and cables were too hot to touch by then I would imagine.
Quite often, first fire raised the cranking speed, so that a second cylinder joined in, and as the cranking speed increased the others came in, in turn. The end result was a great cloud of unburned fuel from the late comers!
Which is probably what we are seeing here.
Pete White16/02/2021 19:10:53
139 forum posts
16 photos
Posted by Phil Whitley on 16/02/2021 18:52:10:
Kigas? Easystart?
Once you needed Easy start it was the begining of the end, burnt all the crap out that was sealing your rings.surprise
I once had a Landrover with 2.2 BMC diesel fitted that fired up like that, cold Start button, that just chucked loads of fuel in, good for going up hill loadedyes, they were not supposed to be accessible from the driving seat, it used to fill the yard with Fog.
Pete
Mike Poole16/02/2021 19:11:11
2936 forum posts
70 photos
Pete White16/02/2021 19:11:54
139 forum posts
16 photos
Pilot error, dual post, I blame the internet.
Edited By Pete White on 16/02/2021 19:14:47
john halfpenny16/02/2021 19:12:59
142 forum posts
21 photos
One very cold morning I was instructed to hit the starter on an ancient double deck Leyland, and not release until told. The owner operator soaked rag in easy start, lit it with his fag, and threw it into the air intake. The engine clattered into life one cylinder at a time over nearly a minute. I was only then instructed to let go. A life lesson.
Zan16/02/2021 19:23:40
225 forum posts
18 photos
Gee you can’t get decent coal these days I wonder where it came from?👻
Andy Stopford16/02/2021 19:40:51
71 forum posts
Posted by Nick Clarke 3 on 16/02/2021 18:47:06:
They used to do this at Tonbridge with the Hastings Line DMUs - when the inevitable letters of complaint were printed in the local rag, a BR representative would explain that the engines were worn out and would be unstartable if left to cool down overnight.*
Of course being left ticking over all night glazed the cylinder bores, making the engines even harder to start, and making them produce steam engine-like clouds of smoke. It wasn't limited to DMUs. BR was so cash-starved in its latter days that apparently they couldn't afford batteries for the big single unit diesels, and wrecked the engines by leaving them idling all night. Of course everyone involved with the motive power side of things knew this was a stupid thing to do, but ... politicians.
*I seem to recall it was said that the Sulzer engines in these had negative clearances when cold, so the donkey engine, which was plumbed into the same cooling system had to be started a couple of hours in advance to warm the engine up so it could be cranked over.
Jon Lawes16/02/2021 19:41:31
506 forum posts
When they couldn't get the A&AEE Harvard started after the first few attempts you had to take the plugs out, whether for cleaning or replacing I don't know, but it's not a task that looked fun!
Howard Lewis16/02/2021 19:44:26
4662 forum posts
10 photos
We once started a truck at MIRA by holding a flaming rag over the air intake (The injection pump provide excess fuel, for starting, but was so worn that when checked it was at normal running level). Once running it was still good for nearly 60 mph around the track.
Didn't think that Land Rovers had excess fuel (No production DPA provided it) My Sries 2 relied on heater plugs. Substituting a CAV Thermostart which heated the ingoing air with a flame much improved cold starting!
The Leyland PD2 and PD3 used a CAV fuel, injection pump fitted with a governor which provided excess fuel, and were ready cold starters.
The same 0600 engine with a DPA without excess fuel was nothing like as good.
A lot of modern engine ECUs keep the heaters energised after start up to prevent light load misfires and smoke.
The fuel supplied has a great effect on starting, smoke and running. Cetane value and calorific value have a huge effect.
Jeff Dayman16/02/2021 20:09:04
2121 forum posts
45 photos
The last ditch engine start technique for temps here in Canada for days below -25 deg C at the family garage was to take a pint pouring can (with thin spout), put a few ounces of gasoline in it, light it, and pour fire directly into the open intake while cranking the engine.
Extremely dangerous, not the done thing these days I am sure, but it worked, particularly on very large gasoline and diesel engines. Definitely worked better the older the engine was. We worked on cars trucks and tractors from the 1920's to the 1980's in the family shop.
Nowadays you would be challenged on most cars and trucks to find a vertical intake hole of any kind to pour the fire into.
We got many calls for "engine won't start" on such days, on locally used cars, mostly 1960's-1970's US made ones. Dad had rigged an extra long set of heater supply and return hoses into the 327 Chev V-8 in our service truck. He arranged end-of-hose valves and couplers so that on such calls he would disconnect the heater hoses from the car's engine block and connect in the long ones from the service truck's running engine. 5 minutes of hot circulating coolant and 9 out of 10 engines would start just fine. Another 5 minutes to disconnect hoses / fix car's coolant level , return to the garage where the phone was ringing off the wall, and then send a bill for $25 whole dollars. Without the hot coolant many cars just would not start at say -30 deg C regardless of what you tried or for how long.
Edited By Jeff Dayman on 16/02/2021 20:09:29
John Pace16/02/2021 20:15:31
249 forum posts
167 photos
Hi
Seeing Howard's post about the flaming rag ,at Worthing
depot it was common thing during the cold weather to
use a paraffin rag on a bent piece of welding wire
on Mk1 Leyland National buses ,the manifold heaters
were a heater coil that had a fuel supply that were a
common problem with fires and were mostly disconnected
hence the burning rag ,with the layout of these vehicles
the usual procedure was to drop out the air filter stuff up
the rag crank over and off you go ,one day i was on a late turn
and the lad who was on the morning shift tried it and left the
air filter element in place ,set fire to the air filter which spread
to the rest of the bus ,when i came in later in the day all that
was left was the burnt out carcass , happy day's.
JD Metals
